Uni Filter mod on 2.7
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Doughnut Spaghetti, May 2, 2017.
  1. May 14, 2017 at 2:15 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    OK, I got the filter from the link. How do I take it apart and get the foam filter out - I don't want to F up $1400 - do I take just the center screw out ? Do I put a knife or flat screwdriver in the crack and pry the top off ? Do I have to take the 5 or 5 screws out ? Thanks for any help, links and or instructions.
  2. May 14, 2017 at 2:37 PM
    Doogz
    Doogz Well-Known Member
    Bryce
    Western MA
    2009 MGM AC
    yep..
    You got it. Center torx screw out. And the top half separates. There's a gasket between the two halves that may give you resistance, but it'll come apart. Just hold the bottom half as well while you pull/pry the top off.
    The foam will pull right out. I'd also clean up any debris/dust from the inside.
    The cap on the outside where the new filter goes will pop off with a bit of prying with a flat screwdriver (tabs break easy so be careful if you want to preserve it to return stock config)
  3. May 14, 2017 at 2:47 PM
    george3
    New Jersey
    Thanks interrupting you Mother's Day and the fast reply - I'm just having a beer and thinking about my truck - just ain't right is it ??
    Doogz[QUOTED] likes this.
  4. May 14, 2017 at 2:59 PM
    Early B.
    Early B. Well-Known Member
    Brad
    metro Atlanta
    2014 2.7L, 5 lug Tacoma
    18" tires and rims, 2.75" Procomp lift, Fox shocks in rear.
    Just ordered mine. Thanks for the instructions.
  5. May 14, 2017 at 3:09 PM
    george3
    New Jersey
    Trying to get the cap off without destroying it - how do I do that ??
  6. May 14, 2017 at 3:32 PM
    Doogz
    Bryce
    Western MA
    2009 MGM AC
    yep..
    I think if you can wedge a few screwdrivers or something to lift up those tabs it might go without breaking any of them. I will say once one tab breaks it comes off nicely :thumbsup:
    Alexely999 likes this.
  7. May 14, 2017 at 3:36 PM
    george3
    New Jersey
    Thanks - I tried tooth picks - screwdrivers are next.
  8. May 14, 2017 at 5:49 PM
    Pigpen
    Dan
    Northwest Montana
    No
    The stock foam "filter" disintegrates and falls into the impeller, destroying the impeller and clogging lines and valves in this most unnecessary of systems.
  9. May 14, 2017 at 5:56 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    I wish I had bought stock in the company before everyone started replacing there filters LOL
  10. May 14, 2017 at 7:27 PM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    Interestingly enough my 3rd gen has a cover over that pump. Looks like there is foam in it to create a sort of gasket around the intake snout so that air can only come up from underneath.
    I think I'm going to replace mine with a Uni filter as well, but I'll be interested to see if there are any differences inside as well.
    Paul631 and Speedytech7 like this.
  11. May 27, 2017 at 4:49 AM
    Early B.
    Brad
    metro Atlanta
    Mod completed. Took 5 minutes. Used T25 torx screwdriver. Just wrangled off the front cap -- no flathead screwdrivers needed.
  12. May 27, 2017 at 5:58 AM
    Doughnut Spaghetti
    Doughnut Spaghetti [OP] Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Almost to easy right? I think the hardest part for me was getting that plastic part off thats kinda clipped.
  13. Sep 4, 2017 at 5:50 PM
    txtaco87
    txtaco87 Budget Travel Hard AF
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
  14. Oct 25, 2017 at 3:18 PM
    TacomaZL
    TacomaZL Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    Anybody have issues pulling the cover off this pump? Not the one that screws in, the one that covers the whole assembly. I see one tab and that's it. No matter how hard I pull it won't come off
  15. Oct 25, 2017 at 5:05 PM
    #35
    Nitori
    Maricopa AZ
    2021 T4R SR5
    There's 3 total tabs. Only one of them is actually visible from the outside, the other two you've gotta feel under the cover because there is an internal "ring" they are on, where it attaches to the pump itself.
  16. Oct 25, 2017 at 5:15 PM
    #36
    TacomaZL
    Illinois
    Did you have to pull wicked hard after pulling on the tabs?
  17. Oct 25, 2017 at 6:48 PM
    #37
    Hoover
    Hoover Clear alcohol is for rich women on diets.
    Hoover
    Idaho
    2005 Tacoma TRD off-road
    RevTek & 5100s. Blocked on rear. K&N intake. Fog light mod. Flashlight holder. LED interior lights.
    Do the 4.0s have this ? Specifically 2005. :thumbsup:
  18. Oct 25, 2017 at 7:18 PM
    #38
    Nitori
    Maricopa AZ
    2021 T4R SR5
    No, once the tabs are released it pops right off- but it's hard to get all 3 to pop at the same time so you sorta wiggle it. It's one of those things where when you got 2 free, the last one is a bitch to pop open because it has tension on it, and if you try to ease it back down one of the 2 freed clips pops back into its slot. :annoyed:
    There is a reason mine sits on the garage floor in a cardboard box of assorted parts.;)
  19. Oct 25, 2017 at 7:48 PM
    #39
    TacomaZL
    Illinois
    Alright, I'm sure I'll get it eventually. I'm trying to get it off and am always worried when dealing with plastic as I am afraid of breaking something. Especially this high dollar emissions bull shit.
  20. Oct 25, 2017 at 7:53 PM
    #40
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Best 15 bucks you can spend,it will more than likely save you $1,500 bucks down the road.
