UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Oct 24, 2017 at 3:02 PM
    #1201
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    I can get 9-9.5 psi on 2.825 pulley and no cats. Gotta be a heat/octane issue
    dark vader trd pro likes this.
  2. Oct 24, 2017 at 4:43 PM
    #1202
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    2.55" pulley only making ~8-9 psi is your problem. Belt slippage and or bypass isn't closing all of the way, @jojotoo.
    Roostfactor and jojotoo like this.
  3. Oct 24, 2017 at 4:48 PM
    #1203
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Remove the vacuum source to the bypass valve. Cap and plug to prevent leaks. Do a test drive and see if your boost goes up. If so, then your bypass valve is a problem. If it is the same, then it is the belt.
    jojotoo likes this.
  4. Oct 24, 2017 at 5:05 PM
    #1204
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    interesting..
    its definitely not belt slippage.
    ill try this " Remove the vacuum source to the bypass valve. Cap and plug to prevent leaks. " .. thanks !
  5. Oct 24, 2017 at 5:25 PM
    #1205
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Report back soon!
  6. Oct 24, 2017 at 7:05 PM
    #1206
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Damn Im the same as you and I get ~6 psi max.
  7. Oct 24, 2017 at 7:36 PM
    #1207
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    All of you people with smaller pulleys, did you replace the belt with the next smaller belt?
    loginfailed likes this.
  8. Oct 24, 2017 at 7:36 PM
    #1208
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What is your elevation?
  9. Oct 24, 2017 at 7:55 PM
    #1209
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I did.
    Paraphrasing from Scott:
    jojotoo likes this.
  10. Oct 24, 2017 at 7:58 PM
    #1210
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Perfect quote.
    I remember you had. Just not sure how many of the other members in here did. :thumbsup:
    jojotoo and loginfailed[QUOTED] like this.
  11. Oct 24, 2017 at 8:06 PM
    #1211
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I didn’t think it was really slipping before. I was just changing to the belt as a preventative.
    I felt a difference right away. It wasn’t slipping at high RPM really, because I was above 10psi. But it is those quick RPM changes is when it slips like when your blip the throttle. Throttle feels more responsive with the shorter belt.
    Also, before changing the belt I had a few episodes when deep into the throttle it would go womp womp womp and it felt like fuel cut. Pretty sure that was belt slip. RPM wasn’t high enough to be rev limit. It hasn’t done that again since the new belt.
    gersus, jojotoo and Torspd like this.
  12. Oct 24, 2017 at 8:36 PM
    #1212
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Ever since installing my blower I haven't seen the boost I thought I would see. Using a Speedhut 15psi gauge. 2.85" pulley, automatic transmission, stock exhaust. Max I see is 6.5psi floored in 4th.
  13. Oct 24, 2017 at 8:39 PM
    #1213
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Mine w/ 2.85 was about 8psi on a really cold day it got up to 9psi.
    Close to sea level, maybe 150ft elevation.
  14. Oct 24, 2017 at 8:43 PM
    #1214
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Good week for boost around Houston, eh? ;)
    loginfailed[QUOTED] likes this.
  15. Oct 24, 2017 at 8:45 PM
    #1215
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Yep. That first cool morning is when I logged 340g/s MAF. :thumbsup:
    Torspd likes this.
  16. Oct 24, 2017 at 8:50 PM
    #1216
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    At 5500 ft I only get 7 psi. I didn’t go smaller on sc belt having the NST and 2.55 combo.
  17. Oct 24, 2017 at 8:51 PM
    #1217
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    What NST pulleys do you have?
  18. Oct 24, 2017 at 9:01 PM
    #1218
    TRON
    I have the NST overdrive kit...
  19. Oct 24, 2017 at 11:33 PM
    #1219
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Great suggestions with belt slippage and faulty bypass valve but another potential symptom could be improper bypass valve adjustment. If the adjustment stop isn't allowing the bypass valve to close all the way the pressure will be bled through the bypass valve even with no belt slippage or vacuum issues.
    Torspd likes this.
  20. Oct 25, 2017 at 3:28 AM
    #1220
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    I got the same 9+ PSI with stock 3.0” pulley. :eek:
    ...but I had a faulty Speedhut pressure sensor. Their answer: ”we received a shipment of them that are all reading between 1-2 PSI too high” and I got a new one which shows right.
    I ordered mine in April this year, got it in May.
