Uniball vs Balljoint
Discussion in 'Suspension' started by Johnny2525, Mar 16, 2015.
  1. May 3, 2018 at 8:56 PM
    #41
    BlownOutTaco
    BlownOutTaco Well-Known Member
    Shane
    2018 Black DCLB OR
    I live at the beach in SF (salt, fog, sand). Which Camburg UCA is the right call you think? Thx.
  2. May 4, 2018 at 12:51 AM
    #42
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    I'd go UB UCA's. My Camburg UCA's have been phenomenal. My original uniballs have had to be replaced last fall. I bought and used a 1" uniball press from All German Motorsports and it was simple. The uniballs lasted 60k miles. (They were way loose and not intended to go that long.)
    FK Uniballs have a static radial load rating of 90,000 lbs and are extremely strong. Part# is (AIN-16T) With a rating like that, there are lots of things that will fail first with those kinds of loads on a mostly stock vehicle. You're looking at $100 every few years for maintenance with uniballs. My first set of uniballs were a bit noisy. When I replaced them, they didn't have FK stamped on them like the new ones did. They may not have used FK way back. The FK's have been ghost fart quiet for 6 months with absolutely nothing done by me as far as lube goes.
  3. May 4, 2018 at 7:47 AM
    #43
    schmidt4brains
    schmidt4brains Highway Warrior
    Texas
    2016 TRD Sport. DCSB. MGM. 2WD.
    255/75R17 Michelin L/T Defender Speaker upgrades: Front JBL GT7-96, Subaru H631SFJ01 Tweeters, Rear JBL GT7-6 Auxbeam FS-16 low beam LED bulbs AC drain extension Removed front bumper air dam Eibach Pro Lift kit Headstrong 3Leaf AAL (left in overload)
    Check out the JBA UCAs. They are high castor Moog ball. There has been a lot of talk about them in other threads.
  4. May 4, 2018 at 10:17 AM
    #44
    BlownOutTaco
    Shane
    2018 Black DCLB OR
    No lube and ghost farts... I’m in! :) thx I think I’m leaning uniball for sure
    JJ04TACO[QUOTED] likes this.
