Uni Filter mod on 2.7
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Doughnut Spaghetti, May 2, 2017.
  1. Jul 24, 2018 at 10:35 AM
    #61
    casey2012
    casey2012 Well-Known Member
    mark
    yota
    none
    why does every one say there paying 1400 bucks for a air pump i have 12 tacoma 2.7 have a friend who works at napa 2 years ago mine went bad he found me one for 235 bucks brand new
  2. Jul 24, 2018 at 7:07 PM
    #62
    dawgn86
    dawgn86 Well-Known Member
    2013 Toyota Tacoma
    I cut an old credit card into 4 pieces and slid them in the tab slots to loosen and cap popped right off
    ethanfiamingo likes this.
  3. Jul 26, 2018 at 6:05 PM
    #63
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    Took off the cap easy, pulled and that plastic end cap popped off, put the new filter on and done in about 7 mins. If you don’t have the torx like me, I used a 1/8” hex key. It’s not like you’re bolting something onto an airplane. It comes off very easily with the hex key.
  4. Jul 26, 2018 at 6:13 PM
    #64
    phuphyter
    phuphyter Well-Known Member
    pennies work too
    dawgn86[QUOTED] likes this.
  5. Jul 26, 2018 at 6:56 PM
    #65
    Tnronin
    Tnronin Two things in this world smell like fish!
    Mitchell
    Cookeville TN area
    2006 DCSB OFFROAD
    If you are in Cookeville this Dumb-ass bought one for a truck that doesn't need it. I'll GIVE it to you sort my own personal stupid tax
    Clearwater Bill likes this.
  6. Jul 27, 2018 at 7:54 AM
    #66
    Clearwater Bill
    Billy
    Largo Florida
    What happens if this 'system' is simply disconnected?
    Cap off the nipple on the engine side, unplug the harness, etc.
    I'm assuming a CEL will fire off.
  7. Jul 28, 2018 at 7:48 AM
    #67
    Pigpen
    Dan
    Northwest Montana
    I've been told that you can't simply delete the system without complications, even when using the bypass options currently on the market. Those rely on the presence of the pump. With the bypass, you can delete the valves and cap them off, but the pump still needs to be present.
  8. Jul 28, 2018 at 7:52 AM
    #68
    i/o
    i/o Active Member
    Richard
    San Antonio Texas
    2013 Limited Double Cab PreRunner Pyrite Mica
    Maybe they are including dealer markup of the part and labor to swap out
  9. Jul 28, 2018 at 8:54 AM
    #69
    Pigpen
    Dan
    Northwest Montana
    $1400 was for replacement of the whole system before Toyota stepped up and started covering the whole thing.
  10. Jul 28, 2018 at 10:25 AM
    #70
    Clearwater Bill
    Billy
    Largo Florida
    So now part of the 8yr/80k emissions coverage?
    Think I'll do the filter mod anyway. Keep OE filter and cap to return to stock if emissions warranty is needed or recall occurs.
    Cause you know they would lay a failure at the feet of that uni filter. Just because they could.
    Kolter45 and Skyway like this.
  11. Jul 28, 2018 at 11:02 AM
    #71
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    ordered one for my '14 4.0L yesterday...Amazon
    must have got the last one......Orange Cycle 3rd party ?
  12. Jul 28, 2018 at 5:25 PM
    #72
    Pigpen
    Dan
    Northwest Montana
    I think the filter mod is well worth it. I think the slyfox75 mod is worth the $50 to avoid the hassle of the system failing. I need to pull that one off my 4.0 because it doesn't do anything on these models. I'm happy I did the filter mod though.
  13. Jul 28, 2018 at 5:51 PM
    #73
    Clearwater Bill
    Billy
    Largo Florida
    Not familiar. For a 2.7? If so, link please? :hattip:
  14. Jul 28, 2018 at 6:01 PM
    #74
    i/o
    i/o Active Member
    Richard
    San Antonio Texas
    I did this mod today, so easy to do and well worth it
    Skyway likes this.
  15. Aug 4, 2018 at 4:24 PM
    #75
    Clearwater Bill
    Billy
    Largo Florida
    So I did this this evening. Slick. I'm saving the OE filter and intake cap, so if something else should fail with the pump system prior to my emissions warranty expiration I can return it to stock before my visit to the dealer.
    Put it back. It makes a cleaner look to the device, but more importantly provides about a 270* splash shield for the filter. When reassembled it looks totally stock at a glance.
    Very creative. I agree, I'd be reluctant to leave it totally exposed in a wet climate. But the factory lid covers it so well, I'd look for one if I were you. Maybe a pick & pull part?
    I used 4 hooked paint can lid openers. When all positioned it just falls off. I could find those faster than pennies around my house. :D
    My truck has few miles, but is approaching 7 physical years old. The OE foam was pliable, but dry. I prefer this filtration method over trying to disassemble and lubricate or replace the OE foam on a periodic basis.
    I see Amazon is still out of stock. It was when I went to order last week. I got mine off eBay for a few cents difference in price with free shipping. It ships USPS from Ohio, 1st class, so it arrived in 2 days.
    #75
    Skyway likes this.
  16. Aug 5, 2018 at 9:55 AM
    #76
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    Congratulations Bill!
    I did mine last month as well....
  17. Aug 8, 2018 at 8:06 AM
    #77
    Newbie2016
    Newbie2016 New Member
    Anyone know if the secondary breather on the 3rd Gen 2.7 still uses a one-inch flange opening?
  18. Aug 20, 2018 at 1:52 PM
    #78
    CE69
    CE69 Active Member
    Chad
    2015 Blue Ribbon TRD Sport
    Did my filter mod last weekend! I guess I broke (cracked) the cover :mad:, the one with the single torx center bolt, when I removed it. Does anyone have one or know where I can find one? No luck on E-Pay and Toyota only sells it as a complete unit $500!
  19. Aug 21, 2018 at 3:37 AM
    #79
    CMD-KY
    CMD-KY Well-Known Member
    South Central Kentucky
    2104 Tacoma AC SR5 4wd
    Salvage yard? JB Weld?
  20. Aug 21, 2018 at 11:04 AM
    #80
    DRP6833
    DRP6833 Well-Known Member
    Dave
    Frederick, CO
    2014 Tacoma I4 4WD
    Did mine this weekend, too. My foam filter looked good for 50K but why take a chance?
