***UPDATED*** 3rd Gen Multimedia Updates
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ktbell444, Nov 28, 2020.
  1. Dec 1, 2021 at 8:59 AM
    #281
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Does anyone know what the update actually takes care of?
  2. Dec 1, 2021 at 9:03 AM
    #282
    ktbell444
    ktbell444 [OP] One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Take a look at the appropriate TSB that is attached in the first post...
  3. Dec 1, 2021 at 8:23 PM
    #283
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    i used the same usb stick i used to do the last update. still had only the previous file on it so i deleted and put the new files on and was unable to see an update doing the same things in the same way that i did last time. i'll try again tomorrow but i don't know if i even care - i only experience the occasional reboot and none of the other symptoms mentioned
    ktbell444[QUOTED][OP] likes this.
  4. Dec 2, 2021 at 7:11 AM
    #284
    TacoTruck808
    TacoTruck808 Well-Known Member
    Oahu in the Aloha State!
    2016 Tacoma TRD Sport DCSB, Prem & Tech Pkg, MGM
    Thanks Op! My HU kept rebooting every other day and it was frustrating having to choose my USB music everytime it did this. It was happening more frequently for the past 6 months or so. I just did the update yesterday so we will see if it fixes the problem.
    ktbell444[OP] likes this.
  5. Dec 2, 2021 at 9:43 AM
    #285
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    I'm on 0101a4 from January this year. If that is the current update then I'm still having the random reboots.
  6. Dec 2, 2021 at 10:36 AM
    #286
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    Then I'd pull the cover, unscrew the radio mounting screws and reseat all plugs in the back, at a minimum.
  7. Dec 2, 2021 at 11:11 AM
    #287
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Yes, that is according to the TSB (assuming A5 doesn't apply to headunits that updated to A4)
  8. Dec 2, 2021 at 3:21 PM
    #288
    Meclizine
    Meclizine Well-Known Member
    CA
    '18 DCLB OR
    Thanks, OP. Although it was a challenge to find a USB drive small enough, I found an old 16gb MicroSD card that I put in an adapter. Updated without issue but I haven't really had problems with the previous firmware. Just wanted to be up to date. Thanks!
  9. Dec 10, 2021 at 12:34 PM
    #289
    Absolut_Boost
    Absolut_Boost Well-Known Member
    Cincinnati, OH
    2021 Tacoma TRD OR DCSB Cement
    thank you for sharing. my 2021 I bought in July had 1730 installed, makes me wonder how many updates they put out in a year that we are at 1785 now.
  10. Dec 10, 2021 at 2:31 PM
    #290
    NorrinRadd
    WA
    It's just software minor updates. As a developer, whenever I make a change, even minor such as fixing a typo, I have to check it back into source control, and thus it gets assigned a new version number. Normally these are minor revisions, but each system is different and I don't know what the Toyota (or head unit manufacturer) uses. BUT at any rate, almost always the number won't be sequential. So, not to worry. Probably there are only one or two actual public releases in a year, if that many, but the values will be very far apart due to internal development. Which means, at least, that they are actually working on the software and not just letting it get stale.
  11. Dec 11, 2021 at 7:34 PM
    #291
    TacoTruck808
    I was hoping the new firmware would fix the problem but my HU still reboots as much as it did prior to the update.:annoyed:
  12. Dec 11, 2021 at 7:42 PM
    #292
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    If you have navigation, see if removing the SD card fixes your reboot issue.
  13. Dec 11, 2021 at 8:08 PM
    #293
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Removing the nav SD made the navigation better because I had to use Google maps
  14. Dec 11, 2021 at 8:44 PM
    #294
    AusBerg
    AusBerg Well-Known Member
    Austin
    North MN
    2022 TRD OR DCLB
    what about 2022s?
  15. Dec 11, 2021 at 8:47 PM
    #295
    Montana_Actual
    Montana_Actual ;)
    I updated at the dealer, without having to connect any USB. Isnt that the same thing? Or is this a different type of firmware update I'd have to check also?
  16. Dec 12, 2021 at 5:05 AM
    #296
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    There was no update at the time I updated this thread.
    Different update. These updates are usually fixes for issues, whereas the OTA update you mentioned can bring new features.
  17. Dec 12, 2021 at 2:54 PM
    #297
    Montana_Actual
    Montana_Actual ;)
    I thought so. Since mine has not been done or checked, I'll check it and have the dealer update firmware when they have the truck this week for all my other stuff going on.
  18. Dec 16, 2021 at 4:41 AM
    #298
    Danbest82
    Danbest82 Member
    Dan
    Northern Westchester, NY
    2019 Toyota Tacoma TRD Off Road 6-speed
    P265/75R16 Falken Wildpeak AT3W on stock Rims Spidertrax 1.5in wheel spacers Alldogs Offroad RCKilla 2" Coil Spring & 1.5" AAL(with overload spring) for about 2" lift. Bilstein 5100s front and rear [great setup. Soft but handles well] - need to upgrade spring to heavier rate though Lil b's hybrid front bumper mid-bar with prismatic powders cast black NY Westchester Coatings Aurora 3" cube amber led fogs(offbrandproducts.com) Apex badlands 12k lb winch TRD Pro Grill Aurora 30" NSSR white led (offbrandproducts.com) Aurora 10" NSSR amber led x2 (offbrandproducts.com) Weathertech vent visors Weathertech bug deflector BAK Revolver X2 Truck Bed Cover R4T tailgate lock AC drip tube mod RCI aluminum engine skid plate Caliraised premium roof rack with 360 light cutouts[stainless hardware upgrade, Fuck that rust-prone shit they sent with it] Aurora scene rear lights TRD reusable air filter K&N reusable cabin air filter AJT designs blackout vents and 4x4 knob Air on board switches Tacomods Anodized Aluminum Radio Knob eBay heated seats with rotary dial SpeedForm Throttle Controller Husky weatherbeater floor liners
    Thanks a lot for this! I updated my radio this morning before work. Unfortunately with that I could not partake in the most important step, beer with the boys. I'll make up for it later though. Haha.
    ktbell444[OP] and BOMBS like this.
  19. Dec 17, 2021 at 9:36 AM
    #299
    TacoTruck808
    I will try that. Thanks!
  20. Dec 17, 2021 at 9:58 AM
    #300
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    How does the OTA update happen?
