UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Oct 6, 2018 at 10:39 PM
    #1541
    N/Es06
    N/Es06 Well-Known Member
    06 icons inchworm rotrex
    I've read on here that ucons dont work right with a flashed ecu. I don't know that it has been just an idea.
  2. Oct 7, 2018 at 8:23 AM
    #1542
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    You probably knew this already, but I’ll repeat it in case anyone else doesn’t know.
    Any time that uTune is “in focus” on the laptop, the space bar becomes a shortcut to initiate a log. This makes it a little safer and easier when youre trying to drive and you want to log something. Gives you a bigger target.
    Possible it wasn’t replaced. Could be that he ran a TRD flash initially. Which is what I did. And then later bought the UCON.
  3. Oct 7, 2018 at 9:34 AM
    #1543
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That has been found mostly true. Quite a few people have swapped out theirs for factory tuned ECU's.
    loginfailed likes this.
  4. Oct 7, 2018 at 11:06 AM
    #1544
    N/Es06
    Is there an easy way to find out that it's been flashed?
    What do you guys think of the discoveries via Ultragauge with ucon vs without?
    I can put it back in and do a datalog to make everyone happy. But at this point we see that the ucon is either causing bank two to run rich or its not telling bank two anything hence bank2 runs rich. Without the ucon installed Everything is rich with it installed bank one operates propper but bank 2 remains rich.
    [QUOTE
    Yesir. The spacebar triggers the sample option. A "datalog" is another word for what Scott calles a sample file.
    ="loginfailed,
    BassAckwards likes this.
  5. Oct 7, 2018 at 12:18 PM
    #1545
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Six of one or half a dozen of the other.
    BassAckwards and Torspd like this.
  6. Oct 8, 2018 at 2:36 PM
    #1546
    N/Es06
    I dont know how to show yall this. But here you go. Right at 50% of the sample it tripped the cel. throwing p0300, 302 & 304. Yesterday after plugging the ucon back in i couldn't get it to trip I only got a pending p0175. Sorry for the delay.
  7. Oct 8, 2018 at 3:05 PM
    #1547
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Sending you a PM.
    N/Es06 likes this.
  8. Oct 8, 2018 at 3:40 PM
    #1548
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    So the highest RPM reached in the log was 1427. When does the misfire happen, only at low RPM? Pedal position at that point is 0.5% was the throttle being press at all? 1427 seems like a pretty high RPM for less than 1% throttle pedal position.
    At which column in the log did the misfires occur? If you look at the Can1 tab, P0300, P0302 and P0304 are there for the entire log. I thought you actually captured it happening, but the codes were set before this log was initiated.
  9. Oct 8, 2018 at 5:35 PM
    #1549
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    I got a whole new one for you guys. Just checking to see if this is common or if this happens to possibly be something because the Ucon is mated to a TRD flashed ECU. If I drive the truck hard and use the throttle for what I like to do with it, the truck runs great. But if I slow down and try to get some sort of decent mpg and just drive normally, it feels like the truck is falling on its face right after it shifts into 2nd gear. It will eventially get past that feeling and get going and then go to 3rd and so on. But 2nd gear just feels gutless and it has no power. even if I give it a bit more throttle it just does what it wants to do on its own until it gets past the blah point. No check engine light, no nothing. Hoping this is just part of what the Ucon does while it is learning that I am now driving without at least half throttle all the time. But could it be a TRD flash Ucon fight? The transmission acting up?
  10. Oct 8, 2018 at 7:10 PM
    #1550
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Mine responded similarly when my intercooler pump went out. Might check that just cause.
  11. Oct 8, 2018 at 7:11 PM
    #1551
    N/Es06
    The cel bagan to flash at 50% of the sample recording. I was holding the throttle just under 1500rpm because that is where it trips the cel at idle conditions. During driving conditions it happens when taking off from a stop or shifting to second while driving gently. If i rev up and take off or am at wot she screems but still shows rich bank two. Down to -30 lng/tm trm give or take. I dont understand the utune enough to tell you precisely. But i was sure to clear visible codes first.
  12. Oct 8, 2018 at 7:16 PM
    #1552
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    I didn’t think there would be any real engine issues if the intercooler pump went out, since all it does is help cooler air get cycled in the engine. I thought these S/Cs could technically run without the pump, you just won’t get the colder air benefits.....am I wrong?
    mr.trd likes this.
  13. Oct 8, 2018 at 7:17 PM
    #1553
    N/Es06
    Intercooler pump?
  14. Oct 8, 2018 at 7:19 PM
    #1554
    Skootter14
    Jeremy
    Coolant pump???
  15. Oct 8, 2018 at 7:22 PM
    #1555
    N/Es06
    Supercharger "oil" cooler? Between intercooler and radiator?
  16. Oct 8, 2018 at 7:42 PM
    #1556
    DocME
    California
    '07 FJ Cruiser
    I’ve got an engine on the stand that begs to differ with you. I had an intercooler pump fail (the pump that circulates coolant between the low temp radiator, and the actual intercooler radiator in the supercharger’s plenum).
    I had some very light engine pinging that I was trying to track down. No check engine lights whatsoever. If the engine wasn’t under load, it was sluggish to respond to throttle input. If I got on it a little bit, the engine seemed more responsive. Higher intake charge temps are the enemy. To check the pump, simply remove the reservoir lid while the truck is on. You should see fluid circulating. If it is stagnant, you lost your pump.
  17. Oct 8, 2018 at 7:45 PM
    #1557
    N/Es06
    Trd supercharger?
  18. Oct 8, 2018 at 7:46 PM
    #1558
    DocME
    California
    '07 FJ Cruiser
  19. Oct 8, 2018 at 7:47 PM
    #1559
    N/Es06
    Oh sorry bro. Never messed with one.
  20. Oct 8, 2018 at 7:52 PM
    #1560
    DocME
    California
    '07 FJ Cruiser
    Probably for the best. If I wasn’t in California, I would have the URD set up for sure. Someone once described the TRD Supercharger as the Poverty Charger. Seems like you have to spend a fortune to get the performance numbers that a Rotrex system starts at.
