Under dash squeak:Help identify component
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tboned, Oct 18, 2013.
  1. Oct 18, 2013 at 4:38 AM
    Tboned
    Tboned [OP] Member
    2003 Tacoma. As soon as you turn the key forward this starts to squeak intermittenly. I had to pull the glovebox to get to it so curious what it is so I can order another one or is a symptom of another issue?
    Thanks!
  2. Oct 18, 2013 at 4:54 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2015 TSS sport DC 4x4
    Blower motor or blend door actuator. I think the latter but it shouldnt squeak, but the blower motor will chirp.
  3. Oct 18, 2013 at 4:58 AM
    Tboned
    Tboned [OP] Member
    It looks like the blower motor is over to the right of this. Plus the squeal/chirp is the same no matter what the blower speed is.
    Is this something that controls the flapper for either cold/heat? I can see the white sweeper/control arm that's why I ask.
  4. Oct 18, 2013 at 5:04 AM
    TACO TX
    Kelly
    Denison ,Texas
  5. Oct 18, 2013 at 5:09 AM
    Tboned
    Tboned [OP] Member
    Thanks!
  6. Sep 8, 2014 at 9:25 AM
    bsyracuse
    bsyracuse New Member
    Barry
    Greenville, SC
    01 PreRunner
    My 01 Tacoma has been doing this for a while. The sound seems to be getting louder. I took it out yesterday and tried to bend the contacts up like I have read elsewhere. That was not the problem. The gears inside look fine. I wonder if it's the door itself that is somewhat stuck and causing the motor and arm to work too hard? When I put it back in, I messed something up and the AC blew out heat. I know the arm moved when I installed it.
    Anyhow, wondering if anyone has replaced one, knows the part number or any thoughts on the door being the culprit?
  7. Sep 10, 2014 at 9:32 AM
    Tboned
    Tboned [OP] Member
    Blend door actuator fixed it! Easy install and was around 130$ online.
  8. Sep 11, 2014 at 5:05 AM
    bsyracuse
    Barry
    Greenville, SC
    01 PreRunner
    Thanks! I'll go ahead and order a new one. The noise is quite annoying.
  9. Nov 12, 2015 at 2:08 PM
    LetsTacoboutit
    LetsTacoboutit Well-Known Member
    SEÑOR MEMBER
    Tejas
    4x4 TRD 6cyl
    yada, yada, yada
  10. Oct 6, 2018 at 6:56 AM
    veleno
    veleno Well-Known Member
    I know this thread is old but how do I remove the blend door actuator? I can't find a video online for removal.
