Unknown Popping Sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jagergirll, Oct 24, 2016.
  1. Oct 24, 2016 at 4:13 PM
    #41
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    I had a pop on mine that went away with a 1.25" Spidertrax spacer on the front end. I'm not sure what caused it but I can turn full tilt and hit bumps again.
  2. Oct 24, 2016 at 8:52 PM
    #42
    jagergirll
    jagergirll [OP] Well-Known Member
    Sam
    Midwest
    4x4 RC
    OME Suspension ARB Bumper Rock Sliders BFG KO2 A/T 245/75R16 Camper Shell
    Interesting. I don't have any sounds when I hit bumps. How did you end up putting a spacer up front?
  3. Oct 24, 2016 at 9:19 PM
    #43
    digitaLbraVo
  4. Oct 25, 2016 at 9:15 AM
    #44
    DrFunker
    DrFunker Well-Known Member
    Just got my truck back.
    Indeed the LCA bolts were not torqued enough and the alignment was also slightly off.
    Realigned and retorqued the bolts.....no more pop.
    :woot:
  5. Oct 30, 2016 at 9:29 PM
    #45
    jagergirll
    Sam
    Midwest
    4x4 RC
    So after checking out my taco this weekend I am assuming for now that the LCA bushing is toast. It's popped twice in 2-3 months and I can't find anything else. The boot to the tie rod end does have a tear but there is no play in the tire and the alignment seems good. There's no vibration in the steering wheel while driving yada yada so I'm going as is on my climbing trip and if something happens maybe I'll put out the taco signal if needed in the southwest region. Thanks for all the ideas and if something solid comes up I'll update the thread. Thanks!
  6. Jan 9, 2019 at 6:52 AM
    #46
    anomalyTRD
    anomalyTRD Well-Known Member
    Oakland, CA
    2019 Ford F150
    VO Nomad
    I have exactly this issue. Any danger of catastrophic failure or can it wait till I go LT? It's been like that for probably 6 months now.
  7. Jan 9, 2019 at 7:00 AM
    #47
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    As long as the LCA bolt is intact then the only damage that I see that can happen is your tires will get chewed up.
  8. Jan 9, 2019 at 7:06 AM
    #48
    anomalyTRD
    Oakland, CA
    2019 Ford F150
    VO Nomad
    The bolts are in good shape, properly torqued and not frozen. Alignment is both good and adjustable. The LCA cam tabs were totally folded over by some tech at Firestone when doing the alignment a while back but it hasn't caused an issue. The bushing is just totally shot.
