UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Nov 20, 2017 at 5:11 PM
    #1401
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Hard pass
  2. Nov 20, 2017 at 5:12 PM
    #1402
    GT7
    Grant
    Phoenix
    2013 DCLB
    Gaurdian mode fuel cut, same thing was happening to me
  3. Nov 20, 2017 at 5:14 PM
    #1403
    oni06
    oni06 Well-Known Member
    Guardian was the first thing that popped into my mind.
    Just not sure why it kicked in :(
  4. Nov 20, 2017 at 5:15 PM
    #1404
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    Less than 1/4 tank ?
  5. Nov 20, 2017 at 5:16 PM
    #1405
    GT7
    Grant
    Phoenix
    2013 DCLB
    Mine was doing it because my fuel pressure was dropping.
    @Chickadee send it back. Get a 320 aem and then find your own external filter that you choose
  6. Nov 20, 2017 at 5:16 PM
    #1406
    oni06
    Nope. Just filled up the other day.
  7. Nov 20, 2017 at 5:19 PM
    #1407
    jojotoo
    Brandon
    Socal
    2015 DCLB
    “ Guardian is also designed to limit maximum engine RPM until fully warmed up “
    Could be ?
    loginfailed likes this.
  8. Nov 20, 2017 at 5:21 PM
    #1408
    oni06
    Could be. Usually it takes me a bit longer to get to the end of the Alley and make the two rights to get to the main street because of having to pull the truck out and move kids around into the right seats.
    This time I just got in the truck and went so very little time between leaving the garage and pulling out into traffic.
  9. Nov 20, 2017 at 5:35 PM
    #1409
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    My shop is on a freeway feeder and people drive 70mph on the feeder. Sometimes when I leave work, I put the pedal to the medal to get up to speed. Guardian has kicked in a few times due to ECT being too low. Surprised the heck out of me the first time it happened. :eek: But now I know to take it easy until its warmed up.
  10. Nov 20, 2017 at 5:52 PM
    #1410
    oni06
    Thanks guys. I feel better with this knowledge and that its not just me :D
  11. Nov 20, 2017 at 6:11 PM
    #1411
    Chickadee
    Chickadee No, It's not my husband's truck.
    Tricia
    Colo Springs, CO
    2013 DCSB TRD OR, Spruce Mica
    OME lift, Relentless Bumpers, Supercharged, UCON
    Haven't ordered it yet. Spent too much money on the truck for now...
    GT7[QUOTED] likes this.
  12. Nov 20, 2017 at 6:15 PM
    #1412
    GT7
    Grant
    Phoenix
    2013 DCLB
    Good
  13. Nov 21, 2017 at 5:19 AM
    #1413
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    How does it run?
  14. Nov 21, 2017 at 6:15 AM
    #1414
    Chickadee
    Tricia
    Colo Springs, CO
    Great so far. Just took it around the block a couple times for a 'victory lap'. I'll drive it to work today & see how it does.
    Torspd[QUOTED] and jojotoo like this.
  15. Nov 21, 2017 at 6:49 AM
    #1415
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Good to hear. Means everything went right. :thumbsup:
    Chickadee likes this.
  16. Nov 21, 2017 at 7:41 AM
    #1416
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Wideband results:
    Got it hooked up and took a little test drive. Interestingly it has about a half second lag between what it should be reading and what the gauge gives me.
    idle and cruise is stoichiometric (proper) at around 14.7.
    low vacuum, richens to the 12s.
    0 vacuum to low boost, 11
    max power, 10.5-11
    Considering I accelerate on a cold engine and cruise around town in the low vacuum region, it seems too rich to me (I'm no tuner, though). Even cold startup the truck is in the mid 14s for warmup. Max power at the 10.5 to 11 range seems excessive for an 8psi setup. My Subaru targets 11 for max power and it runs 20psi. Also runs 13s for AFR until about 3psi. I need to get this up to freeway speed and see what it does, but I suspect at 75mph it's richening.
    BTW, my exhaust blew out carbon chunks on startup.
    GT7 likes this.
  17. Nov 21, 2017 at 8:20 AM
    #1417
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Different engine. These need to be be a on the richer side.
  18. Nov 21, 2017 at 8:38 AM
    #1418
    Voodoo Rufus
    Bakersfield, CA
    Yeah I get that. Not a direct comparison.
    But is blowing carbon chunks and fouled spark plugs on a TRD blower setup normal?
  19. Nov 21, 2017 at 8:47 AM
    #1419
    GT7
    Grant
    Phoenix
    2013 DCLB
    I have a feeling that is a potential yes. My pipe is jet black has been since I put it on. My plugs were not totally fucked but they werent good.
  20. Nov 21, 2017 at 11:00 AM
    #1420
    omgwtfbbq!
    omgwtfbbq! Well-known Idiot
    Ohio
    2013 X-Runner
    14.7 is super rich for cruising, you don't need to be stoich when you're just chilling on the highway.
