Unholey vent mount questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 92se-r, Mar 13, 2019.
  1. Mar 13, 2019 at 12:21 AM
    92se-r
    92se-r [OP] Well-Known Member
    Do these work on the driver side vent by door? I only see them used on the inner 2 vents. Also, what are the best mounts for a ham radio controller head? Got any pics to share?
  2. Mar 13, 2019 at 1:14 AM
    Claytallica
    Claytallica Active Member
    Utah
    2018 Tacoma MGM TRDOR DCSB AT OVtuned
    5160s/6112s
    You can mount it on any of the vents. I just think most people put it on the vent to the right of the steering wheel because they are right handed. I’ve been really happy with mine so far. It’s a very solid mount.
    Fieldsy18, 92se-r[OP] and tonered like this.
  3. Mar 13, 2019 at 1:26 AM
    methodtim
    methodtim I eat a lot of salsa
    Umm... really?
    California
    17 TRD Off-Road DCLB
    Aftermarket radio knobs, woot!
    +1 they work on any of the four vents. I had considered putting it on the door vent, but the arm got in the way of my turn signal. I guess I could just stop using the turn signal as it's apparently optional for half the driving populace anyway.
  4. Mar 13, 2019 at 5:14 AM
    Loudog504
    Loudog504 Well-Known Member
    Luis
    Baton Rouge, LA
    2017 Tacoma TRD Off-Road 4X4 DCLB
    Anyone have experience running a 8-9 inch+ tablet on one of the big squeeze mounts?
  5. Mar 13, 2019 at 5:26 AM
    Virginian
    Virginian Well-Known Member
    Raleigh, NC
    2017 Tacoma Double Cab TRD Off Road
  6. Mar 13, 2019 at 5:42 AM
    Loudog504
    Luis
    Baton Rouge, LA
    Also, Anyone get the new mount design they have out? Its suppose to let you have range of motion with the vent at least up and down from what i can tell from the picture.
    92se-r[OP] likes this.
  7. Mar 13, 2019 at 8:47 AM
    Claytallica
    Utah
    5160s/6112s
    I have the newest mount and you can move it up and down but you can’t twist it. It doesn’t close all the way but it does open all the way.
    methodtim, 92se-r[OP] and Loudog504 like this.
  8. Mar 13, 2019 at 8:57 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I'm a lefty, but that was just the best spot.
  9. Mar 13, 2019 at 1:18 PM
    92se-r
    How much was the attachment?
  10. Mar 14, 2019 at 8:59 AM
    Claytallica
    Utah
    5160s/6112s
    The entire kit is $139.00 from Hondo.
    92se-r[QUOTED][OP] likes this.
  11. Mar 14, 2019 at 9:19 AM
    92se-r
    What mount do you guys think would work well with ham radio controller heads?
  12. Mar 14, 2019 at 5:57 PM
    methodtim
    Umm... really?
    California
    The mount for the unholey thingy is really just a mount for Ram Balls. If you buy the entire $139 kit, it comes with the vent mount, two ram balls, an arm, and the phone grip.
    If you want maximum flexibility, just get the vent mount for $39 and then go to ramball.com and buy the other components separately. I bought the $139 kit and ended up buying a 1" Ram Arm as the included one was a bit too long for my liking. The ramball site has a ton of radio controller mounts that would fit your needs.
    SC4333 and 92se-r[QUOTED][OP] like this.
  13. Mar 14, 2019 at 6:31 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    I do. I put in on the inner passenger side vent facing the driver. Super solid, and great quality. No vibrations. The only issue at all is it rattles off road, when empty, if you don’t tighten it up on itself, and you have to rotate the mount 90 degrees on the ramball when you switch from tablet to a smaller I-phone, which I do on occasion. Would buy the exact set up again. Really nice.
    Loudog504[QUOTED] likes this.
  14. Mar 14, 2019 at 7:16 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Thanks for the heads up.. I too was thinking the arm included in the kit was longer than I liked - just ordered the unholey mount. Then I picked up the ram ball mounts, ram arm, and ram universal x-grip (all from Amazon) making for a grand total of $87.
    tonered and methodtim[QUOTED] like this.
  15. Mar 14, 2019 at 8:36 PM
    methodtim
    Umm... really?
    California
    I ended up getting an X-Grip too, mostly out of morbid curiosity and incapacity to not spend money. I found it pretty dinky to be honest, and have come to really like the Hondo grip. The X-Grip is definitely easier to use if you have different-sized phones that you want to use on the same mount.
  16. Mar 15, 2019 at 10:30 AM
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    9.7" 2018 iPad but not in the big squeeze. RAM has a dedicated holder the iPad clips into that was cheaper for me and I used one of their octagon swivel mounts so it stays super close to the dash and doesn't bounce at all until I hit the dirt.
  17. Mar 15, 2019 at 11:16 AM
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    I use mine of the left side with a ram magnet base as the phone mount.
  18. Mar 15, 2019 at 12:30 PM
    Tuh-coh-mah
    Tuh-coh-mah Huh?
    Caluhferneeah
    17MGMTRDORDCSB4WDAT
    TRD catback, BAMF sliders, lots o trail stripes
    Same here but on the right vent - super clean setup. The phone does bounce off the magnet on rougher dirt roads, though.
