UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Oct 30, 2017 at 2:55 PM
    #1261
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    When putting shorter belt on, the head of my ratchet was hitting the fan clutch so I couldn’t get the tensioner to move far enough.
    I took off the fan clutch nuts and just let it sit inside the shroud and that provided enough room for the ratchet to swing. Made the belt easy to put on vs. fighting with it.
  2. Oct 30, 2017 at 3:08 PM
    #1262
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    I believe I maxxed out how loose I can get the tensioner, fan clutch is a bitch but it doesnt prevent me from getting the tensioner all the way loose
  3. Oct 30, 2017 at 3:09 PM
    #1263
    GT7
    Grant
    Phoenix
    2013 DCLB
    Im going to try this though
    loginfailed[QUOTED] likes this.
  4. Oct 30, 2017 at 4:40 PM
    #1264
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Trust me, I tried to avoid taking it off. Messed around with the belt for 30 minutes with no joy.
    It took about 2 minutes to take the 4 nuts off the fan clutch. Once clutch was out of the way I had the belt on in like 2 minutes.
    I am living proof that it is possible to spend more time trying to skip a step than you would spend if you just do the step to begin with.
    Biscuits and nfs257 like this.
  5. Oct 30, 2017 at 4:41 PM
    #1265
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    did you go OEM or NAPA/Autozone??
    loginfailed likes this.
  6. Oct 30, 2017 at 4:41 PM
    #1266
    Skootter14
    Jeremy
    is there anything wrong with the plugs provided with the kit???
  7. Oct 30, 2017 at 4:47 PM
    #1267
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I used OEM. I’m sure the Victor Reinz stuff from the LAPS would work fine.
    Nothing wrong with them. Going colder is optional. If you’re going all out w/ upgrades, I’d do the colder plugs while you have it all apart. Sell the other ones new in the box and get some of your money back.
    Skootter14[QUOTED] likes this.
  8. Oct 30, 2017 at 5:29 PM
    #1268
    GT7
    Grant
    Phoenix
    2013 DCLB
    Ok so I got it on, the fan clutch made literally a 1/5 of an inch difference, practically nothing and me and my girlfriend went beastmode and got it on. Jesus h christ
    Pedal response is a bit nicer for sure but I dont think I picked up any power. So worth it though
    Also I found I sheared one of my front valve cover bolts some how :/
    Torspd likes this.
  9. Oct 30, 2017 at 8:32 PM
    #1269
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Cool, glad you were able to get it on there!
    GT7 likes this.
  10. Oct 30, 2017 at 11:22 PM
    #1270
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    NAPA Victor Reinz gaskets for me. They are working fine.
  11. Oct 31, 2017 at 8:44 PM
    #1271
    GT7
    Grant
    Phoenix
    2013 DCLB
    Since adding the smaller belt I am getting semi consistent bog down/buck when I increase throttle semi-rapidly or to as fast as possible
  12. Oct 31, 2017 at 9:12 PM
    #1272
    Roostfactor
    TX panhandle
    Try increasing throttle slowly until boost starts...then punch it and see if it still happens. I think the bypass valve is slamming shut creating boost so quickly the other sensors and ecu can't keep up. I know Scott told me that is a difficult hurtle to overcome with the TRD/Maggy s/c since it is a positive displacement s/c and there is very little air volume after the rotors. If you are just cruising (in vaccuum) and you whack the throttle, the bypass valve closes creating almost instant boost. The problem is how to control afr and timing for that crucial second or two until the maf/ecu/tps catch up.
    The last part is my speculation anyway. I wonder if the UCON can use a MAP sensor as an active input for fuel/timing control. It may be a better type of sensor to quickly react to boost changes.
    GT7[QUOTED] likes this.
  13. Nov 3, 2017 at 8:37 PM
    #1273
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    Lol .. vacuum leak. Found it ...
    Supercharger side of the hose connecting to bypass valve. It wasn't loose but was easily pulled. Clamp it down and saw my boost increase.
    Wonder if that could have caused my CELs.
    Time for another WOT data run ..
    loginfailed, nfs257, Billy182 and 2 others like this.
  14. Nov 3, 2017 at 9:52 PM
    #1274
    Chickadee
    Chickadee No, It's not my husband's truck.
    Tricia
    Colo Springs, CO
    2013 DCSB TRD OR, Spruce Mica
    OME lift, Relentless Bumpers, Supercharged, UCON
    Some of my parts started arriving today - spark plugs & valve cover gaskets. Hoping to see a shipping notice from URD soon!
    Any tips on choosing a new ECU on Ebay? I have the part number, just wondered if anyone has a method to pick a good clean one.
  15. Nov 3, 2017 at 10:22 PM
    #1275
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Heck yeah man! Glad that was an easy fix! What did your PSI jump up to?
  16. Nov 4, 2017 at 2:30 PM
    #1276
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I’ve ordered a couple ECUs. First one clean, second one water damage, sent back for refund, third one clean. I assume most people selling them aren’t trying to pull a fast one. The one I got that was water damaged, the seller was really easy to deal with, but I did have to pay return shipping. $10 expense the grand scheme of my Tacoma spending is literally nothing to stress over.
  17. Nov 4, 2017 at 3:37 PM
    #1277
    GT7
    Grant
    Phoenix
    2013 DCLB
    So I Have a Trd tuned ecu @loginfailed worthy investment? Send me your other clean one :D
  18. Nov 4, 2017 at 4:27 PM
    #1278
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    TRD ECU + no UCON = :thumbsup:
    TRD ECU + UCON = :facepalm:
    Stock ECU + UCON = :burnrubber:
    Skootter14 likes this.
  19. Nov 4, 2017 at 4:28 PM
    #1279
    GT7
    Grant
    Phoenix
    2013 DCLB
    Roger that, what did u pay?
  20. Nov 4, 2017 at 4:58 PM
    #1280
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    For my stock ECU? It was around $100 on eBay.
