UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Nov 21, 2017 at 11:10 AM
    #1421
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Mine has always been stoich at cruise.
  2. Nov 21, 2017 at 11:15 AM
    #1422
    omgwtfbbq!
    omgwtfbbq! Well-known Idiot
    Ohio
    2013 X-Runner
    I guess thats why tacos get such shit fuel economy lol. My S4 was around 18:1 at cruise.
  3. Nov 21, 2017 at 11:23 AM
    #1423
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    o_O:confused::crazy::facepalm:
    Torspd and GT7 like this.
  4. Nov 21, 2017 at 11:26 AM
    #1424
    omgwtfbbq!
    Ohio
    2013 X-Runner
    Lean is where it's at, thats why my diesel jetta got 40mpg at 80mph lol. Of course diesel is a whole other game.
  5. Nov 21, 2017 at 11:38 AM
    #1425
    FinnJ
    Finland
    Yes it is, gasoline engines (not lean burn engines) are meant to run at lambda 1 (14.7:1).
  6. Nov 21, 2017 at 11:50 AM
    #1426
    omgwtfbbq!
    Ohio
    2013 X-Runner
    At high load I agree, you want stoich or richer to be safe. If you're cruising lean is what most cars shoot for. Better for emissions, better fuel economy. Even my bike runs north of 16:1 when I'm just maintaining speed on the highway. As soon as you crack the throttle it richens up but 14:1 cruise is just wasting fuel on a modern engine.
    Roostfactor likes this.
  7. Nov 21, 2017 at 11:58 AM
    #1427
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Yeah, if you're catless maybe. 14.7 or a tad under is ideal for catalyst efficiency.
  8. Nov 22, 2017 at 6:27 AM
    #1428
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Try that on your 1GR. Tell us how that works out. :D
    Lucario Runner and WOODEX M.E. like this.
  9. Nov 22, 2017 at 6:36 AM
    #1429
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    I will make on offer on said engine if you do try it
    Torspd likes this.
  10. Nov 30, 2017 at 12:21 PM
    #1430
    Voodoo Rufus
    Bakersfield, CA
    More notes after observing the wideband behavior.
    You have to drive on a figurative egg shell to keep the system from enrichening. As soon as it hits 0psi the AFR dives to 12-13. It will stay there even if you use less throttle and go back to vacuum. You pretty much have to close the throttle to get it to go back to the 14s. It's not a smooth enrichment ramp, more like a dump valve on tip-in.
    Calling on full power the AFR will dive to 10.5, then wobble around 11.
  11. Nov 30, 2017 at 12:24 PM
    #1431
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  12. Nov 30, 2017 at 12:25 PM
    #1432
    Voodoo Rufus
    Bakersfield, CA
    2.85". Nothing crazy. I did do the fuel pressure reference to boost mod, though. It helped but did not solve my top gear roll on knock.
  13. Nov 30, 2017 at 12:26 PM
    #1433
    GT7
    Grant
    Phoenix
    2013 DCLB
    Gadget says not to do this with the ucon.
  14. Nov 30, 2017 at 12:27 PM
    #1434
    Voodoo Rufus
    Bakersfield, CA
    Interesting. I can try switching it back and see how it behaves.
  15. Nov 30, 2017 at 12:36 PM
    #1435
    GT7
    Grant
    Phoenix
    2013 DCLB
    loginfailed likes this.
  16. Nov 30, 2017 at 12:58 PM
    #1436
    Voodoo Rufus
    Bakersfield, CA
    Well then. Off the mod comes tonight!
  17. Dec 1, 2017 at 8:18 AM
    #1437
    Chickadee
    Chickadee No, It's not my husband's truck.
    Tricia
    Colo Springs, CO
    2013 DCSB TRD OR, Spruce Mica
    OME lift, Relentless Bumpers, Supercharged, UCON
    Mine dives to 12-13 under moderate throttle, 10-10.5 with heavy throttle. Goes rapidly back to 14s when I stop accelerating & just maintain speed, even at 85mph.
  18. Dec 1, 2017 at 10:25 AM
    #1438
    Voodoo Rufus
    Bakersfield, CA
    Going to swap back the FPR mod, and maybe give it a good run this weekend.
    Starting to wonder if my 4 mile commute and the rich-happy tune has been the downfall of my plugs and cylinders. Might need a good freeway run and "italian tune up" to blow the carbon out periodically.
    Roostfactor and loginfailed like this.
  19. Dec 1, 2017 at 3:45 PM
    #1439
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Mine gets the Italian tuneup daily! :D
  20. Dec 4, 2017 at 10:16 AM
    #1440
    Voodoo Rufus
    Bakersfield, CA
    Gave it a good run this weekend. 16mpg average. Max boost AFR is 10.5. Tip-in AFRs 12-13. It doesn't like to return to the 14s until vacuum exceeds -5 inHg. No wonder it guzzles fuel on slight inclines in top gear. I have to proactively downshift it on a hill. If say going over an overpass and it boosts up and stays rich, a click down on the cruise will get it to go back to stoich. Then back up to get the speed back. If the system does go back on it's own from rich to stoich, there's a momentary loss of power. I've noticed it before, but now I see it does it on the AFR change, not just out of the blue.
    Seems like it's doing what it's programmed to do. I guess you could call it "performance oriented", but for daily use trying to maximize mileage it is not ideal, yet. It's interesting to learn how this thing behaves and operates.
    jojotoo likes this.
