UHMW tape between leaf springs??
Discussion in 'Suspension' started by TrueNorth, Jun 15, 2014.
  1. Jun 15, 2014 at 1:43 AM
    TrueNorth
    TrueNorth [OP] Well-Known Member
    Maryland
    13' V6 4X4 DCSB
    Weather tech floormats and visors, ImMrYo rear-view mirror bracket Cooper ST Maxx 255/85/16 On stock TRD alloys. OME 887's w/NitroCharger sports, LR uca's, Toytech sway bar relocate, Dakar leaf's modified with some 1/8" UHMW liner strips. SuperBumps front and back.
  2. Jun 15, 2014 at 8:07 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I used EPDM , but this looks interesting too
  3. Jun 15, 2014 at 10:37 AM
    TrueNorth
    Maryland
    13' V6 4X4 DCSB
    I saw that. I might still go that route, but I came across this. My Dakar's just arrived and while they are still clean and on the work bench I am weighing all options.
    It looks like people have been fully lining leafs with this stuff, but I I haven't been able to find find any long term results. My concern is grit imbedding into the material.
  4. Jun 15, 2014 at 11:41 AM
    TrueNorth
    Maryland
    13' V6 4X4 DCSB
    Some results here. http://forums.roversnorth.com/showthread.php?11383-How-much-UHMW
    It looks like thicker is better. Hmm, who knew?
    http://www.eatonsprings.com/techquestions/leaflinereffectonspringrate.htm
    Copied from above:
    "Full length spring liners are available in two designs.
    The first being a simple flat strip and the other channeled with lips going up and down, sort of like an "I" beam. The lips help keep the liner from slipping out.
    Installing full length liners does increase the spring pack thickness.
    Based upon the width of the liner, the thickness varies from .03 to .06 Inches thick. So the overall spring thickness does increase based upon how many full length liners are installed. But the use of liners has no effect on the spring rate.
    Spring rate is a result of the width of the spring, the thickness of the steel, the number of leaves and how the ends are finished.
    But the use of liners does have an effect on how the spring performs. Due to interleaf friction all multi-leaf springs suffer what is known as "hysteresis".
    That is, it takes more force to start the spring to deflect than it does to keep it deflecting.
    The use of either full length liners or tip inserts greatly reduce interleaf friction which in turn reduces hysteresis. This keeps the working spring rate close to it's actual rate.
    Keep in mind, that in order for a liner to be effective the liner must be as wide as the spring.
    While spring liners help in a spring's performance, the liner has absolutely no strength. Even though a liner is used in a spring, the spring still requires all of it's leaves."
    Looks like there's a material called Derlin that's similar also.
  5. Jun 15, 2014 at 1:09 PM
    OZ-T
    Peter North
    British Columbia
    Delrin
    Cool info
  6. Jun 15, 2014 at 1:17 PM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Sub'd for future insight and experiences
  7. Jun 15, 2014 at 4:13 PM
    TrueNorth
    Maryland
    13' V6 4X4 DCSB
    Yes Delrin. I'm lysdectic sometimes. Derlin sounds like a something I'd say after a couple beers. To wife: "while you your up, could you bring me a beer derlin'."
    This seems to be the place to buy sheets and strips of the stuff.
    http://www.mcmaster.com/#uhmw-polyethylene-sheets/=sf9mno
    The abrasion resistant stuff :eek: nice!
    It seems like a thicker piece 1/8 or 1/4 would hold itself in the pack with the clips and be thick enough not to deform. It seems like the bad results that others have had with the tape's durability were using 1/32"(30mil) and maybe the 1/16"(60mil)
    Baja style bumper and skids with uhmw-pe? I like the visual I get from that. Not my dd style though.
  8. Jun 15, 2014 at 4:19 PM
    OZ-T
    Peter North
    British Columbia
    So , without adhesive , you would just run full length strips with a hole for the centre pin ?
    1/8" per leaf is going to add up , especially with Dakars / 7 leaf
  9. Jun 15, 2014 at 4:44 PM
    TrueNorth
    Maryland
    13' V6 4X4 DCSB
    Contemplating it with the full strip through the center pin. I was just thinking about doing the leaves that do not have isolators already installed. Maybe the top 3. My thinking is those are the ones that are engaged most frequently and seems to be where you found that the dak's were squalking.
  10. Jun 15, 2014 at 4:47 PM
    OZ-T
    Peter North
    British Columbia
    Interested to see how it works for you
  11. Jun 15, 2014 at 4:59 PM
    TrueNorth
    Maryland
    13' V6 4X4 DCSB
    I think I'm going to try it, the packs are still off and I can wait a bit longer. I can't see any way it could hurt. I wasn't really looking to break new ground here and be a guinea pig, but I really hate it when new things squeak. If this works well you might have to add a column in your Dakar height thread.
  12. Jun 15, 2014 at 5:05 PM
    OZ-T
    Peter North
    British Columbia
    Sounds good
  13. Jun 15, 2014 at 8:08 PM
    TrueNorth
    Maryland
    13' V6 4X4 DCSB
    It looks like on the Dakar's there is only a 1/4" of space left in the clip hangers. So that will dictate how much can go in unless I'm missing a concept. Does the D29xl aal max out the pack? I didn't get it, but it seems like it would be close to the top bolts of the hangers.
  14. Jun 16, 2014 at 6:29 AM
    TrueNorth
    Maryland
    13' V6 4X4 DCSB
    It's ordered. No guts no glory.
  15. Jun 16, 2014 at 7:10 AM
    OZ-T
    Peter North
    British Columbia
  16. Jun 16, 2014 at 7:29 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    Do you look to use 2 strips of 0.30 instead of one 0.60"
    You glue one Under the leaf and an other over the leaf for each leaf so you'll have UHMW sliding against UHMW. This way you're gonna have a lower friction coefficient and not having metal sliding against UHMW will reduce wear.
    Just an idea. We use it in some industrial application but most of the time UHWW against UHMW or the if metal the surface should be very, very smouth, machined and polished.
  17. Jun 16, 2014 at 7:30 AM
    OZ-T
    Peter North
    British Columbia
    It's just to stop metal to metal contact to avoid squeaking , I use EPDM strips and they work too
  18. Jun 16, 2014 at 7:33 AM
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
  19. Jun 16, 2014 at 6:58 PM
    cstallings
    cstallings Well-Known Member
    Arkansas
    2013 MGM DCSB TRD Sport 4x4
    SOS Front Bumper, SOS Sliders, SOS skids, ARB Rear Air Locker, OME Lift (885x Coils, Nitro Charger Shocks, Dakar Leafs), LR UCAs, Leer Shell, OKLED 30" light bar, Wet Okle Seat covers, etc, etc
    Where did you find EPDM? I can only find it online in large quantities.
  20. Jun 16, 2014 at 6:59 PM
    OZ-T
    Peter North
    British Columbia
    I got it at my local lumber yard , they sell it as pond liner by the foot
    Check out this thread , near the end there is a post with an online supplier
    http://www.tacomaworld.com/forum/showthread.php?t=156353
