Updated T-SB-0326-08 Oil Leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BeefTaco, Oct 31, 2008.
  1. Nov 14, 2012 at 1:12 PM
    BlazeAce
    BlazeAce Well-Known Member
    AL
    04 Super White
    Airbox
    Start by removing the connector for the MAF.
    Remove this hose from the airbox.
    Loosen this screw to release the clamp's grip on the throttle body.
    Remove these 2 bolts.
    Remove this hose. At this point, check the airbox for plastic clips that will keep it from being removed(they are generally attached to electrical looms). Once they are off, lift the airbox while pulling it away from the throttle body. You may need to twist airbox to get it to release.
    Upper Intake Manifold
    Remove the coolant hoses from the throttle body and clamp/cover them with saran wrap.
    Detach the electrical connector from the throttle body. Go ahead and remove this support bracket by removing the 2 bolts.
    Remove the hoses shown in the picture from the upper intake manifold. Cover them as you did the others.
    Detach the electrical connector in the picture. Then remove the brackets held on by the 4 bolts(1 not pictured).
    There is a bracket that supports some hoses hidden behind the upper intake manifold. It is easier to remove the bracket by removing the bolt than detaching the hoses from the bracket. It is pictured with the UIM removed.
    There are 2 nuts and 4 hex head bolts to remove here. After removing these, check for any plastic clips just as you did with the airbox. It should then lift off(watch for hoses blocking your path at the back).
    No more hanging wires!
    Time to get those pesky electrical harnesses out of the way. But first, carefully wipe the intake holes:confused: and then cover them with tape. Don't want anything to fall in there!
    Then the fun begins! You may feel the want to label all of this, but it really will just fall back into place when you go to reinstall it. Carefully disconnect the electrical connectors from the coils, fuel injectors, and VVT system components(ones up front). There are multiple plastic clips attaching the wire looms to the valve covers. To remove them, put a screwdriver under them and lift. There was a ground wire on the driver's side near the alternator that I removed to gain clearance, and there may have been something on the passenger side too, but I can't remember. Just make sure you have the clearance you need and label anything you take off.
    I secured the wire looms to the firewall using zipties.:anonymous:
    More coming soon!
  2. Dec 13, 2012 at 11:02 AM
    SecondGenDave
    SecondGenDave Member
    Crawling under my truck this past weekend, I found oil building up. I purchased an aftermarket warranty when I bought my truck so I just took it in for them to check out. They called today and yup, timing cover was leaking. Fully covered by my warranty minus the oil filter. $100 deductible +$5 for the filter and I'll be all fixed up. After looking at some of these DIY pics, I'm glad I got the warranty.
    *picked up my truck tonight. Total cost would have been $1300 out of pocket. Oof.*
  3. Jan 30, 2013 at 11:17 AM
    tacomaSuper619
    tacomaSuper619 New Member
    Michael
    El Cajon
    lifted tacoma, Supercharged, Robby Gordens Rims, Bfg 285-70-17, Total Chaos lift spindles, Built right upper control arms, bilstein 5150, National springs
    i have a question i have a 2007 tacoma 4.0 with 110,000, my timing cover is leaking, but i have a question i have a factory supercharger is the teardown the same or are there additional steps to complete the job, any info will help me, this will be the first time doing a big job on my truck
  4. Jan 31, 2013 at 12:59 PM
    BlazeAce
    AL
    04 Super White
    tacomaSuper619: I would probably say that it would be best to be sure that you are prepared to uninstall and reinstall the supercharger, though I could only say for sure if I knew exactly how it is installed. My advice to someone who has never done a big job on his truck is, yes you can do it, but I would get help from someone who is knowledgeable if possible. Also, I have been lazy and not finished my write-up, so hopefully I can change that soon.
  5. Feb 4, 2013 at 5:50 AM
    RieRie
    RieRie Member
    Sherie
    SE Texas
    06 PreRunner SR5
    Why isn't there a recall!? Wished I would've read this 2 years or 45k ago!!! Dealership is wanting to charge me $1300 to replace a $15 part like everyone is talking about ... hoping to find someone / place else to change this for less out of pocket
  6. Feb 4, 2013 at 6:26 AM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    anyone have any pics of what this leak looks like? my fucking dealer wants to charge $45 bucks if i bring it in and it in fact is NOT leaking... so i want to make sure it is before i do it...
  7. Feb 4, 2013 at 7:24 AM
    BlazeAce
    AL
    04 Super White
    You will be able to see this easy. I had a oily, gunky slick down the passenger side of the engine all the way back to the transmission. If your power steering pump is covered, this will probably be the culprit(that or a bad valve cover gasket). Here are the pics you requested.
