Undercoating / Rust proofing
Discussion in 'Detailing' started by EvilEmpire, Nov 7, 2011.
  1. Nov 7, 2011 at 7:42 AM
    EvilEmpire
    EvilEmpire [OP] Aircraft Commander
    Pittsburgh, PA
    4x4
    Been doing a ton of research here and still coming up 50/50 on the go or no go on this....Just got a new truck and debating on the ziebart vs oil spraying...my truck will spend most time outside and will be driven on the barren salt tundra that will become our highways. Any opinions for those in the north country?
  2. Nov 7, 2011 at 10:09 AM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    krown.com if you can get it there
  3. Nov 7, 2011 at 8:51 PM
    EvilEmpire
    Pittsburgh, PA
    4x4
    i would love to but im down in south pennsylvania, im thinking a good thick thick coat of paint may be best then add some oil/wax protectant - has this worked good for anyone in particular?
  4. Nov 8, 2011 at 9:57 AM
    tim455
    tim455 Active Member
    Tim
    Sharon,Pa
    PreRunner SR5 in Barcellona Red
    Tinted windows/Borla Cat-back/K&N CAI filter/ /all bulbs LED/G-Force chip//TRD skid plate/Daystar 9130 lift kit,Truxedo Lo-Pro cover,Weather Tech Mats and vent visors, N-Fab Step bars,Scan guage.Sony stereo/Redline hood struts/EBC slotted rotors and green stuff pads/Truxedo LoPro Tonno/Rigid light bar behind Grillcraft Grill./Helo wheels with Michlin tires
    Oil, I do mine every fall and all my friends... IT WORKS! Will do yours if you don't mind drivin north an hour? PM me if your interested.
  5. Nov 10, 2011 at 2:28 AM
    808hiker
    808hiker Taco addict
    Justin
    Big Island, Hawaii
    Spray the undercarriage with oil. Works for our tractors quite well on the farm. It's a messy job but just gotta be careful and you'll be good to go.
  6. Nov 10, 2011 at 6:24 AM
    lossscause
    lossscause Well-Known Member
    Southwest Ohio
    2001 Taco DC 4x4
    Eibach coils/Bilstein 5100's, 2" block, 17x7.5 Tundra Wheels, 285/70/17 BFG AT, 1.25" All-Pro Spacers, AirLift Bags w/On Board Compressor
    I'm about to spray Fluid Film under mine.
  7. Nov 10, 2011 at 11:06 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    ziebart is not very good imo
  8. Nov 10, 2011 at 11:09 AM
    NicNac22
    NicNac22 D.I.L.L.I.G.A.F
    Nic
    Wild and Wonderful
    95 V6 4x4 ex cab SR5 5sp PICKUP!!!
    fun stuff coming soon! New battery, radiator and CV joints and axles. Added some Rancho RS5000 shocks.
    what kind of oil?
  9. Nov 10, 2011 at 11:11 AM
    Hook & Ladder
    Hook & Ladder Well-Known Member
    Maine
    16' TRD Tacoma
    The project @c4_fabrication-Sliders, HC bumper w/ swing out @kb_voodoo_fabrications-Bed rack @tepuitents-RTT @cali_raised_led-Fogs, ditch lights, bed stiffeners @prinsudesign-Roof rack @kingshocks-2.5 with adjuster @totalchaosfabrication-UCA @rcioffroad-diff skid plate Follow at @wicked_overland #nacrew
    agree with this FF is the way to go., I started a post on this same subject ! look for it and you can see why FF it better the rubber undercoating
  10. Nov 10, 2011 at 11:14 AM
    Hook & Ladder
    Maine
    16' TRD Tacoma
  11. Nov 10, 2011 at 11:36 AM
    Oscarbob
    Oscarbob Well-Known Member
    Bob
    Central New York
    '10 DCSB 4X4 OR, Pyrite Mica
    WeatherTec floormats and rainguards, Scanguage, LR UCA, 265/75/16 Duractrac's
    I'm in the middle of doing this, just taking a break for some TW.
    Fluid film seems to be a great product. Professional plowers and farmers swear by it.
    I bought 4 cans and just used up 1 and it covered way more than I thought it would.
  12. Nov 10, 2011 at 12:49 PM
    Cars99
    Cars99 New Member
    Justin
    Detroit, Michigan
    I think that Ziebart is the best choice for an undercoating.
  13. Nov 10, 2011 at 1:29 PM
    Tacoma Mike
    Southern Maine
    Oh man that stuff is nasty.
    Ive worked on plenty of vehicles with that on and trying to get tools over bolts and things off is crazy. then once you get the parts apart it's all rust under the zeibart. If there is a crack in the undercoating then stuff gets in and won't let it out.
    If it's worked for you then my all means stick to it.
  14. Mar 14, 2012 at 1:07 PM
    kyser13
    kyser13 Well-Known Member
    09 Tacoma/SR5 4X4
    Debadged, Inno bed rack blacked out brackets, Blacked out front Toyota badge, Interior red LEDS, 285/17-70 Duratracs, 17X9 Moto Metal 957s, Toytec 3" lift Bilstiens, Ultra Gauge, LED bed lights.
    So what do you use, how do you apply it, and whats the prep process for the oil?
  15. Mar 16, 2012 at 5:00 PM
    tim455
    Tim
    Sharon,Pa
    I use used oil from semi's and spray it with a garden sprayer. If your truck is really muddy I'd recommend pressure washing it a day or so ahead of time.
  16. Mar 16, 2012 at 5:37 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Illegal in most states and used oil has a lot of nasty stuff in it. FF did mine in the fall still is wet and on the frame not a bit of it has washed off.
  17. Mar 17, 2012 at 6:59 AM
    ryank 5
    ryank 5 Well-Known Member
    Jefferson County, PA
    2006 Radiant Red Taco - Access Cab 4WD TRD
    OME Dakars, OME 884's, 5100's all around (0" setting), SPC UCA's, 17" 4-Runner Trail Edition Wheels with Dynapro's, ABS Killswitch Mod, Extang Tonneau
    Cheap and effective way right here.
    Theres no need of doing it now, so wait til fall. When youre changing your oil, keep it! Use it on your truck! Make sure its dry outside and drive down a dirt road after you spray it. This will work.
  18. Mar 17, 2012 at 8:30 PM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    Krown is the best for sure, but any undercoating is going to help you v.s. a salty highway. Do it annually to keep the protectant working, as it gets washed off over time.
    Krown is hands down, the best out there if you have one in your area. Their product will creep up panels, and into seams. It's pretty cool stuff.
  19. Mar 17, 2012 at 8:36 PM
    udy2554
    udy2554 NORTHERN RED-NECK
    Naples, NY
    '06 Tacoma TRD Sport
    Toytec ULK, Light Racing UCA's, OME Dakar rear leaves, ARB Bumper with XRC8 winch, Good Year Duratracs 285/70/17's on 17x9" Level 8 Strike 6's. Leer cap in the winter. Pioneer Double Din with BT, iPod, etc. Boston Acoustic components in all 4 doors with a Sony amp, powered 8" sub. Ultra gauge, Tom Tom...
    This^^^^though it does get a little messy!:D It doesn't have to go on so thick it drips, but enough that every thing is coated.
  20. Mar 17, 2012 at 8:47 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I agree! Fluid Film works great...I like the fact you can still see the frame and the nuts and bolts aren't covered up like they would be with rubberized undercoating.
