Understanding Open Face vs Closed Face Center Support Bearings
Discussion in '1st Gen. Tacomas (1995-2004)' started by hawhawkk, Nov 15, 2021.
  1. Nov 15, 2021 at 8:50 AM
    hawhawkk
    hawhawkk [OP] Member
    Joe
    2003 Toyota Tacoma Double Cab PreRunner 3.4L 2WD
  2. Nov 15, 2021 at 9:36 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Not sure if this is the case for first gens, but I know on 2nd gens there are two different P/Ns. One with dust shield for 4x4 and pre-runner trucks, and one without for 2wd.
    Only one of your pictures loaded, but Im guessing thats the case here.
    And no, no one has the correct picture listed with the correct P/N when shopping online..
  3. Nov 15, 2021 at 9:42 AM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    the one pictured seems right
  4. Nov 15, 2021 at 10:16 AM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
    I just replaced my carrier bearing, I bought the spicer replacement. Here is what my old and new one looked like:
    My new one is the "open" style. The old one seems to be the same style, although it's a bit roughed up at this point. Haven't had any issues with the new one!
  5. Nov 15, 2021 at 10:51 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    What the OP is calling "closed face" is the Toyota spec bearing for the 1st gen 4wd Tacoma. The other (Spicer) is Toyota spec for some other Toyota application. They both "fit"and "work" but the Taco spec bearing has two additional seals under that "face". Might be worth it for some, others not given the price difference.
    For some reason a bunch of folks on this forum think they are "the exact same thing" and the Spicer is Taco OE. Obviously they are not.
    "The Spicer says Toyota right on it" is the typical justification, from this thread https://www.tacomaworld.com/threads/1st-gen-genuine-oem-carrier-bearing-for-79.583219/
    The open Spicer (and other brands) are common in the aftermarket at a much lower price. No 1st gen 4wd Taco came with the Spicer brg, not from the factory and not current Toyota service replacement.
    OE vs Spicer, OE on the left.
    Inside an OE (factory) Tacoma spec OE bearing with the two extra seals.
    Recent Toyota service replacement.
    An OE bearing.
    ztwatson, kctmet and 1bad2k like this.
  6. Nov 15, 2021 at 10:55 AM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    So morbid curiosity here, is there anything from Toyota that did come with a Spicer bearing? Because if you buy the Spicer bearing they have a Toyota part number formed into the rubber right outta the box. I never bothered to cross reference the number since the bearing was cheap and worked.
  7. Nov 15, 2021 at 11:05 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    The "Toyota part number formed into the rubber" crosses to something else like the T 100.
    Not going to debate the worth of the two extra seals, just pointing out the difference.
    Speedytech7[QUOTED] likes this.
  8. Nov 15, 2021 at 11:46 AM
    SR-71A
    Zack
    Southern Maine
    Yes, the two extra seals is what I was getting at in my poorly worded post above haha.
    Pretty sure they are manufactured for Toyota by Spicer. The 2nd gen trucks have a Spicer sticker right on the driveshaft assemblies.
  9. Nov 15, 2021 at 11:58 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    Spicer did make some 1st gen driveline parts according to Toyota, I think it was 5 lug stuff.
    The 4wd shafts use Koyo u-joints and the supt bearing itself is Koyo along with the double cardan parts.
    One would think if Spicer also made the 1st gen Taco 4wd support bearing they would sell it.
    Anyhoo it's all trivia, point is they are different.
