UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Jun 30, 2017 at 4:49 PM
    #141
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
  2. Jun 30, 2017 at 6:57 PM
    #142
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    This guy doesn't sloth around. :thumbsup:
    Roostfactor[QUOTED] likes this.
  3. Jun 30, 2017 at 10:50 PM
    #143
    Roostfactor
    TX panhandle
    Got that right Tor!
  4. Jun 30, 2017 at 11:20 PM
    #144
    PupuleUlua
    PupuleUlua Well-Known Member
    Rod
    Honolulu
    2011 MGM TRD Sport DCSB 4x4
    You won't be disappointed:thumbsup:
  5. Jul 1, 2017 at 12:01 AM
    #145
    Roostfactor
    TX panhandle
  6. Jul 1, 2017 at 4:31 AM
    #146
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I ordered mine on the 16th. Haven't seen a tracking number yet. I'm not in a rush really, since I won't have time to install it until the week of the 10th.
  7. Jul 1, 2017 at 8:36 AM
    #147
    Roostfactor
    TX panhandle
    I ordered mine on the 8th and just got it a few days ago.
    loginfailed likes this.
  8. Jul 1, 2017 at 8:38 AM
    #148
    Roostfactor
    TX panhandle
    Also exhaust cam gears. They must be installed before running the UCON
  9. Jul 1, 2017 at 4:24 PM
    #149
    gersus
    gersus Well-Known Member
    Missouri
    14 Tacoma DCOR
    Lil lift, bumpers, SC, UCON, headers, etc.
    I tried to start the process of installing the ucon by uninstalling the bd but the bd said it was already uninstalled :ballchain::frusty: I dont see how it could be uninstalled so I'm done for today. :annoyed:
    Torspd likes this.
  10. Jul 1, 2017 at 4:26 PM
    #150
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
    BD strikes again.
  11. Jul 1, 2017 at 4:28 PM
    #151
    gersus
    Missouri
    14 Tacoma DCOR
    For real.
  12. Jul 1, 2017 at 5:27 PM
    #152
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    @gersus You know I've already been through that.
  13. Jul 1, 2017 at 5:27 PM
    #153
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Ebay ECU
    Mongoose cable
    48hr Techstream sub
    Done.
  14. Jul 1, 2017 at 5:34 PM
    #154
    gersus
    Missouri
    14 Tacoma DCOR
    @loginfailed supposed to be able to uninstall it enough for the ucon to function. Gadget says its been done.
  15. Jul 1, 2017 at 5:44 PM
    #155
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If it is unistalled, then why not just try installing the UCON. It doesn't change any coding.
    Maybe the BD was never actually installed......
  16. Jul 1, 2017 at 5:53 PM
    #156
    gersus
    Missouri
    14 Tacoma DCOR
    It was definitely installed. I've tried 4 different tunes and all were different. The tune that is installed now "works" but a far cry from great. Its not running lean though so I dont see how it could be uninstalled.
    I'm thinking about trying to install a tune then uninstalling again to see what happens.
    I was afraid the bd tune would mess up the ucon?
  17. Jul 1, 2017 at 6:04 PM
    #157
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    UCON overrides the OEM ecu. However. If it is expecting to see certain variables, but those are skewed, then its adaptive outputs of said variables will be skewed as well.
    Try what you plan first.
    loginfailed and gersus like this.
  18. Jul 1, 2017 at 6:50 PM
    #158
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Anyone interested in purchasing a gently used Bully Dog tuner? They're great for running a Magnuson charger.
    Haha
    :rofl:
    nudavinci64 likes this.
  19. Jul 1, 2017 at 6:55 PM
    #159
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Only been dropped once. ;)
  20. Jul 1, 2017 at 7:04 PM
    #160
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Then kicked, stomped on and smashed to pieces.
    :D
    Still works great, though!
    Torspd[QUOTED] and gersus like this.
