UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Oct 8, 2018 at 7:55 PM
    #1561
    N/Es06
    N/Es06 Well-Known Member
    06 icons inchworm rotrex
    Well, do it all yourself and buy new. My only cents.
  2. Oct 8, 2018 at 11:06 PM
    #1562
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Such is life when you're dealing with an older design non-TVS blower.
  3. Oct 8, 2018 at 11:37 PM
    #1563
    N/Es06
    Ok I see now. So I did a total of 5 samples earlier. 2 of the 5 show the missfires all the way and the other 3 are all zeros.
  4. Oct 9, 2018 at 7:19 AM
    #1564
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    I will check the pump for sure. Thank you. The only reason I was thinking it was Ucon related is because as soon as I installed the Ucon is when I noticed it. So just always figured it was the learning of the it. But it is still there if I change my driving style. And I can't drive normal long enough to see if it goes away after a bit. Also thought I should ask in case someone knew that it was the Ucon guardian kicking in. If so, I need to see why it is kicking in.
  5. Oct 9, 2018 at 10:52 AM
    #1565
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    I missed that the Ucon was a new addition....you logic sounds right. I'd reach out to Gadet and get that looked at.
    I think my pump failure experience has me always thinking about it first. Starting to sound like Bob Barker reminding you to spay/neuter your pets or your news channel reminding you it's time for a buddy check. I'm just hear to spread awareness!
    mr.trd and N/Es06 like this.
  6. Oct 9, 2018 at 5:54 PM
    #1566
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    One reason I love the TRD reflash so much. No codes :thumbsup: How is the haltech 2500 working out @Torspd
    Biscuits and Roostfactor like this.
  7. Oct 9, 2018 at 7:05 PM
    #1567
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Brilliantly. Love it, and no turning back. Can even tune the VVT-I better than factory .
    Biscuits, TRON and Roostfactor like this.
  8. Oct 10, 2018 at 10:52 AM
    #1568
    Speedwaytacotuesday
    Speedwaytacotuesday I love riding in my wife's Taco :p
    Calgary, Alberta
    2016 TACO LTD, 88 4runner, 4th Gen 4Runner
    TRD S/C 2.3" pulley mild ported Portmatched/cleaned intake runner Ucon EMS/cam gears/160 t-stat 840cc injectors 255 LPH walbro fuel pump Urd equal length headers Urd competition y-pipe AFE 3” Exhaust Vibrant resonator Oil Catch can Ratio-tek valvebody upgrade 3" bilstein/OME lift Dakar rear 7-leaf pack 32" KO2's load range C Stealth custom wheels Ray-10's Volk Te37X’s Tundra front 13.3” brakes Custom fab rock sliders LC-2 wideband autometer boost gauge Cravenspeed gauge pod mount Scangauge 2 SC MODS: Pulley ripp mod/belt wrap mod/ fleetrunner belt/ tensioner stop delete mod/ bypass jet delete mod
    9ED7A77E-656D-429C-8925-3C70F8DB83EA.jpg AACA502B-3886-46C4-88FF-47730426F640.jpg Just wanted to report back after a couple runs datalogging. Truck has started to lean out a few points after a bit of learning and looking at the graph AFR commands are pretty much like @Roostfactor as per air load and Maf(g/s). Notice at 177.8 load my Afr command is 11.22
    I think Scott either mistyped the 10.2 at 150 air load or was prolly still drunk that morning when he answered my email, that's all.:proposetoast:
    Something to note at about 340ish g/s my Max IDC on 840cc injectors are at 62 percent capacity. Still plenty of headroom left.
    347 g/s was the highest I've seen that evening within a few runs. Looks like at nearly 4000 feet I'm only equal to or under most running the 2.55" pulley. Will see again once the 76mm throttle gets install along with a more aggressive porting.
    Roostfactor and jojotoo like this.
  9. Oct 10, 2018 at 11:11 AM
    #1569
    Speedwaytacotuesday
    Calgary, Alberta
    When you have a rotrex and it goes, yes poverty is the proper word to use. In my case I had a C38-91. I opted not to spend 4k CDN to replace it, I then decided not to even rebuild it. There were two companies that were known to rebuild rotrexs', although it is not recommended by Rotrex themselves due to the tight tolerances, they claim it will fail in a short period of time. With that in mind, I decided to try something different. Ended up buying a TRD system used locally and sold the rotrex kit. Sold it with my old indestructible c30-94 that I over spun about 10-15 percent using a 70mm pulley for 4 years. the last 1000-1300 RPM is where the rotrex really shines over my current TRD setup.
    Roostfactor likes this.
  10. Oct 10, 2018 at 11:31 AM
    #1570
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Why do you have to be talking smack about my truck?
  11. Oct 10, 2018 at 11:38 AM
    #1571
    DocME
    California
    '07 FJ Cruiser
    Haha, technically talking smack about most all of our trucks!
    If you're on this thread, it's too late. You've got a hole in your wallet.
  12. Oct 10, 2018 at 11:42 AM
    #1572
    Biscuits
    Ha! That I know, but F/I is more rewarding than hookers and blow.
    I saw those words "Poverty Charger" and lightheartedly took it to mean you were calling out my truck (check my vehicle descriptions). :p
  13. Oct 10, 2018 at 4:12 PM
    #1573
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I think you are higher than most considering your elevation. Hard to tell though because of the temperature advantage you currently have.
  14. Oct 10, 2018 at 5:56 PM
    #1574
    TRON
    I’ve noticed in higher elevation that Barometer pressure has a huge impact regardless of temperature for FI. Just sayin
    I need to look back at my ucon data logs and see my MAF g/s
  15. Oct 10, 2018 at 6:38 PM
    #1575
    Speedwaytacotuesday
    Calgary, Alberta
    In the midst of winter, the truck feels like a rocket ship, with all 4 wheels spinning, drifting sideways from light to light, like it's propelled by a set of jet engines. I am not sure if it's the -30 degrees Celsius temps causing huge power gains or if it's the illusion of it due to lack of traction in this winter wonderland I call home. When summer comes around its slow as balls again.
    mr.trd, Biscuits and N/Es06 like this.
  16. Oct 10, 2018 at 6:41 PM
    #1576
    Roostfactor
    TX panhandle
    Maybe a bit of both but today it was 60°F and the truck was sooo responsive. It almost felt like it was supercharged or something. :D:D:D
  17. Oct 25, 2018 at 12:53 PM
    #1577
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    How long (in miles) is everyone in here with the TRD/Maggy S/C letting the UCON relearn everything after resetting the battery for more than 3mins (IE resetting the UCON)? Scott had mentioned I need to drive normally for at least 50 miles to let it learn everything before romping on it. I drove mine for about 100miles the other day before getting on it and it still is stuttering in 3rd gear at 3k rpms at WOT (guardian is kicking in from it running lean).
  18. Oct 26, 2018 at 7:42 PM
    #1578
    5thGearPinned
    5thGearPinned Light Speed
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    As soon as it was installed, we romped full throttle to 90 within the first mile, I guess mine figured it out ok, lol.
    Torspd, BassAckwards and Roostfactor like this.
  19. Oct 29, 2018 at 8:53 AM
    #1579
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Advanced learner. ;)
  20. Oct 29, 2018 at 3:34 PM
    #1580
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Yep, been working it hard since the day the Ucon was put it. Made a world of difference in how smooth and responsive the truck was.
    BassAckwards and oni06 like this.
