UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Nov 4, 2017 at 5:11 PM
    #1281
    omgwtfbbq!
    omgwtfbbq! Well-known Idiot
    Ohio
    2013 X-Runner
    You guys who bought replacement ECUs, did you get the exact model you had before? Or is there some leeway. Finding an X-Runner ECU has been a bit of a pain.
    Hacktacular likes this.
  2. Nov 4, 2017 at 8:10 PM
    #1282
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I bought the same part number. I remember a couple other guys looking for x-runner ECUs and pretty much striking out.
    @Billy182
  3. Nov 5, 2017 at 9:10 AM
    #1283
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    Well, previously.. i only saw 6-7 psi when i left it in 3rd gear. Now im able to hit 9.5. Ive hit 11 when im shifting.
    My Max MAF increased to 336 g/s.. from 324.
    and.. UCON /Guardian feature kicked in. I had less than 1/4 tank when i ran the WOT data run. At the top of 3rd gear i lost power. When i looked at the data log i leaned out. Nice safety feature .. :)
    also, the vacuum leak might have been the culprit for the cels ive been battling, p0420/p0430. they have not yet returned...:fingerscrossed:
    My 6 injectors - 95% / 7th - 40% duty cycle .. might consider upgrading. hoping URD has a sale coming up soon.
    good looking out @Torspd .. always appreciate your input.
  4. Nov 5, 2017 at 9:19 AM
    #1284
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Wow! Your truck must really throw you in the seat now!
    With enough perseverance, we can over come any obstacle. :thumbsup:
    Which size injectors do you currently have? They are maxed out and need to move up in size for sure!
    loginfailed and jojotoo like this.
  5. Nov 5, 2017 at 1:06 PM
    #1285
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    My numbers are pretty much identical. Definitely considering an injector upgrade.
    So how about a URD Black Friday deal? ;)
    @Gadget@URD
    jojotoo[QUOTED] likes this.
  6. Nov 5, 2017 at 2:07 PM
    #1286
    Billy182
    Billy182 Well-Known Member
    Bill
    NJ
    X-Runner
    2013 X-Runner build thread: https://www.tacomaworld.com/threads/billy182s-2013-x-runner-build.829354/
    Yep, it was pretty much hopeless finding the ECU part number I needed on eBay for my x-runner. I ended up buying a new one
  7. Nov 5, 2017 at 3:24 PM
    #1287
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You guys will like this.
    Here you go.
    zerotimeouts and loginfailed like this.
  8. Nov 5, 2017 at 3:26 PM
    #1288
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  9. Nov 5, 2017 at 3:57 PM
    #1289
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Going to do this now. Didn’t know it was even there. :thumbsup:
    12TRDTacoma likes this.
  10. Nov 5, 2017 at 4:04 PM
    #1290
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The veil has been lifted.
    12TRDTacoma and loginfailed like this.
  11. Nov 5, 2017 at 4:12 PM
    #1291
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Going out to do it tonight
  12. Nov 5, 2017 at 4:28 PM
    #1292
    Billy182
    Bill
    NJ
    X-Runner
    I'll take a look at mine too, thanks for posting
  13. Nov 5, 2017 at 4:32 PM
    #1293
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Happy modding guys. ;)
  14. Nov 6, 2017 at 3:27 AM
    #1294
    Billy182
    Bill
    NJ
    X-Runner
    Just wondering about drivability, perhaps drilling out the brass pill would be a happy medium?
  15. Nov 6, 2017 at 4:30 AM
    #1295
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Pull it out. If you don't like the change, then put it back, or try drilling. Apparently though, other owners of the M90 have used Nos jets of various sizes. As an alternative to drilling.
  16. Nov 6, 2017 at 6:47 AM
    #1296
    Billy182
    Bill
    NJ
    X-Runner
    Thanks, I'll have to do some research online and see if I can find a place that sells different sizes.
    I actually just read a thread on a Fiero forum where the guy says he just leaves it disconnected. Not that I intend to do that, just interesting reading:
    http://www.fastfieros.com/tech/boost_solenoid_bypass_mod.htm
  17. Nov 6, 2017 at 7:51 AM
    #1297
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Totally going to check this line when I get home. My symptoms sure seem like a vacuum/boost leak.
  18. Nov 6, 2017 at 7:57 AM
    #1298
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah definitely not ideal. The last thing you want is to heatsoak even more because you are in constant boost at throttle applications. On top of that it will rob you of gas mileage.
    Billy182[QUOTED] and Torspd like this.
  19. Nov 6, 2017 at 8:13 AM
    #1299
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  20. Nov 6, 2017 at 8:32 AM
    #1300
    Billy182
    Bill
    NJ
    X-Runner