    Arrow points to where the leak was coming from. It was not clear where exactly the leak was until the timing cover was removed, but it ended up being exactly where the TSB said it would be.
    I knew it wasn't the valve cover because there was no seepage present until the arrow.
    The valve cover after it was removed and partially cleaned up.
    And here is the proof that it was leaking out the side. Sorry the picture is a bit blurry, but its all I got.
    Like I stated before, I will get the rest of this write up done, but I also have a med school application I am working on, so this might take a while. If I would have had any kind of warranty, I would have taken her in, but as the 2nd owner at 90000 miles, there was nothing I could do. Hope this helps you identify your problem.
  8. Feb 4, 2013 at 7:31 AM
    BlazeAce
    AL
    04 Super White
    Sorry you are having this issue too...I think the reason it isn't a recall is there is no apparent risk of bodily harm. They only do recalls when something is unsafe. I guess until someone's truck goes up in smoke, we have to deal with it. The real issue with the cost isn't the parts, but the labor. If you have a reputable independent shop near you, I'm sure they could do it cheaper. Toyota charges an arm and a leg just to take a look! Maybe I'm just cheap:)
  9. Feb 6, 2013 at 8:15 AM
    RieRie
    RieRie Member
    Sherie
    SE Texas
    06 PreRunner SR5
    Guess I'm pretty cheap myself because I pulled out the paper work that I kept for my 'Platinum Extra Care Service Agreement' & it as far as I can tell this should be covered with this warranty. Called to confirm this from the Extra Care call center & now awaiting a call from the local service department to see if they will in fact cover this with the extra coverage I purchased or once again try & blow smoke. Fingers crossed that the $$ I've saved up for wheels & tires doesn't have to go towards this instead ... thanks for everyone's 2-cents & especially for this forum ... I've been able to read through all different topics that it's answered so many questions I was unable to find any where else HI5!!!
  10. Feb 24, 2013 at 3:23 PM
    jasonav
    jasonav Member
    atlanta
    05 4door v6 long bed
    a lot of you talk about TSB what is that??
  11. Feb 25, 2013 at 6:28 AM
    BlazeAce
    AL
    04 Super White
  12. Mar 11, 2013 at 8:30 PM
    undecided
    undecided Well-Known Member
    Adam
    San Diego, CA
    06 TRD Sport 4X4
    CAI, CB radio, Double Din Stereo, Aero Exhaust, Softopper, BHLM, KODE Push Button Start, Bruteforce Fab Rear bumper, Weathertechs
    Thanks for everyone's input! I have to set the time aside to do this
  13. May 3, 2013 at 6:51 PM
    undecided
    Adam
    San Diego, CA
    06 TRD Sport 4X4
    Starting on this endeavor, with the help from my buddy. I cant wait to get this done. It has been haunting me for the last 2 months
  14. Jun 18, 2014 at 9:12 AM
    tlamhain
    tlamhain New Member
    Theresa
    07 Double Cab 4WD
    Just got a call from the dealer saying we have a Timing Cover that is Seeping. Of course my extended warranty ran out last June. My truck only has 78,000 miles on it. I am annoyed that to fix it they quoted me $1230.00!!!
  15. Jun 18, 2015 at 8:16 PM
    #35
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
  16. Jun 19, 2015 at 10:04 AM
    #36
    dakotasyota
    Dakota
    Ellensburg, WA
    Ok I'm doing this. Can people give me advice on which brand to buy for the gasket set? Is there really any difference?
    Also it seems the general consensus is to replace the valve cover gaskets and water pump at the same time... Right? Any brand preferences?
  17. Jul 20, 2015 at 5:29 PM
    #37
    dakotasyota
    Dakota
    Ellensburg, WA
    Done at 165,000 miles. Not too hard... yet not very easy. Just a lot of labor to get everything apart :rolleyes: Anyways, I too circled where the leak was. I also replaced the water pump, idler pulleys, and serpentine belt. Much smoother sounding now :thumbsup:
    hresendiz25, eherlihy and lo2hi like this.
  18. Jul 20, 2015 at 5:30 PM
    #38
    dakotasyota
    Dakota
    Ellensburg, WA
  19. Jul 29, 2016 at 2:22 PM
    #39
    Digger53
    Digger53 New Member
    06 Tacoma SR5
    I have a 2006 Tacoma Automatic Transmission SR5 that has the oil leak. I am looking at doing this myself, but have a question. Do you have to remove the oil pan to get the timing chain cover off?
  20. Jul 29, 2016 at 2:35 PM
    #40
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I think some have done it without removing the oil pan. But, the actual approved procedure requires the oil pan. Both lower and intermediate pans.
