Under the Hood LED Lighting
Discussion in 'Lighting' started by Colonel Crow, Apr 19, 2015.
  1. Apr 19, 2015 at 8:05 PM
    Colonel Crow
    Colonel Crow [OP] Member
    Caleb
    Florida
    2014 Prerunner
    Debadged, Under-hood LEDs
    Hello All,
    This is my first “real” post, I just got my Tacoma on Friday and have been doing all kinds of things to it. I went through the list of quick links for modifications and looked at the engine bay lighting mods, I personally did not like anything I saw. I used a 20 inch LED strip from AZ and installed everything today. I hate seeing crappy wiring jobs and poor workmanship so it took longer than normal to run the wiring and work up a fused terminal block.
    The finished product. It is dark out side... I think the light output is perfect.
    Here is the pin that I fabricated. When the hood is closed it interrupts the ground, causing the circuit to be "open", killing the light. As soon as the hood is popped the light energizes.
    And finally my power solution. The block is mounted to the fuse box, all four slots are powered with 12v, leaving me 3 more areas to expand out too for future projects. There is an inline fuse on the other side of the cover that is directly connected to the 12v power from the battery.
    And thats all, let me know your thoughts!
  2. Apr 19, 2015 at 8:10 PM
    senfgastn
    senfgastn Member
    Chuck
    Knoxville, TN
    2018 Tacoma TRDOR silver
    Excellent work! I'd love to see a thorough write up. My new Taco is begging for this.
  3. Apr 19, 2015 at 8:16 PM
    Colonel Crow
    Caleb
    Florida
    2014 Prerunner
    Thanks! If people are interested I could go through and take some detailed pictures with explanations.
  4. Apr 20, 2015 at 8:42 AM
    TurboRyan
    TurboRyan New Member
    05 tacoma v6
    How did you run your wire from your hood to your switch. I did this a while ago and im curious if you ran your wire like i did, or if you came up with something more hidden. I ran mine near the hood hinge. Ill post a pic when i get home.
  5. Apr 20, 2015 at 6:25 PM
    Colonel Crow
    Caleb
    Florida
    2014 Prerunner
    I ended up using duplex wire and running it through the hood completely tucked. I put a grommet in the base of the hood and then ran the wires into the stock wiring harness.
  6. Apr 20, 2015 at 6:30 PM
    mlbdriver
    mlbdriver Well-Known Member
    Ben
    Santa Rosa
    2020 TRD Off-Road
    Go Fast Camper ARB Dual Air-Compressor Pro-Comp 7089 17x8 BFG AT KO2 265x70x17
    looks good details would be appreciated
  7. Apr 20, 2015 at 7:32 PM
    rvdb
    rvdb Well-Known Member
    CA
    TRD Sport
    stuff that makes it better for my use...
    Nice work...
  8. Apr 21, 2015 at 3:40 AM
    Colonel Crow
    Caleb
    Florida
    2014 Prerunner
    Im on duty right now, Ill make a write soon. BM? "MLBdriver" im assuming you mean 47MLB (or 41)?
  9. Apr 22, 2015 at 3:42 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '03 cbr600rr, '09 R1, '03 cbr954rr
    Nice. Very interested on that hood pin switch you used. I ended up using a rocker switch and mounted it on the fuse box lid. I would rather use the pin switch but had a hard time finding one. Where'd you get yours!?
    btw here's mine. strips are form Superbrightleds. Have lasted for a couple years at least now. And never pealed off. Have a section of 3 led's that recently burnt out but no biggie. Also ran mine through the hood supports and down by the hood hinge.
  10. Jun 2, 2015 at 1:12 AM
    McCallywood
    McCallywood Active Member
    Christian
    McCallywood & San Diego
    2015 DCLB TRD SPORT MGM
    17" Black Trd Pro "Sema" wheels, TRD Exhaust
    A more detailed write up would be greatly appreciated
  11. Jun 2, 2015 at 5:45 PM
    BluLED
    BluLED Well-Known Member
    SoCal in the foggy desert
    Yeah, Col. Crow give us a writeup. :thumbsup:I too like your finished look vs the "stuck together with spit and bailing wire" approach (not that I've ever done that-nope not me:rofl:
  12. Jun 3, 2015 at 10:53 AM
    Colonel Crow
    Caleb
    Florida
    2014 Prerunner
    Alright alright! I'm making a writ up right now guys. Check back tonight!
