Undercover frozen locks...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fish Tacos, Jan 29, 2009.
  1. Jan 29, 2009 at 4:05 AM
    Fish Tacos
    Fish Tacos [OP] Active Member
    Conn
    2009 Double Cab TRD Off-Road
    I have an undercover which is awesome. I love everything about it - great looks, helps mpg, easy to use and keeps things secure. The only thing I don't like is how the locks freeze up in the winter and can be bitch to turn with the key. My only solution so far is to pour some hot water over them - they loosen up pretty quick but if there's a better way to keep them unfrozen - I'd love to know.
    Maybe some sort of spray or something to prevent freezing....?
    Any solutions out there?
  2. Jan 29, 2009 at 4:12 AM
    Joe B
    Joe B Well-Known Member
    I haven't had any problems with my Undercover locks and the weather has been very cold with plenty of snow and ice.The plastic covers over the locks helps big time.
    Pouring hot water on the locks is not a good idea.
    The locks will be frozen the next time you try to use the key.
    Try heating your key with a bic lighter.
    Also try adding powdered graphite in your locks when the locks dry or maybe some WD-40..
  3. Jan 29, 2009 at 4:24 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Lock de-icer.
    Try Sears automotive for about a buck. Or maybe a Valu. Many places have it but some hammer you for it. Get several, as they don't have a lot in each can.
    Also - If you are washing the truck in the cold weather, hit the locks up right after to keep them from freezing up on you.
  4. Jan 29, 2009 at 4:28 AM
    ph16drive
    ph16drive \m/.....\m/
    Paul
    Clevelandish
    08 DC, V6, 4x4, 5-Speed Auto
    Shorty antenna, Pop-&-Lock tailgate lock, Undercover bed cover, Aeroforce Interceptor gauge (custom mount), bed mat, AFE Pro Dry S air filter, map light mod, suspension TSB, Billy 5100's all around, Eibach springs, custom fuel tank armor plate, custom cat armor plate, painted front brake calipers, Grillcraft MX upper grill & Hella 500s, ipod adapter, dash pushbutton garage door opener, aux reverse lights, custom ipod nano 4G mount, seatbelt chime mod, custom bull bar w/ (3) Lightforce 140 Lance lights, POR-15 Chassis Coat Black drivetrain, illum 4x4 switch, xtra bed D-rings mod, locker anytime mod, diff breather relocation mod, ABS disable switch mod, Heated seats
    X2 w/ the graphite . . . haven't had good luck with liquid anything (wd40 or the like). Mine also get difficult to turn and/or frozen so I make sure I exercise them regularly. One advantage I have is that the truck stays in the garage and pretty much thaws them by morning if they do get frozen. I have to exercise my pop-n-lock too but the graphite seems to be helping. I'm also looking for the BEST solution to keep them from freezing w/o having to upgrade to an 'ARE' top or something like that.
  5. Jan 29, 2009 at 4:42 AM
    WNYTACOMA
    Clarence, New York
    WD-4O has water in it from my understanding.
    Not rocket science to figure out why it is not the best for use in sub-freezing temperatures.
    Lock De-icer is made for use in locks with freezing temps. That is its #1 purpose.
  6. Jan 29, 2009 at 4:46 AM
    Joe B
    No water according to this buy still has liquid that may freeze..
    What does WD-40 contain?
    While the ingredients in WD-40 are secret, we can tell you what WD-40 does NOT contain. WD-40 does not contain silicone, kerosene, water, wax, graphite, chlorofluorocarbons (CFCs), or any known cancer-causing agents.
    Lock De Icer is the smart choice.
    So much for the secret ingredients.
    WD-40's main ingredients, according to U.S. Material Safety Data Sheet information, are:
  7. Jan 29, 2009 at 6:40 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    Lock deicer to free it up and WD-40 to keep it from happening. It's my understanding that the "WD" was short for either water displacement or water displacer. I'm on my 3rd trouble free winter with my undercover. :D
  8. Jan 29, 2009 at 6:51 AM
    Joe B
    Anybody ever try a wet graphite like this?
    Product Description
    - Use for year round lock protection - Seals out moisture and protects against lock freeze-up - Helps locks work easier, prevents sticking, guards against rust and corrosion - Flushes out dirt and grease, and helps free stuck and frozen locks - Colloidal graphite penetrates to every part of a lock, then the special carrier evaporates leaving a graphite, long-wearing protective film - Won't run in the hottest climate and won't gum or harden in sub-zero cold - With flexible snorkel for ease of use - 3.5 oz aerosol
  9. Jan 29, 2009 at 7:00 AM
    WNYTACOMA
    Clarence, New York
    Ahhh, i stand corrected. Not sure where i heard about the water content. Seems like it was related to why WD wasn't a good choice to 'undercoat'.
    Anyway, good info.
  10. Jan 29, 2009 at 7:05 AM
    Joe B
    Yeah,I too thought there may be some water in WD-40 or at least liquid that freeze.
    Roland posting the WD may stand for Water Displacement makes sense.
    Any thoughts on that liquid graphite additive?
    I always used dry.
  11. Jan 29, 2009 at 7:08 AM
    Bearskill
    Bearskill Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    Ya, there are sprays out there. Just go to Autozone or something. I used to have a 94 Geo Tracker. In Idaho the door looks would freeze up over night. I would try and get in and go to work only to find them froze shut. Not a big fan. Had to get that spray stuff to free it up. Can't remember what it was could but worked great.
  12. Jan 29, 2009 at 7:14 AM
    WNYTACOMA
    Clarence, New York
  13. Jan 29, 2009 at 7:17 AM
    Joe B
  14. Jan 29, 2009 at 7:18 AM
    WNYTACOMA
    Clarence, New York
    FYI - For anyone reading this and using any of this stuff, its a good idea to have a rag ready to catch any of the extra ozzing out of the lock opening.
