Uneven Wheel Well Spacing - Tires Not Centered in Wells
Discussion in 'Suspension' started by Vege-Taco, Aug 29, 2008.
  1. Aug 29, 2008 at 8:35 PM
    Vege-Taco
    Vege-Taco [OP] Chips and Salsa Specialist
    Shawn
    Arizona
    2017 Tesla Model S 100D
    Bugs on the windshield
    Could some of you check your front wheel well spacing for me? My front tires are not spaced evenly. When I crank my steering wheel to the left I have plenty of tire clearance, but when I turn to the right I get rubbing. So I took my tape measurer out and the difference between the left and right sides is amazing. Is this normal? It seems really odd to me, but I don't know what could be done about it. If a few of you could check your trucks for symmetry, I'd really appreciate it. I don't care about absolute numbers, just the differences. My driver side tire is almost centered in the wheel well while the passenger side tire is nearly an inch closer to the rear of the wheel well opening.
    Driver Side - Front edge of tire: 2 3/8"
    Passenger Side - Front edge of tire: 3 3/4"
    Driver Side - Rear edge of tire: 2 7/8"
    Passenger Side - Rear edge of tire: 2"
  2. Aug 30, 2008 at 7:43 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I'm totally stock with stock tires...and both sides measured 3.5" on front edge and 2.5" on the backside - ultimately 1" back in the wheel wells.
    Since the passenger side & drivers side are not connected (like a solid axle would be). I would assume that one side is actually 'normal' - or else you have more complicated route cause.
    A couple questions for you: How's your truck drive & when did you have an allignment done last? Does your steering wheel 'center itself' after you make a turn? - Test this going in both directions. This has a lot to do with CASTER.
    When you turn RIGHT and it rubs...WHERE does it rub?
    I'm guessing drivers side front maybe and/or passsenger side rear....or both?
    Other than that...no noises or thumps when you drive/hit a bump? Does everything mechanically look good?
    What wheels & tires are you running? What suspension?
  3. Aug 30, 2008 at 8:12 AM
    CometKat
    CometKat Well-Known Member
    Carson City NV
    08 Tacoma 4X4 Regular Cab SR5
    I think it’s likely that the cab is mounted crooked on the frame. There is another similar thread in the 2nd generation section that discusses the bed being off center. My bed is off to one side about 3/4".
  4. Aug 30, 2008 at 4:30 PM
    Vege-Taco
    Shawn
    Arizona
    The truck drives straight, no vibrations, pull, rattles, etc. I have the ToyTec C/O's up front. The truck was aligned last week.
    I've thought about the cab not being bolted down straight, but the passenger tire is actually closer to the chassis mounting bracket which is a part of the frame. Even if the cab is mounted crooked a bit it wouldn't help the tire spacing any to straighten it as the frame/cab mounting point wouldn't be moving. It's the suspension components themselves that put the tire too far back.
  5. Aug 30, 2008 at 6:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What does your printout from your alignment say? Post the numbers for me, so I can see if they are in check.
  6. Aug 30, 2008 at 6:53 PM
    Vege-Taco
    Shawn
    Arizona
    Here's the alignment sheet:
  7. Aug 30, 2008 at 6:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hmmmm......Looks pretty good. :confused:
  8. Aug 30, 2008 at 9:51 PM
    Janster
    Jandy
    Lancaster, PA
    Who installed your C/O's? Did you have these installed before or after the allignment?
    Did you just notice this? Or has it been like this since you bought the truck?
    Did you try the *steering wheel* centering trick yet (I mentioned it earlier)?
  9. Aug 30, 2008 at 9:56 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    janster.....how do you do the steering wheel centering trick, if you dont mind explaining again??
  10. Aug 30, 2008 at 10:13 PM
    Vege-Taco
    Shawn
    Arizona
    A local 4x4 shop did the installation. They are the best shop in town. Alignment was done afterward. I know nothing of this trick you mentioned, but my steering wheel is centered already.
  11. Aug 31, 2008 at 8:55 AM
    Vege-Taco
    Shawn
    Arizona
    It has nothing to do with the fender flare. The passeger side is hitting on the body mount, which is a part of the frame. Take a look at the following pictures:
    Fully cranked to the left (driver side):
    Fully cranked to the right (passenger side):
  12. Aug 31, 2008 at 9:24 AM
    Janster
    Jandy
    Lancaster, PA
    It's not a *trick*, but somewhat of a test.....
    When you have proper caster - your steering wheel should center itself after a turn without you touching it. Just make a good turn (90 degree for example) and let go of the steering wheel. It should go back to 'straight' by itself (for the most part).
  13. Aug 31, 2008 at 9:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Looking at his caster #'s, they are within spec. :)
  14. Aug 31, 2008 at 9:29 AM
    Janster
    Jandy
    Lancaster, PA
    I guess I'm just having a hard time explaining this....
    Take a drive. Make a turn onto a side street..... After you've made the turn, let go of the steering wheel and see what the truck/steering wheel does.
    Does the steering wheel and the truck straightened itself out by itselft (for the most part).
    This is a test of CASTER allignment.
  15. Aug 31, 2008 at 9:31 AM
    Janster
    Jandy
    Lancaster, PA
    Not doubting the allignment....or what's on that paper.
    But perhaps something has come loose, broken, or even perhaps the truck wasn't properly set on the allignment rack. I dunno...just throwing a 'test' out there to check.
    Anything is possible
  16. Aug 31, 2008 at 9:32 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its possible that the missalignment spacers in the lower and upper control arms arnt in the right spot. Point out the problem to them. By pushing the rear of the control arms out a little, and bringing the fronts in, it should move your axel center more twards the front of the vehicle.
  17. Aug 31, 2008 at 9:44 AM
    Vege-Taco
    Shawn
    Arizona
    This is what I'm starting to suspect at this point. I'll take it back by the shop and see what they have to say.
  18. Aug 31, 2008 at 9:50 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats the only way that I know in which to move the wheel forward and back, other than cutting the CA mounts and reattaching them. :)
  19. Aug 31, 2008 at 12:47 PM
    Janster
    Jandy
    Lancaster, PA
    How/when could that happen? During the allignment?
    You shouldn't have to mess with any of that for a spacer lift.... and if it did happen during the lift install - how did they allign it with it like that?
  20. Aug 31, 2008 at 4:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No telling how or when it could have happened. If the shop that did the install removed his CA's they may have put them back incorrectly. Odds are that didnt happen, and it was installed wrong at the factory. It can still be aligned, but the shop should have caught it and fixed the issue.
