UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Dec 7, 2017 at 8:02 PM
    #1461
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I noticed Haltech just came out with elite 2000. Curious the main differences between it and the 2500
    loginfailed likes this.
  2. Dec 7, 2017 at 8:26 PM
    #1462
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Torspd likes this.
  3. Dec 8, 2017 at 5:52 AM
    #1463
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    2500 is more suited for these trucks' needs.
    Plus between myself, and @Hacktacular , we can get you up and running with little down time.
    Individual cylinder adjustments for fuel and ignition, long term learning for fuel, ignition, and a few other functions. Safety protocols for every sensor you have, which has varrying degrees of severity, followed by an OBD CEL #. Intake cam adjustability for more POWA.
    It works alright. ;)
  4. Jan 10, 2018 at 6:41 AM
    #1464
    Chickadee
    Chickadee No, It's not my husband's truck.
    Tricia
    Colo Springs, CO
    2013 DCSB TRD OR, Spruce Mica
    OME lift, Relentless Bumpers, Supercharged, UCON
    Looking to get a better gauge to monitor my engine & also help me trouble shoot a misfire problem. Since the UCON install my BD has lots of trouble maintaining a connection & the numbers are often frozen. Will I have this issue with any of the OBD scanners? Has anyone used the Ultragauge or the Scangauge with the UCON?
  5. Jan 10, 2018 at 7:07 AM
    #1465
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Yes the UCON intermittently interrupts OBD2 communication. I’ve got 3 different tools and they all have intermittent connection interruptions.
  6. Jan 10, 2018 at 11:19 AM
    #1466
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    I have the Scangauge. No problems with the UCON. Some values (eg. AFR and ignition timing) are not accurate with the UCON connected.
  7. Jan 10, 2018 at 1:15 PM
    #1467
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Like @FinnJ said, some of the values will be wrong becuase of the UCON sending unicorns and rainbows to the ECM.
    The intermittent connectivity problems are more of a traffic issue. Too many PIDs being read at one time.
    A generic reader like scan gauge or ultra gauge should work ok because they don’t read very many PIDs at once.
  8. Jan 10, 2018 at 6:21 PM
    #1468
    Chickadee
    Tricia
    Colo Springs, CO
    Will the scan gauge give you pending codes? How about misfire counts for each cylinder?
  9. Jan 10, 2018 at 6:54 PM
    #1469
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    You can view pending codes and clear when they set. Will not detect misfires.
    I have a scan gauge and purchased a scanner for all other needs. With the scanner I’m able to view live data stream and freeze frame data.
    inwood customs likes this.
  10. Apr 15, 2018 at 12:36 PM
    #1470
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Just in case anyone from this thread is interested. I am selling my 7th injector with ucon expansion harness for $550 shipped
    Roostfactor and inwood customs like this.
  11. Apr 30, 2018 at 10:23 AM
    #1471
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Pretty sure I am going to jump on the Ucon ship here very soon. With my AFR numbers (low 8's) I don't really see any other option. I want to keep it "simple" being in Idaho, I have no tuning help or references around me.
    jojotoo and Roostfactor like this.
  12. Apr 30, 2018 at 10:24 AM
    #1472
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    or ovtune is an available option too
  13. Apr 30, 2018 at 2:27 PM
    #1473
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Considering I have yet to have anyone from Orange Virus Tuning contact me about a tune for my bosses 2017 Tacoma with 4 emails sent to him about it, I am not sure that is really a option. I know he is a busy guy, but I think I scared him when I mentioned that I work for a dealership or that he is just to busy to worry about the Tacoma when he has all the Lexus money being thrown at him. And Bully Dog is here in town, but I don't to hear stories about what they put my truck through when they had it to build the tune. We have supplied trucks for many of Bully Dog's products and lets just say that the stories are entertaining, but not if it is your vehicle. As one of them my bosses 2013 s/c Tundra that we got back with a blown motor and many stories of it doing 4 wheel drive burnouts. And the tune for the 2012-2015 s/c tacoma came off of a buddies truck that just never ran the same after words and traded that in. And there is Uni-Chip, but not sure that really is a option either as every time we have used them it has required lots and lots of attempts to get it right and he told me straight up that I would need a custom tune and need to come see him if I really wanted my truck to run right. But Gadget, he is one I do trust as I have done business with him for many many years.I actually met him through getting involved with another shop that was trying to take advantage of the both of us before URD ever existed. So the Ucon seems to really be my only choice, but a good one, just expensive at the moment.
  14. Apr 30, 2018 at 2:40 PM
    #1474
    jojotoo
    Brandon
    Socal
    2015 DCLB
    I would go with OVTUNE if I can get a bench tune vs handheld.
  15. May 1, 2018 at 1:59 AM
    #1475
    FinnJ
    Finland
    Why my AFR is gone down to 9.5 (WOT) instead of 11.7 before? It’s way too rich now, I have noticed a power loss too. No OBD codes.
    Setup:
    • UCON
    • 2.85” pulley
    • Spec-U headers
    • DeatschWerks DW200 fuel pump
  16. May 1, 2018 at 5:14 AM
    #1476
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I imagine that you are not boost referencing the FPR, correct?
    Power loss is directly related to that AFR.
    Have you tried disconnecting the battery for a few minutes?
  17. May 1, 2018 at 7:54 AM
    #1477
    FinnJ
    Finland
    Yes, it’s stock, no referencing.
    Yes, I can feel it.
    No. Maybe I could try. It was disconnected few weeks ago and the problem is developed after that.
  18. May 1, 2018 at 8:11 AM
    #1478
    TRON
    Your ucon is stuck in engine guardian mode
  19. May 1, 2018 at 9:54 AM
    #1479
    FinnJ
    Finland
    What do you mean? It works ok, AFR close to 14.7 at constant speed, but when boosted it’s too rich.
  20. May 1, 2018 at 10:20 AM
    #1480
    TRON
    Case in point. There is a mode the ucon kicks into when the fuel is not being delivered properly at boost or WOT. It’s call engine guardian or something like that. This mode is suppose to flood the injectors to protect the engine. It’s probably just the ucon acting up and should be a simple fix from Scott. When’s the last time you changed your fuel filter?
