UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Nov 13, 2017 at 6:32 AM
    #1361
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Yes it needs to be 12v I think or there could be issues. I didnt have a battery charger, so I hooked it up to another truck and let it run for 32 min and it worked
    jojotoo and loginfailed like this.
  2. Nov 13, 2017 at 6:45 AM
    #1362
    Chickadee
    Chickadee No, It's not my husband's truck.
    Tricia
    Colo Springs, CO
    2013 DCSB TRD OR, Spruce Mica
    OME lift, Relentless Bumpers, Supercharged, UCON
    Ignition on, or engine running?
    GT7[QUOTED] likes this.
  3. Nov 13, 2017 at 6:45 AM
    #1363
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Ignition On only.
  4. Nov 13, 2017 at 9:49 AM
    #1364
    oni06
    oni06 Well-Known Member
    Saw your updates in the other thread. So stoked your truck is running good now.
    GT7[QUOTED], loginfailed and jojotoo like this.
  5. Nov 13, 2017 at 10:55 AM
    #1365
    GT7
    Grant
    Phoenix
    2013 DCLB
    Dude. its amazing. Like it is so much fun. I loved it before but now its just beautiful
    12TRDTacoma and oni06[QUOTED] like this.
  6. Nov 13, 2017 at 12:42 PM
    #1366
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    What did you do to your truck exactly? Scott and I are going back and forth on my UCON configuration (stock ECM + UCON + S/C). Adding a wideband sensor to the UCON to aid in troubleshooting.
    loginfailed likes this.
  7. Nov 13, 2017 at 1:12 PM
    #1367
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    UCON EMS - eTuneLite and flash content?
    what is the ucon usb stick for?
    Have you managed to use USB stick by this way?
    I’d like to switch between couple of maps.
  8. Nov 13, 2017 at 3:22 PM
    #1368
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  9. Nov 13, 2017 at 3:27 PM
    #1369
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I have dual LC-2 widebands wired to the UCON expansion harness. So when I do logs I can compare what the WRAFs and widebands are reporting. Pretty neat.
    I’d like to also wire in my boost sensor and fuel pressure sensor. Scott said it’ll work but I need to find sensors with published transfer functions so we can tell UCON/uTune how to interpret the data.
  10. Nov 13, 2017 at 3:31 PM
    #1370
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That would open up more safety feature capabilities. For everyone.
  11. Nov 13, 2017 at 3:33 PM
    #1371
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I’m going to ask gadget if he has any leads on sensors to use with the UCON. I’d be surprised if he didn’t already have something figured out for that.
    UCON has a lot of add’l inputs that nobody uses. Seems like a waste to me.
    Roostfactor likes this.
  12. Nov 13, 2017 at 3:37 PM
    #1372
    GT7
    Grant
    Phoenix
    2013 DCLB
    Definitely interested in fuel pressure sensor after my last fiasco.
    Torspd likes this.
  13. Nov 18, 2017 at 2:01 PM
    #1373
    Chickadee
    Tricia
    Colo Springs, CO
    Starting my UCON install. Have the UCON attached to the new ECU & can't figure out what the USB extension cord is for - I see where to plug it into the UCON, but just don't know what to do with the other end.
  14. Nov 18, 2017 at 2:14 PM
    #1374
    GT7
    Grant
    Phoenix
    2013 DCLB
    Just leave it out. Its for data logs
    Chickadee[QUOTED] likes this.
  15. Nov 18, 2017 at 2:22 PM
    #1375
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Just wait til you get the rehauled valve body.
    You'll be like holy fook it is WAY TOO MUCH fun now!
  16. Nov 18, 2017 at 2:49 PM
    #1376
    Chickadee
    Tricia
    Colo Springs, CO
    Thanks.
    Also can't figure what plugs in here (center section)IMG_2796.jpg :
  17. Nov 18, 2017 at 2:52 PM
    #1377
    GT7
    Grant
    Phoenix
    2013 DCLB
    Ive never used them
  18. Nov 18, 2017 at 2:57 PM
    #1378
    Chickadee
    Tricia
    Colo Springs, CO
    Thanks. That was really stressing me out! LOL
    Tomorrow we tackle the rest of the project - too cold today. Hope it all goes smoothly.
  19. Nov 18, 2017 at 3:24 PM
    #1379
    GT7
    Grant
    Phoenix
    2013 DCLB
    Too cold? Cmon man
  20. Nov 18, 2017 at 3:43 PM
    #1380
    Chickadee
    Tricia
    Colo Springs, CO
    It snowed last night. High was in the low 40's. Truck won't fit in the garage with the door closed - too long.
    I'm a girl, I get to whine once in a while, right?
    JuanitoBonito and Torspd like this.
