UCON Flex Advanced Engine Management System
Discussion in 'Performance and Tuning' started by gray223, Jul 5, 2014.
  1. Nov 3, 2018 at 7:33 PM
    #1581
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    So are all the bugs worked out finally? Or people still having issues?
    BassAckwards and loginfailed like this.
  2. Nov 3, 2018 at 7:38 PM
    #1582
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Some have issues still. Mine seems pretty solid.
    BassAckwards likes this.
  3. Nov 4, 2018 at 8:51 AM
    #1583
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Some occasional random check engine lights, but they always go away. It works well enough.
  4. Nov 4, 2018 at 8:58 AM
    #1584
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Im still having issues unfortunately. Hope to have them ironed out eventually. If im unable to figure them out, ill be going to the trd tune
  5. Nov 4, 2018 at 10:07 AM
    #1585
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Pretty much how mine is.
  6. Nov 5, 2018 at 5:47 PM
    #1586
    5thGearPinned
    5thGearPinned Light Speed
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    I’m one of the lucky ones I guess. Roostfactor and I installed mine two or three months ago and I have not had one check engine light. Knocking on wood! I have all the possible mods except the 7th injector, however that is on my bench still in the URD box waiting to be installed. I did what Loginfailed did and took my TRD flashed ecu out and put in a stock ecu at the same time the UCON went in. I think that is the main reason I’ve been good. Truck runs hard and pulls all the way through.
    loginfailed, jojotoo, DocME and 2 others like this.
  7. Nov 5, 2018 at 6:08 PM
    #1587
    Roostfactor
    TX panhandle
    When did you get the 7th?
  8. Nov 6, 2018 at 4:40 AM
    #1588
    5thGearPinned
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    About six or seven weeks ago, it’s collecting dust. I want it mainly for reliability, I just need to figure out when to do it. Also I wanted to run all ten plus mods you and I did at the same time to make sure everything is cool before adding anything else. I’m more excited about my Borla muffler experiment. I need to get up there so we can play again, which is too much fun.
    BassAckwards and Roostfactor like this.
  9. Nov 6, 2018 at 4:44 AM
    #1589
    Roostfactor
    TX panhandle
    Cool! There will be a significant amount of metal that needs to be removed from the injector adapter.
    I'm curious how the Borla will sound as well.
    Good times.
  10. Nov 7, 2018 at 11:23 AM
    #1590
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    @5thGearPinned whats the Borla experiment? I have one on my Taco as well.
  11. Nov 7, 2018 at 11:45 AM
    #1591
    Roostfactor
    TX panhandle
  12. Nov 7, 2018 at 11:47 AM
    #1592
    BassAckwards
    Please post up some sound clips when yall finish that up! Definitely interested in how it's gonna sound!
    5thGearPinned likes this.
  13. Nov 7, 2018 at 11:49 AM
    #1593
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    lol. thats pretty much EXACTLY what I have. I pulled my Vibrant.. and switched to the Borla and Magnaflow.. all 3".
  14. Nov 7, 2018 at 11:51 AM
    #1594
    Roostfactor
    TX panhandle
    Is your Magnaflow the one that splits into two pipes inside the back to one prior to exit?
    How does it sound?
    Nice and quiet?
  15. Nov 7, 2018 at 11:59 AM
    #1595
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    ahh no. Mine is single center/single center.
    its great. I spent a ton of time dialing in my exhaust. I've gone through so many setups over the years. this is by far the best I've found. no rasp, smooth, quiet, no drone in cab. My Blower is louder than anything else.
    I'll see if I can find some clips.. or make one.
    Its: URD equal lengths > 2.25 high clearance Y pipe with cats > 3" piping with Borla and Magnaflow > dumped over the axle/down
  16. Nov 7, 2018 at 12:02 PM
    #1596
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I may give this a whirl as well. Do you remember which Borla part number you used?
  17. Nov 7, 2018 at 12:07 PM
    #1597
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I'll poke around in my build for the info. it was a few years ago. I had the Vibrant resonator.. and it still had some rasp to it.. the Borla muffler got rid of all that.
    5thGearPinned and Roostfactor like this.
  18. Nov 7, 2018 at 12:10 PM
    #1598
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  19. Nov 7, 2018 at 12:15 PM
    #1599
    Roostfactor
    TX panhandle
  20. Nov 7, 2018 at 12:18 PM
    #1600
    Roostfactor
    TX panhandle
    So did you start with the URD Spec-U system? If so the muffler that came with it is the 12579 Magnaflow. It splits into two pipes internally but is still a single 3" in and single 3" out.
