Upcoming wiring project
Discussion in '2nd Gen. Tacomas (2005-2015)' started by danteisme, Oct 31, 2012.
  1. Oct 31, 2012 at 7:24 PM
    danteisme
    danteisme [OP] Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    **warning, i may ramble***
    ok, so i want to make sure i have everything on hand for my upcoming wiring project. i want to wire an aux. fuse block in my truck to distribute power for my fog lights, off road lights on my brush guard, my reverse lights that will be mounted on my bumper, and for my power inverter. i've been doing some research, and there is some gaps in my information.
    when i run my power to my fuse block, should i use another inline fuse from the battery to the fuse block?
    with all of my lights, i plan to run relays so i'm not sending power straight from the fuse block to the switch. now here is my thoughts on the power inverter. i'm looking at one that is 400 watts continuous, is it even possible to run wires from my blue sea fuse block to a relay then to the inverter? i'm fairly certain that will have to be a pretty large gauge wire. if you are wondering why i want to run it off of a switch, i plan to mount the inverter under the seat so if i can just use a dash mounted switch rather than fish around under the seat for the on off switch i would much rather do that.
    what gauge wire should i run from the battery to the inline fuse or whatever to the fuse block? from what i've read, i need to add up all the demands for everything i intend to run off the block, correct?
    thats all of the questions i can think of right now. i'm sure i'll think of more as i get into this.
    thanks!
  2. Oct 31, 2012 at 7:30 PM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
  3. Oct 31, 2012 at 7:32 PM
    Drunknsloth
    Retribution
    South West
  4. Oct 31, 2012 at 7:33 PM
    danteisme
    South Western PA
    ah thank you for posting that. i missed that one some how. i'll go through that and then come back if i have anymore questions
  5. Oct 31, 2012 at 7:34 PM
    Drunknsloth
    Retribution
    South West
    Sounds good. I would look at the specs of the inverter you want to get and see what the amp draw is on that, then base your wire gauge and relay off of that.
  6. Oct 31, 2012 at 7:37 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    on that inverter it is not 4 amps draw. if you run 400 watts thats about 34amps draw. 400/12=33.33 amps.
  7. Oct 31, 2012 at 7:40 PM
    Drunknsloth
    Retribution
    South West
    Alright, yeah I'm not to familiar with inverters. I figured it was the output volts that you calculated with.
  8. Oct 31, 2012 at 7:50 PM
    2000GTacoma
    Snow Hill NC
    well depends on what you are discussing. in ops case he needs the draw which is 34 amps. if you want to power something off the inverter about 4 amps is all that can be powered off the inverter which is not much. as you said there 400/110=3.63 amps
  9. Nov 1, 2012 at 5:54 PM
    danteisme
    South Western PA
    well i've been researching on my upcoming project. i think i may have found a hiccup in my plans. my fuse block says it "give 30 Amperes rating per circuit". my 400 watt rms power inverter (assuming it never goes into the peak demand) will require 32 amps.
    i figure my total amp demands (using 12.5 volts) will be 70 amps, but i'm not sure if my fuse block can handle it (it has 6 available slots), mainly because the inverter requires 32 amps and thats assuming it never goes into peak demand.
    i think the most i would be plugging into the inverter would be my laptop or maybe my charger for my led drop light. i actually probably dont even need an inverter as high was 400 watts rms.
  10. Nov 3, 2012 at 3:13 PM
    Drunknsloth
    Retribution
    South West
    At this point I would just wire it to it's own fuse separate of the fuse block.
  11. Nov 3, 2012 at 4:34 PM
    2000GTacoma
    Snow Hill NC
    use a distribution block. one big wire runs to the distribution block. then 2 smaller yet still big wires. the distrubution block has 2 large fuses. still a good idea to put a large inline fuse close to the battery though.
