upcoming truck for sale in 2 or 3 months, doubt sooner, got questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by CodeSeven, Aug 3, 2022.
  1. Aug 3, 2022 at 9:37 PM
    CodeSeven
    CodeSeven [OP] LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    Hey, peeps.
    I'll most likely be selling my truck here soon. What other info should I include when putting my truck up for sale? it's basically stock except for the radio and bilstein shocks all around w/ 3" lift. I know to include pics. probably going to start at 12k, still needs a little work and a paint job.
    info
    1) 2000 Taqo
    2) bought in 2013 w/ 185k now has ~235k. im supposedly 2nd owner, 1st only drove truck between LA and Palm Springs
    3) v6
    4) manual
    5) 4wd
    6) moonroof
    7) stock tires
    8) synthetic oil change every 5k miles
    9) So Cal car whole life no rust!
    10) A/C could be better but I live in a desert that gets above 110f.
    11) Viper alarm w/remote start
    Modded
    1) front turn signals & cornering light swap. ran a 2 wire and crossed grounds. installed clear front turn signal lamps (not amber).
    2) PO had "clutch start cancel" bypassed for remote start to work.
    major work done since I've owned it (9 years)
    1) fuel injectors
    2) plenum/throttle body gaskets
    3) valve cover gasket
    4) Starter
    5) timing belt kit w/ water pump + A/C Idler pulley
    6) bilstein shocks w/ 3" lift
    7) front axles
    8) both cats
    9) center support bearing
    10) both diffs and tranny fluid replacement
    11) rear wheel seals
    12) brakes all around
    13) power steering pump
    14) energy rack bushings
    15) front sway bar links
    16) energy body bushings
    17) lower control arms and ball joints
    18) radiator
    19) charcoal cannister
    20) brake booster and master
    21) clutch kit +master, slave, and hose
    22) FPR
    23) Fuel filter plugs wires air filter pcv valve battery intake hose air filter box
    24)
    wanted/needed repairs
    1) P.S. Hoses
    2) upper arms & ball joints
    3) mmaaayyybeeee rack and pinion
    4) tranny rebuild for shits and giggles? truck pops out of 1st if you don't hold stick in gear when accelerating.
    5) paint job with HD single stage paint.
    I think that's all.
  2. Aug 5, 2022 at 5:45 AM
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
  3. Aug 5, 2022 at 5:52 AM
    Jakuku Pahwheenis
    J Phoenix
    South Carolina
    These came with a sunroof option?
    CodeSeven[QUOTED][OP] likes this.
  4. Aug 5, 2022 at 9:17 AM
    CodeSeven
    Serge.
    Coachella Valley
    also why I'm asking. Seeing trucks go for over 15k, so i figured i'd start that high and go down. Maybe more like 9,500 :notsure:
  5. Aug 5, 2022 at 9:19 AM
    CodeSeven
    Serge.
    Coachella Valley
    Moonroof, my bad
  6. Aug 5, 2022 at 9:20 AM
    Jakuku Pahwheenis
    J Phoenix
    South Carolina
    That means it only opens at night then right? :anonymous:
  7. Aug 5, 2022 at 11:09 AM
    CodeSeven
    Serge.
    Coachella Valley
    :notsure:
  8. Aug 5, 2022 at 8:11 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Why would anybody put a picture of their butt on their car roof?
    joeyv141 and CodeSeven[OP] like this.
  9. Aug 5, 2022 at 8:19 PM
    O'Silver_Taco
    MD
    If body and interior are so-so.....I'd say 10K to 12k....
    If body is stellar, then the sky's the limit.......especially on the west coast....
    CodeSeven[OP] likes this.
  10. Aug 5, 2022 at 8:29 PM
    CodeSeven
    Serge.
    Coachella Valley
    For the police helicopters
