Unsuccessful Leaf Spring Replacement 03 4x4
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hoyle, Sep 18, 2011.
  1. Sep 18, 2011 at 1:35 PM
    Hoyle
    Hoyle [OP] Well-Known Member
    Cookeville TN.
    2014 DCSB 4x4 Black
    A lot of stuff.
    Today I attempted to replace my worn out leaf springs with new leafs from AllPro, the All-Pro Standard Duty Leaf Springs. Everything was completely removed until I attempted to remove the front bolts out of the bushing… NOT SUCCESSFUL .. the front bolt would not budge!.. It seems the rubber bushing has become one with the bolt.. I turn the bolt.. but the bushing turns as well… I had to put it all back together to drive it out of my friends garage..
    Suggestions on how I get the front Leaf Spring Bolt out of the bushing!..
    Thanks
  2. Sep 18, 2011 at 1:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I think you have to burn it out with a torch.
  3. Sep 18, 2011 at 1:38 PM
    98tacoma27
    Ben
    Not Beech Creek
    Or cut the bolt off.
  4. Sep 18, 2011 at 1:39 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
  5. Sep 18, 2011 at 1:41 PM
    Hoyle
    Cookeville TN.
    2014 DCSB 4x4 Black
    A lot of stuff.
    Are you suggesting cutting the bolt on each side, inside the bracket.. will my sawzall cut that pin?
  6. Sep 18, 2011 at 1:42 PM
    scocar
    scocar hypotenoper
    Angle grinder is a good method. Common approach w/seized main eye bolts on our crusty old first gens.
  7. Sep 18, 2011 at 1:43 PM
    scocar
    scocar hypotenoper
    An angle grinder will. I think others have used a sawzall and gone through several blades and several f-bombs.
  8. Sep 18, 2011 at 1:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If you squirt WD40 on the blade, you shouldnt hurt it.
  9. Sep 18, 2011 at 1:44 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Yes if you have a decent recip saw and a good blade. Also, a BFH and a punch works wonders as well.
  10. Sep 18, 2011 at 1:44 PM
    Hoyle
    Cookeville TN.
    2014 DCSB 4x4 Black
    A lot of stuff.
    Do I have to get replacment Pins from the Dealership?
  11. Sep 18, 2011 at 1:47 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    wheelers offroad has the main eye bolts. Just use a sawzall and with the correct blade + Lube it should cut like butter.
  12. Sep 18, 2011 at 1:48 PM
    scocar
    scocar hypotenoper
    Not necessarily. You can order them from Wheeler's Offroad, just down the road in Grants Pass, or you may be able to find a close match at Lowe's. The stock ones are ~4.5 inches long. Lowe's has 4 in and 5 in. grade 8s. Watch the side near the gas tank. Not much clearance.
  13. Sep 18, 2011 at 2:32 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Its a stud, it has to knocked out. Use a BFH and a driving pin or old screwdriver..whack.it out. Soak it in grease or lube first if you want.
    Then go down to local hardware store and get grade 8 replacements..easy peasy
  14. Sep 18, 2011 at 5:58 PM
    exminnesotaboy
    exminnesotaboy Well-Known Member
    Maple Grove, MN
    01 Tacoma 4x4 V6 SR5 TRD Xtra Cab
    Bilstein 5100's / OME 881's / Wheelers 5 leaf pack / Level8 MK6/ 265/75-16 Bridgestone Dueler tires
    I had the same issue. I got grade 8's from the local hardware store when I had to sawzall the old ones out. I have replacement ones now from Toyota($10 from dealer), but haven't put them in yet.
  15. Sep 18, 2011 at 6:41 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Thats how I got mine out. Put the cutting wheel between the leaf and the bracket. My old bolts were still siezed in the leafs when I brought them to the metal scrap yard.
