Under rail LED bed lights
Discussion in '1st Gen. Tacomas (1995-2004)' started by Richie85, Sep 14, 2010.
  1. Sep 14, 2010 at 11:00 PM
    Richie85
    Richie85 [OP] Member
    Northern California
    2002 Tacoma Prerunner Double Cab
    Hello everyone. Just bought a 2002 Tacoma DC with a hard Tonneau. I'm really itching to put in some under rail LEDs that will come on when the cover is lifted. Anyone done something similar? recommendations? Thanks for the help.
  2. Sep 15, 2010 at 12:19 AM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    Something like http://www.oznium.com/smd-bar or any of the water proof ones http://www.oznium.com/flexible-led-strips should work. As far as the switch, something like http://www.oznium.com/pin-switch will work. Probably easiest to hook the switch up to the tailgate since you'll have a bit more play when its closed. There's even a few pics on their site of people that have done it. (look at the beefy led strip action shots for someones actual truck bed)
    Pretty easy setup overall, and since the leds really dont use much power, I wouldn't even bother with a relay. Just run all the grounds to the back end of the switch and when its open, it'll complete the circuit and turn on the lights.
    I'm not sure I'd put an automatic switch in my truck like that though. Although the leds really dont use that much power, I think an in cab switch would still be the better solution to best avoid a dead battery, although if you forget to turn it off (and dont run a lighted switch), that might still be a problem.
  3. Sep 15, 2010 at 12:34 AM
    Hawaiitaco
    Hawaiitaco Well-Known Member
    Hawaii
    TRD OFF ROAD
    Blue Sea Fuse Box, led bed lights and ground lights
    I'm in the process of doing the same thing..and also doing ground lights... here are some of the threads im using as reference...
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/4323-bed-lights-w-pics.html
    http://www.tacomaworld.com/forum/technical-chat/4838-cheap-free-mods-18.html#post297835
    Suggestions for LEDs.:
    http://www.vminnovations.com/product_275/Underbody_4_Piece_LED_Light_Kit_White_.html
    I actually bought: http://www.amazon.com/LEDGLOW-White...7?s=automotive&ie=UTF8&qid=1284535647&sr=1-27
    They look great so far...im running them to a spdt rocker so that it will run either with the dimming domelight or on whenever i want..when i finish ill take some pics.... search around..there are some great posts and people that are very helpful...ie. borderbrat and pierced tiger
  4. Sep 15, 2010 at 8:22 PM
    Richie85
    Northern California
    Thanks for the info. I wasn't even thinking about using the "rope" or "tape" LEDs, but I'm thinking that they might be the way to go now. anybody have any other opinions or options? thanks again guys.
  5. Sep 15, 2010 at 9:03 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    i'd do the rope led's with a rocker switch hidden up under the rails.
  6. Sep 16, 2010 at 4:36 PM
    Richie85
    Northern California
    I'm thinking about doing the rocker switch switch the more I think about it. What's the best kind of rope or tape LED out there in your guys opinion? its a DC bed so I'd need about 10 feet
  7. Sep 16, 2010 at 9:21 PM
    pittim
    Pennsyltucky
    Boujee Prius
    if you put 2 of the 20 in piranha bars on each side i think you'll have more than enough light. just have it so the gaps are even...so one from 7"-27" and 34"-54" back from the front.
  8. Sep 17, 2010 at 8:00 PM
    Richie85
    Northern California
    Thanks for the info...you guys are great. Should I get the mounting kits that Piranha sells or is there a better way to mount them?
  9. Mar 9, 2014 at 10:49 AM
    grumeazy
    grumeazy Member
    California
    14 Tacoma
    Banks Monster Exhaust
    Thanks for the idea and write up. Just did mine today.
  10. Apr 2, 2015 at 11:30 AM
    dani144
    dani144 Member
    Daniel
    canada
    2013 tacoma
    iv done these over the winter they are led strips and i put the light switch by the tail gate ran power of the rear lights cost me a total of 20$ and about 2 hours of work
  11. Apr 2, 2015 at 12:14 PM
    stikle
    stikle Well-Known Member
    Seth
    The Sovereign State of Eastern Oregon
    1997 LX Xtracab 4x4 V6 3.4L
    Eh, see my Build Thread sig link. Too many mods to list.
    Take a look here...
