Understanding Key Fob and Security System -- Technicians?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hotajax, Jan 17, 2023.
  1. Jan 17, 2023 at 9:33 AM
    hotajax
    hotajax [OP] Well-Known Member
    09 TRD Off Road
    Here we go. Sometimes I leave my key in the ignition overnight. (Rural area and a Doberman that loves to ride in my truck). So I go out the next morning and start the engine. It will run for a few seconds, and then dies when I try to back out. Solution: Remove the key for about 10 seconds, holding it far away from the steering column. Usually it will start right up and run without interuption.
    Weird part: Other nights when I leave the key in the igniton overnight, the next morning it will start right up and stay running without cutting out.
    Question: Why does the engine cut out sometimes, and then other times it will run without a hitch? Completely illogical.
    Thanks in advance. Hot Ajaxx
    HondaGM likes this.
  2. Jan 17, 2023 at 10:08 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    What you describe is not how the immobilizer works. (Security system)
    The immobilizer will let the truck crank, but never start.
    Your problem sounds like a bad fuel pump resistor. When you first start your truck, the resistor is bypassed. Once it has run about 10 seconds it then switches to the resistor.
    Dm93 and HondaGM like this.
  3. Jan 17, 2023 at 4:49 PM
    TacoTuesday1
    SD CA
    Leaving key in truck is how it gets stolen
    Vehicles locked go into sleep mode reducing power to electrics to save battery.
    not doing that usually messes with things
    HondaGM likes this.
  4. Jan 17, 2023 at 6:35 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I'm with @TnShooter, I'd suspect a fuel system issue or fuel pump relay that isn't switching properly between high and low speed.
    Another possibility the throttle body is getting a bit dirty and causing cold idle to be a bit too low.
    My keys stay in mine all the time at home and I've never had an issue with it doing that.
  5. Jan 17, 2023 at 6:40 PM
    Bishop84
    Bishop84 Well-Known Member
    Basically if it starts, thats it, the immobilizer has done its job and won't stop the truck again. So if the security light flashes and turns off, the immobilizer is fine.
    This sounds like fuel to me as well. It's a pain to find a fuel gauge for these trucks, so you may be best off taking it to a shop as this sounds like an issue that can leave you stranded.
    TnShooter and Dm93 like this.
  6. Jan 18, 2023 at 1:19 AM
    hotajax
    09 TRD Off Road
    My Doberman likes the truck too much for somebody to steal it. She likes those rides.
  7. Jan 18, 2023 at 7:14 AM
    hotajax
    09 TRD Off Road
    Theft isn't the issue
  8. Jan 18, 2023 at 7:38 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    The immobilizer cuts power to the fuel pump completely. crank all you want, but it will never start if the immobilizer is doing its job.
    sounds like you have a different issue. the fuel pump relay that switches from low to high is down by the battery. unplug it and see what it does. start there to investigate, as that is free and easy.
    also, take the key out completely, to see if leaving the key overnight has something to do with the issue.
  9. Jan 18, 2023 at 8:01 AM
    hotajax
    09 TRD Off Road
    Sounds like you and Tennessee Shooter have the goods on this. Thanks.
  10. Jan 18, 2023 at 8:02 AM
    hotajax
    09 TRD Off Road
    Thank you.
  11. Jan 18, 2023 at 10:25 AM
    FishaRnekEd
    New Orleans, LA
