Undercover Classic LED Light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mikerizer, Sep 4, 2017.
  1. Sep 4, 2017 at 7:07 PM
    Mikerizer
    Mikerizer [OP] Active Member
    2013 Tacoma 4D 4X4
    2013 Tacoma Quad Cab, 5' bed
    I recently purchased a used Undercover Classic bed cover. I'm really enjoying it, not having to worry about keeping a toolbox, jumper cables, tow chain, hatchet and shovel handy.
    The cover has an LED light built in. I replaced the batteries (2 but does it take 3?), but can't get it to work properly. If i insert them negative side first, nothing happens. If I insert them positive side first, the LEDs light up, but won't turn off.
    There seems to be a thin ring inside the battery compartment, but it's only wide enough to cover the height of one battery. Is this an insulator, or just a spacer? It seems to be conductive.
    Does anyone have any kind of an assembly schematic, so I can be sure I'm putting it together correctly? I can't seem to find one on the web.
    Thanks,
    Mikerizer
  2. Sep 5, 2017 at 7:35 AM
    boogie3478
    boogie3478 Tacomaholic & Hollywood
    Northern Virginia
    14 TRD Off-Road V6
    All the mods
    Maybe the lights only come on when the bed cover is raised?? :notsure:
  3. Sep 5, 2017 at 12:30 PM
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 Black Tacoma Prerunner SR5 V6
    OME Lift with HD Dakar’s JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Mid-Height Rack with Tonneau Cover Brackets 23Zero RTT 23Zero Awning Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
    Mine has a light but is small and useless. You'll need to install something else if your going to see anything at all after dark.
  4. Sep 5, 2017 at 7:29 PM
    Hanwei
    Hanwei Active Member
    2015 White Tacoma TRD Pro
    My undercover flex tonneau came with LED light strips... when I turned them on to test them... pressing the button once to turn them off didn't do anything. I figured out that I had to press the button twice in quick succession to turn the lights off.
    So...
    1 Press = On
    2 Quick Presses = Off
    Did you try that?
  5. Sep 6, 2017 at 12:33 PM
    Mikerizer
    2013 Tacoma 4D 4X4
    Thanks for the replies...I bought a new unit from Amazon. I think the old switch is just bad. The button doesn't move properly when pushed.
  6. Feb 9, 2018 at 5:18 PM
    Mikerizer
    2013 Tacoma 4D 4X4
  7. Feb 9, 2018 at 6:35 PM
    baldridge
    Bart
    Auburn, AL
  8. Feb 9, 2018 at 7:37 PM
    Mikerizer
    2013 Tacoma 4D 4X4
    It's waaaaay brighter than that rinky-dink light that came with the cover. It lights up the whole bed!
