Updated T-SB-0326-08 Oil Leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BeefTaco, Oct 31, 2008.
  1. Aug 10, 2019 at 7:03 PM
    #61
    SpeedwayTaco160
    SpeedwayTaco160 Well-Known Member
    Killeen TX
    10 Sport SWB DCSB
    Yes that is what I meant, I saw on a prior post someone mentioned that they didn't know if they needed sealant there or not. The post never got followed up on.
  2. Feb 2, 2021 at 6:58 AM
    #62
    TacomaPhobia
    TacomaPhobia Member
    Eric
    '07 DCSB 4x4 6 Speed
    @hx989 How did your make shift seal work out? Has it held up? My cover is seeping enough to make an annoying mess, but not enough to affect the oil level on the dipstick between oil changes. I was thinking about trying the external seal.
  3. Feb 2, 2021 at 4:01 PM
    #63
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That is cast in to provide rigidity and strength to the large area of cast aluminum.
  4. Feb 2, 2021 at 4:10 PM
    #64
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Not great, starting leaking again eventually but less so than before. Probably gonna do it over soon. For how easy it was it held up long enough
  5. Jan 1, 2024 at 11:11 PM
    #65
    dmtien
    dmtien New Member
    A bit late to the game but I realized my '06 with 130K miles was losing oil and stumbled on this TSB issue. If I'm going through the trouble of disassembling the engine this far, are there things I should just replace (e.g., water pump, valve gaskets) while I'm at it? I'm also going to check valve clearances before the valve covers go back on.
  6. Jan 2, 2024 at 6:20 AM
    #66
    ryanbitt
    ryanbitt Wherever you go...there you are.
    Hutto TX
    07 DCLB 4x4
    Wouldn't you like to know!
    Water pump, seals, & Thermostat wouldn't hurt. Shortly after those I had to do the radiator. @258K miles
    R0dzilla75 likes this.
