UHMW tape between leaf springs??
Discussion in 'Suspension' started by TrueNorth, Jun 15, 2014.
  1. Jun 16, 2014 at 8:07 PM
    cstallings
    cstallings Well-Known Member
    Arkansas
    2013 MGM DCSB TRD Sport 4x4
    SOS Front Bumper, SOS Sliders, SOS skids, ARB Rear Air Locker, OME Lift (885x Coils, Nitro Charger Shocks, Dakar Leafs), LR UCAs, Leer Shell, OKLED 30" light bar, Wet Okle Seat covers, etc, etc
  2. Jun 16, 2014 at 8:37 PM
    TrueNorth
    TrueNorth [OP] Well-Known Member
    Maryland
    13' V6 4X4 DCSB
    Weather tech floormats and visors, ImMrYo rear-view mirror bracket Cooper ST Maxx 255/85/16 On stock TRD alloys. OME 887's w/NitroCharger sports, LR uca's, Toytech sway bar relocate, Dakar leaf's modified with some 1/8" UHMW liner strips. SuperBumps front and back.
    I was originally going to go the EPDM route, but I got pissed at Amazon for not shipping the stuff to Alaska. My original idea was to use the tape, but I became concerned about grit getting between the leaves and tearing it up. They put small gravel on the roads in winter here for traction. Then I came across a post somewhere of a guy claiming to have had larger strips w/o adhesive between his leaves for over a decade and still going strong. That's my current plan.
  3. Jun 22, 2014 at 9:01 PM
    TrueNorth
    Maryland
    13' V6 4X4 DCSB
    Update: Here are a few pics of what I came up with.
    69608D54-36D1-4C03-B0AD-2855926509C5_zps_f30bc921bd8e64e167d410de65b6f662885b6cb0.jpg
    87BFA316-9BC8-4214-9EF8-E00EBB2E14D8_zps_624228c7c728923a1564a20536b3bbd13eedaede.jpg
    D3DD6B02-6545-405D-B395-28E2CE3A5BDE_zps_1538019b800ab409a789221d8a4edb4cfc13195b.jpg
  4. Jun 22, 2014 at 9:06 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    1/8" ?
  5. Jun 22, 2014 at 9:08 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    I just put a little grease on the contact pads that are there.
  6. Jun 22, 2014 at 9:10 PM
    OZ-T
    Peter North
    British Columbia
    That's not really the subject of this thread
  7. Jun 22, 2014 at 9:11 PM
    TrueNorth
    Maryland
    13' V6 4X4 DCSB
    Yes both strips are 1/8"
  8. Jun 22, 2014 at 9:13 PM
    OZ-T
    Peter North
    British Columbia
    Interested to hear ( or not hear ) your results
  9. Jun 22, 2014 at 9:20 PM
    AR15xAR10
    I thought the purpose of the pads in between the leafs was to eliminate metal on metal contact and eliminate squeaking?
    Maybe i don't understand :eek:
  10. Jun 22, 2014 at 9:21 PM
    OZ-T
    Peter North
    British Columbia
    This thread is about an experiment with UHMW strips between the leafs of the Dakars
  11. Jun 22, 2014 at 9:23 PM
    OZ-T
    Peter North
    British Columbia
    OP , did the pack with the strips installed fill the clips as we discussed ?
  12. Jun 22, 2014 at 9:32 PM
    TrueNorth
    Maryland
    13' V6 4X4 DCSB
    Indeed. That will be the proof.
    I had to trim 1/4" off of the whole length of the strip so I can say that it is some tough stuff. I was using a new razor blade and it took about 10 passes to get through. I also took a file to the sharp edge on the top of the 3rd leaf so it would slide and not cut into the uhmw. It took a little head scratching and measuring to get the lengths figured. I left some excess hanging off with the intention of seeing how it flexed and cutting it later.
    Other than that I'm pleased with the immediate results. It's probably for everyone, but it wasn't overly difficult.
  13. Jun 22, 2014 at 9:37 PM
    TrueNorth
    Maryland
    13' V6 4X4 DCSB
    Yes it did fill the pack up. I couldn't fit another leaf in there using the stock brackets.
  14. Jun 22, 2014 at 9:38 PM
    OZ-T
    Peter North
    British Columbia
    That may be the limiting factor in this set up
  15. Jun 22, 2014 at 9:48 PM
    #35
    TrueNorth
    Maryland
    13' V6 4X4 DCSB
    For some not entirely known reason there are none of the yellow leaf isolators on the 2nd and 3rd leaf. This allows a metal on metal situation and potential noise here. This thread is my attempt to address this problem by placing something between these leaves. There is a easier and proven, albeit not permanant fix highlighted in the squeaky Dakar thread.
  16. Jun 22, 2014 at 9:55 PM
    #36
    TrueNorth
    Maryland
    13' V6 4X4 DCSB
    Agreed. I'm inclined to think that 1/16" would have worked also, but until I have some durability results I'm not going out on that limb.
  17. Jun 22, 2014 at 9:56 PM
    #37
    OZ-T
    Peter North
    British Columbia
    I'm considering adding the d29xl OME AAL , so 1/8" wouldn't work with that
  18. Jun 22, 2014 at 9:57 PM
    #38
    AR15xAR10
    Well have fun. I'll go back to my corner now :eek:
  19. Jun 22, 2014 at 10:11 PM
    #39
    TrueNorth
    Maryland
    13' V6 4X4 DCSB
    There is that. You'd have to abandon the dak's clip and fab a new one to keep the pack together. Something like two pieces of plate and a bolt top and bottom to sandwhich the whole upper pack.
    But then again the D29xl is not for everyone.
  20. Jun 22, 2014 at 10:13 PM
    #40
    OZ-T
    Peter North
    British Columbia
    Agreed
    In my case I carry a constant 450lbs
