*UPDATE* Remote Tailgate Lock Fuse Location
Discussion in 'Technical Chat' started by Devious6, Jan 28, 2023.
  1. Jan 28, 2023 at 2:05 AM
    Devious6
    Devious6 [OP] Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    I know I've seen this somewhere but either the coffee isn't working yet or I'm just having a bad day, but I can't find the thread that showed the fuse location for the remote power tailgate lock.
    Mine isn't working - actually not sure it ever worked - but was told it was installed when I purchased my truck. I guess I'd better pull the access cover to make sure it's really there.
    Would someone please tell me where the fuse is located?
  2. Jan 29, 2023 at 12:40 PM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    It should be the same fuse as for the power door locks as it uses the power door lock switch. That's if it's OEM and not some aftermarket hack job. If you have a separate switch for it, it's not an OEM installation.
    Devious6[OP] likes this.
  3. Jan 31, 2023 at 11:07 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The fuses on mine are the harness near the connectors at the kick panel.
    Devious6[QUOTED][OP] likes this.
  4. Jan 31, 2023 at 5:41 PM
    Devious6
    Mark
    It's OEM - sounds like it's trying to throw but won't engage.
  5. Jan 31, 2023 at 5:58 PM
    HisDad
    Texas at last
    It doesn't sound like a fuse. Since it's a 2020 it's likely out of warranty. Depending on how handy your are, you can removed the tailgate inner panel and see what happens when the switch is thrown. You'll need a helper, of course.
    I installed mine back when I got the truck, so I don't remember the details.
    This thread here, URL="https://www.tacomaworld.com/threads/2019-tailgate-lock-pn-pk3b6-35js0.637471/#post-21973091"]2019 Tailgate Lock - PN: PK3B6-35JS0[/URL] has a link to the PDF instructions.
    It will show you what the tailgate lock set up should look like. You can compare that to yours to see if something is loose or fell off.
  6. Jan 31, 2023 at 6:44 PM
    Devious6
    Mark
    Thanks!!!
  7. Jan 31, 2023 at 6:47 PM
    HisDad
    Texas at last
    You're welcome.
  8. Jan 31, 2023 at 8:08 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That sounds like an actuator issue. Check in the TG for sure.
  9. Feb 6, 2023 at 1:04 PM
    Devious6
    Mark
    I took my truck into the dealership - turned out either the actuator was improperly installed or a nut came loose at some point causing the lock to fail to engage. After a bit of discussion they agreed that, since it was dealer installed as part of the original purchase, it was covered under the 36 month/36k mile Toyota Warranty. As it turned out, today was the exact date of my 36 month purchase anniversary! :eek::thumbsup: They put in the new actuator and it works like a champ.
    tonered, HisDad and Justified like this.
  10. Feb 7, 2023 at 8:40 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Good stuff. It is unfortunate that it took a discussion to get there, but at least it was properly taken care of.
    HisDad likes this.
