UltraGauge 1st Gen ABS Issue Fix
Discussion in 'Technical Chat' started by zero4, Sep 12, 2010.
  1. Sep 12, 2010 at 8:22 PM
    zero4
    zero4 [OP] Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Posting this here to compile this info from different threads as I know the info may get buried in the GB thread like all the other great info that people miss.
    References:
    http://www.tacomaterritory.com/forum/showthread.php?p=1998825#post1998825
    http://www.tacomaworld.com/forum/1st-gen-tacomas/111669-abs-light.html#post2153065
    http://www.tacomaworld.com/forum/gr...auge-group-buy-55-shipped-49.html#post2164012
    snobord552 did a good job at confirming disconnecting pin 14 of the OBDII port does resolve the ABS light issue. He extracted the pin from the port as I suggested so there would not be any permanent modifications.
    Another idea I posted is to get an OBDII port extension cable like this: http://www.amazon.com/OBD2Cables-144201-OBD-Extension-Cable/dp/B000SBCHCA
    Modify the cable to disconnect pin 14, then you will not have to worry about any permanent modifications to the truck or the UG & still be 100% plug & play.
    Now you guys can enjoy your UG like the rest of us. If you need help I'm more than willing or post here.
  2. Sep 12, 2010 at 8:56 PM
    JAG
    JAG Well-Known Member
    Good job dude! You got mad skillz.
  3. Sep 12, 2010 at 8:58 PM
    zero4
    Will
    SFV, CA
    01' DCab 3.4L TRD
    ^^ :laugh:
    Credit goes to snobord552. ;)
  4. Sep 12, 2010 at 11:04 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    And the clouds parted, rays of sunlight surround my ultragauge :)
  5. Dec 16, 2010 at 9:26 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Quick, somewhat stupid question, with the extender cable when looking at it I would be braking off pin 11 so no pin would go into 14? Just making sure before I snap off a pin on this extender cable. I think I'm making this more complicated than it really is...lol :eek:
    This would be like looking at the extender
    This would be like looking at the port on the truck
  6. Jul 24, 2011 at 9:03 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I apologize for reviving an ancient thread but, having finally bought an UG and an ODBII extension cable, I want to confirm which pin(s) I need to modify and kmok's pics are no longer showing up.
    Based on what I've read here, and in the linked posts, I understand I need to disable connectivity to my truck's (female) ODBII pin 14 which corresponds to the extension cable's (male) ODBII pin 11. Can anyone confirm?
    I've also seen anecdotal reports of possible Airbag issues on the truck's (female) ODBII pin 6, which I believe corresponds to the extension cable's (male) ODBII pin 3. Is this really a problem, or can I leave pin 3 intact?
  7. Jul 26, 2011 at 9:54 PM
    Norton
    Bueller? Bueller?
  8. Jul 26, 2011 at 10:57 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    Not sure but I got my ug back in the gb....I have an obdII extension but still haunt hooked it up, lol. I'm lazy.
  9. Jul 26, 2011 at 11:17 PM
    kmok
    Kyle
    Columbus, Ohio
    Let me see if I can find those pics or I'll pull my cable out and see which prong I took off.
  10. Jul 26, 2011 at 11:24 PM
    kmok
    Kyle
    Columbus, Ohio
    Pin 11 is correct, that's all I pulled on mine and I've had no issues with it.
  11. Jul 27, 2011 at 12:36 AM
    Norton
    THANK YOU!
  12. Feb 2, 2012 at 7:34 PM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
  13. Apr 25, 2012 at 5:31 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    Does this disengage ABS as well?
  14. Apr 25, 2012 at 6:45 PM
    tacomaforlife
    Robbie
    AIKEN, SC
    no.
  15. Apr 25, 2012 at 6:55 PM
    Norton
    Does what disengage the ABS?
  16. Apr 26, 2012 at 6:27 AM
    T-Rex266
    Elon
    The mod
  17. Apr 26, 2012 at 7:18 PM
    Norton
    In that case, I agree with tacomaforlife's answer of NO. This mod does nothing to your ABS functionality. (I'm pretty sure allowing the Ultragauge to place your ABS into what I understand to be a "diagnostic mode," however, DOES impact ABS functionality.)
  18. Dec 26, 2013 at 8:14 AM
    zacharypaul89
    zacharypaul89 Eat right, be fit, die anyway
    Zach
    Georgia
    2019 Quicksand Trd Offroad
    I hate to revive a dead thread, but I got my Ultragauge for Christmas yesterday and am having some issues connecting it. I connected and rode about a mile and the ABS light didn't come on or anything, but the Ultragauge kept beeping and saying error or something. Also, when I connected it and it scanned, it said there was a 9141 Protocol. I don't know if that's got anything to do with the ABS or what, but when I tried to follow the instructions on this thread, I noticed that my OBDII isn't configured like the one in the pictures. PLEASE HELP!!!!
  19. Jan 26, 2014 at 9:37 PM
    MedicMutt
    MedicMutt Purveyor of Useless Information
    Josh
    Baton Rouge, LA
    '03 DC PreRunner TRD OR; '06 Mercury Grand Marquis GS
    OME suspension, Whiteline bushings, Line-X'd Jason topper, GoRhino "Grille Guard", many more...
    Sub'd for reference. Getting in on the current GB.
  20. Jan 27, 2014 at 1:19 PM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
