UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Oct 29, 2017 at 7:14 AM
    #1241
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    What mileage are you getting? Mine gets about 12.5 MPG. I think the tune could be improved for fuel efficiency, but I figured since mine is running perfect no need to fiddle with it.
    I only drive 16 miles a day so fuel efficiency isn’t really a big objective for me anyways.
  2. Oct 29, 2017 at 3:03 PM
    #1242
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    About 16.5 MPG.
  3. Oct 29, 2017 at 4:06 PM
    #1243
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Haha must be nice!
  4. Oct 29, 2017 at 4:36 PM
    #1244
    FinnJ
    Finland
    No, 30 MPG would be, but I’d happy with 20 MPG. Gas costs twice as much here. Today’s local price is $6.36/gallon. CNG is almost 50% cheaper, but here is only few stations where you can tank up it.
  5. Oct 30, 2017 at 7:42 AM
    #1245
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Pre-supercharger I used to get about 18mpg highway. Post supercharger started around 17, then dropped to 16 in August/September. Now I'm at 14.
  6. Oct 30, 2017 at 8:56 AM
    #1246
    oni06
    oni06 Well-Known Member
    Less skinny peddle.
    I get about 16 highway on long drives with cruise control on doing 65.
    Putting around town 13 or less depending on boost used.
  7. Oct 30, 2017 at 9:40 AM
    #1247
    Voodoo Rufus
    Bakersfield, CA
    Did you even see the spark plug pics? Ping, rough idle, and declining mileage together are not normal.
  8. Oct 30, 2017 at 9:46 AM
    #1248
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I did. They were super rich. Do you have any CEL's? Do you have any major vacuum leaks? MAF dirty?
  9. Oct 30, 2017 at 9:47 AM
    #1249
    oni06
    I did not and no that is not normal. :(
  10. Oct 30, 2017 at 9:51 AM
    #1250
    Voodoo Rufus
    Bakersfield, CA
    I occasionally get a P0136 since the S/C install.
    Checked all the vacuum and PCV lines attached to the S/C and they seem normal so far.
    Anything else I can check? I should probably verify the S/C intake manifold gasket and to the cylinder head.
  11. Oct 30, 2017 at 9:59 AM
    #1251
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Do you have a catch can? Have you sprayed of used a silicone stethoscope to investigate for vacuum leaks?
  12. Oct 30, 2017 at 10:01 AM
    #1252
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    Still battling p0420 and p0430.
    No exhaust leaks.
    Sent Scott freeze frame data.
    Here is what we found.. per scott.
    1. P0420 – bank-1 issue
    2. Here is the operating space
      1. engine rpm / 1665 - min
      2. vehicle speed / 88 km-h
      3. calculated LOAD value / 57.6%
      4. engine coolant temp / 88*C
      5. commanded throttle actuator control / 23.5%
      6. fuel/air command equivalence ratio / 0.965 (rich)
    3. Adaptives all look good:
      1. These show the trims all balance
      2. short term fuel trim bank 1 / 5.5%
      3. long term fuel trim bank 1 / -0.8%
      4. short term fuel trim bank 2 / 0.8%
      5. long term fuel trim bank 2 / -8.6%
    4. Here is the clue:
      1. equivalence ratio lambda B1-S1 / 1.041 (wraf1 reads lean)
      2. oxygen sensor output voltage B1-S2 / 0.175V (hego1 is lean)
      3. equivalence ratio lambda B2-S1 / 1 (wraf2 at stoich)
      4. oxygen sensor output voltage B2-S2 / 0.820V (hego2 is rich)
    5. Hypothesis:
      1. Assumptions:
    i.Tests for both banks are done at the same time in parallel
    ii.Commanded fuel/air is cycled between rich and lean and drives both banks
      1. Bank-1 passenger side air leaking is causing both B1 sensors to show lean
      2. The leak is driving the test to fail – OSC time calculation not working because of leak
    1. Experiment
      1. Let’s clear the code to see if this repeats.
  13. Oct 30, 2017 at 10:02 AM
    #1253
    Voodoo Rufus
    Bakersfield, CA
    Just installed a catch can this past week for good measure, but my truck has never consumed any measurable amount of oil reading from the dipstick.
    Silicone stethoscope spray? Not sure I get it.
  14. Oct 30, 2017 at 10:08 AM
    #1254
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    :notsure: pretty sure this is a typo.
    Think he meant spray and then listen to see what happens.
  15. Oct 30, 2017 at 10:24 AM
    #1255
    Voodoo Rufus
    Bakersfield, CA
    A boost leak would be problematic. I do have some silicone spray so that's an easy check I hope.
  16. Oct 30, 2017 at 11:10 AM
    #1256
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Did the operational issues start after the catch can?
    Disconnect the catch can, to make sure that it isn't causing the leak, while attaching a hose in factory manner.
    Which brand is it?
    Does it have a breather on it? (Should be no breather.)
    I meant to type silicone HOSE stethoscope. (Just a long piece of hose with ear at one end and the other proding around the engine.)
  17. Oct 30, 2017 at 11:48 AM
    #1257
    Voodoo Rufus
    Bakersfield, CA
    Nope, added the catch can last week to eliminate the possibility of the carbon buildups being from oil. Problems going on for a couple months now. Primecooling baffled universal. It's sealed pretty well. No breather.
    Torspd likes this.
  18. Oct 30, 2017 at 1:43 PM
    #1258
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Cannot get the 5050695 belt the last 1” needed
  19. Oct 30, 2017 at 2:02 PM
    #1259
    jojotoo
    Brandon
    Socal
    2015 DCLB
    2.85 or 2.55 ?
    It was bit of a struggle for 2.55. needed an extra hand.
  20. Oct 30, 2017 at 2:05 PM
    #1260
    GT7
    Grant
    Phoenix
    2013 DCLB
    2.85!
    loginfailed likes this.
