" Under load / uphill " vibration
Discussion in 'Technical Chat' started by OZ-T, Jul 15, 2013.
  1. Jul 31, 2013 at 9:57 AM
    #81
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    OK ,
    had a chance to get some more accurate driveline angles today
    This is parked on a level concrete slab
    Front pinion
    Rear is 4.50 degrees UP
    Front section of driveshaft it 2.70 degrees off of square to the front pinion
    Rear section of driveshaft is 0.30 degrees off of front section
  2. Jul 31, 2013 at 10:02 AM
    #82
    OZ-T
    Peter North
    British Columbia
    I think I will remove the 3* shims and see if that improves matters
  3. Jul 31, 2013 at 12:05 PM
    #83
    OZ-T
    Peter North
    British Columbia
    I think it's this
  4. Jul 31, 2013 at 4:57 PM
    #84
    Boilerman
    Boilerman Well-Known Member
    Brian
    Texas, northwest of the Big Pond
    2010 Prerunner SR5 Magnetic Gray 2.7L
    I have a vibration and noise that comes when I have the cruise on and climbing an overpass on the road. Mine is coming from behind the glovebox somewhere.
  5. Jul 31, 2013 at 5:58 PM
    #85
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    I don't know how much of a noise/vibration your talking about but...
    Check that the cabin air filter access door is snapped shut all the way. Our Highlander had a rattle in the glovebox area for a week before I discovered that the filter door wasn't clipped all the way shut. It had somehow sounded like something a lot bigger and heavier.
    Just another thought, something easy enough to check and rule out.
  6. Jul 31, 2013 at 6:17 PM
    #86
    Boilerman
    Brian
    Yep it is snapped in securely.
  7. Aug 2, 2013 at 11:20 PM
    #87
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
    Any progress Calgarian?
  8. Aug 2, 2013 at 11:21 PM
    #88
    OZ-T
    Peter North
    British Columbia
    I haven't removed the shims yet , no
  9. Oct 15, 2013 at 11:53 AM
    #89
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I swapped my carrier bearing and my vibrations under load are gone. I think that the rubber in the carrier was allowing for too much movement and caused my vibration/shutter issues.
  10. Oct 15, 2013 at 12:35 PM
    #90
    OZ-T
    Peter North
    British Columbia
    Interesting
  11. Oct 15, 2013 at 12:38 PM
    #91
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Does this mean you're never getting that new light bar installed?
  12. Oct 15, 2013 at 12:39 PM
    #92
    Pugga
    Massachusetts
    With the new bearing installed, there was noticably less play in the rubber surround. We'll see how long it lasts but initial results were great! I bought a Dorman bearing from Rock Auto (wouldn't recommend it, it crapped out in 300 miles, replacement is on it's way). In the 300 miles, I tried to do everything I could to replicate the vibrations and shuttering I had before and it wouldn't do it.
  13. Oct 15, 2013 at 4:01 PM
    #93
    OZ-T
    Peter North
    British Columbia
    Cool info , thanks Mike
  14. Dec 1, 2013 at 2:06 PM
    #94
    Pugga
    Massachusetts
    I'm going to update this. Dorman bearings have a lifetime warranty so Rock Auto sent me a new one. That one lasted a little longer to just about 1,000 miles before it started squeeling again. I got sick of Dorman and bit the bullet and bought an OEM bearing for a cool $150. Well, the take off shutter came back when I swapped the bearings out. All vibrations and shutters were gone with the Dorman, the under load shutter came back with the OEM bearing. They're not as bad as it was before, but still noticeable.
  15. Dec 2, 2013 at 3:14 PM
    #95
    OZ-T
    Peter North
    British Columbia
    Thanks for the update
  16. Oct 31, 2020 at 8:13 AM
    #96
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
    So, seven years later what have we discovered?
