Undercoating?
Discussion in '1st Gen. Tacomas (1995-2004)' started by goldentaco03, Nov 23, 2015.
  1. Nov 23, 2015 at 4:36 PM
    goldentaco03
    goldentaco03 [OP] Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    I want to protect some of the parts from rust. I am planning on cleaning any existing rust off then coating them with some sort of spray like rhino liner. Is this the right way to do it? And any recommendations on types of "liner"?
    Liam
  2. Nov 23, 2015 at 10:43 PM
    CodeSeven
    CodeSeven Yo
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    if it's rust your dealing with, find the threads about rusty frames/chassis and make sure that doesn't apply to you. they will talk up and down about how the rust problem on the chassis is internal and not external. if you have no internal chassis rust issues, then good. you already pretty much have the right idea on what to do.
    bedliners are the best to use since they're so strong. I live in the so cal desert so i don't worry about rust. however, recently, I had a bout with a squeaky noise that ended up being my center support. during this bout, I used rubberized undercoating on anything that could cause this kind of noise. the leaf springs, the crossmember holding up my spare tire, some heat shields around my exhaust, the crossmember holding my tranny mount, and even the rockguard under my engine. now that I fixed my center support after the fact, my truck is now like 80% quieter!
    in lieu, bedlinders offer great protection. but rubberized undercoating offers quietness. use both if you can afford to :)
  3. Nov 23, 2015 at 10:47 PM
    CodeSeven
    CodeSeven Yo
    Serge.
    Coachella Valley
    as far as which bedliner to use, I recommend raptor liner. as a paint supplier, I saw people order more of this than anything through us. it was a very simple and dependable system to use. that's all. zolatone has a better and more durable system if you want. little more complex, but it's stronger and offers different colors. duplicolor, herculiner, and rhinoliner are all in competition with each other and don't really offer anything over the others unlike zolatone and raptor liner.
  4. Nov 24, 2015 at 3:30 AM
    goldentaco03
    Liam
    NJ
    NO internal rust I already had my frame replaced just trying to protect skid plates struts and other semi-important pieces.
  5. Nov 24, 2015 at 3:53 AM
    DrFunker
    DrFunker is Funkified!
    Didums
  6. Nov 24, 2015 at 6:20 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    Spray it all with fluid film.
