UJoints
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Turtle7117, May 25, 2022.
  1. May 25, 2022 at 3:59 PM
    Turtle7117
    Turtle7117 [OP] Turtle...
    Chantel
    Springfield Oregon
    2007 Silver Tacoma Pre-Runner 4.0
    How difficult are the u joints on my 07 Tacoma PreRunner.
  2. May 25, 2022 at 4:03 PM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    Not difficult at all. All you have to do is make just make sure you mark how everything was aligned and use spicer u-joints.
  3. May 25, 2022 at 4:17 PM
    TacoNonspecialist
    TacoNonspecialist Well-Known Member
    Noblesville, Indiana
    17 trd sport MGM DCLB 4x4 wtftacosōs
    Driver mod, KDmax, eibach, wheelers, morimoto, and ricer pro grille
    Bench vice and a ball joint press and a good hammer. Be careful not to bend the ears. U-joints are my kryptonite though. If you're mechanically inclined shouldn't be too much of a hassle. Watch plenty of videos before tackling it. They aren't hard they're just finicky sometimes.
  4. May 25, 2022 at 4:26 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    And if you have a center bearing, consider replacing it also. It will be on four-door and extended cab models. A vote, here, for non-greaseable u-joints.
    Alealexi likes this.
  5. May 25, 2022 at 6:01 PM
    Alealexi
    Houston, TX
    Definitely on the non-greaseables if you are the type of person that likes to set it and forget it. They come with stronger seals so that the grease doesn't escape as easily or let dirt in.
    Here are the part numbers on the ujoints and bearing. Get them in rockauto or in summitracing. They sell the exact same ones as the OEM from the dealership but cheaper.
    Dana 51330x for non-greasable
    Dana 513301x for greasable
    Dana 5002334
    Also get an extra set of retaining clips as sometimes the thinnest clip that comes with the packaging is too thick and cause the clip to bulge out. Which could lead to premature failure. I got these from Amazon as they were thinner.
    https://www.amazon.com/gp/product/B079D1SHKD?ie=UTF8
  6. May 25, 2022 at 6:05 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Chock the front and/or rear wheels.
    When you disconnect the driveshaft, the truck is free to roll.
    If you knew this, Great.
    Some people didn’t know this, and they are no longer here.
  7. May 25, 2022 at 6:09 PM
    Alealexi
    Houston, TX
    I just put mine up on jack stands. It allowed me to put my truck on neutral to spin the shaft.
    TnShooter[QUOTED] likes this.
