Upgrade to Bed Mount AC outlet
Discussion in '2nd Gen. Tacomas (2005-2015)' started by onevoodooz, Sep 9, 2009.
  1. Sep 9, 2009 at 10:40 AM
    onevoodooz
    onevoodooz [OP] New Member
    Greetings, I just got a new 09 Access cab, but didn't have many choices for options. I would like to add is the ac power outlet in the bed. I can get the whole '05-08 assembly for about $200 bucks, or just the storage box cover with outlet for about $50. My may concern though is the power. I was wondering if anyone ever tried to upgrade the existing inverter to a higher wattage using the existing storage box cover, the factory cover with the outlet...
  2. Sep 15, 2009 at 11:11 PM
    mcampos0
    mcampos0 Today I Will!!!!
    Mark
    EL Paso
    09 DC Pre
    Mud Flaps Off, Window Tint, Keyless Remote w/ Kill switch n Alarm, Straps for shovel in back, Avh-3100DVD, 3in toytec lift, 285/75/16 Nitto tera Grapplers on stock 16 wheels, Polk Audio MM speakers all around
    Keep us posted if you find anything as someothers myself included have the same question
  3. Sep 16, 2009 at 1:18 AM
    JKD
    JKD Well-Known Member
    Any particular reason you want the factory outlet there? There are cheaper options.
  4. Sep 16, 2009 at 2:04 AM
    BLacTaco
    BLacTaco Well-Known Member
    Zabdi
    Los Angeles
    07 PreRunner SR5 Black
    cheaper options??? can you share them with us...
  5. Sep 16, 2009 at 4:53 AM
    onevoodooz
    I intend to install a power inverter with a higher output than 400Watts, though I would like to have the factory faceplate for nothing more than esthetics. I think that I mentioned before that the bed storage box w/ power outlet is available for the 07 for a little over $200 bucks though I do not know if it actually comes with the inverter itself. I just assumed that the inverter was located elsewhere. The trick would be to adapt the new inverter to the factory cover plate. That would be something. In my search I have also found that there is an after market, lockable storage box replacement where I could install a large inverter but without the factory cover. It's an additional cost so I am still looking into it.
  6. Sep 16, 2009 at 3:43 PM
    JKD
    The factory inverter is located under the console storage compartment.
  7. Sep 18, 2009 at 11:34 PM
    foxtail99
    foxtail99 Member
    Arizona
    09 PreRunner DblCab LB
    I removed inverter console a few days ago to pound out a dent in the side of truck (don't ask!). Anyhow the tiny 400w inverter is mounted right next to the outlet. It is powered via some real tiny 12v wires. If I wanted to install an inverter, here is what I would do.
    Pick up a 1000+ watt inverter and mount inside the cab of truck, say behind rear seats. Then pick up some extenstion cord wire from Home Depot and run it out to the rear of truck. Wire into just the outlet you are looking at getting (w/o the inverter, just the plug).
    I had a similar setup in a old Ford F350 years ago. By having the inverter in the truck, I did not have to worry about the elements (rain) getting to it. Also, as long as it has breathing room, I did not have to worry about ventilation. With a high powered inverter, you have to use large 12v cables. Jumper cables with ends removed, works great. Remember, the shorte the 12v wires are, the better. Then you can just use a 120v ext. cord for the rest of the run.
    Hope this is useful to someone....
  8. Sep 18, 2009 at 11:57 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Great info
  9. Mar 19, 2010 at 6:15 AM
    normbal
    normbal Well-Known Member
    Norm
    socialist occupied Maryland
    White SR5 long bed
    minor mods. Hood moustache, truckchamp SS oval step-bars, Go Rhino Hitch step, popnlock plus tailgate hoseclamp, Weathertech digitalfit floor mats. Wheel and spare tire locks.
    After having a TRD loaner that AC outlet in the bed appeals to me too.
    How and Where did you find it for "$50"?
    Norm
  10. Mar 19, 2010 at 9:43 AM
    JKD
    The factory 400w inverter is not located at the outlet location in the bed, it is under the center console. Perhaps you are seeing a GFCI or something?
    It would make sense that 120v wires would be small, since they don't need to carry as much current as the 12v wires to the inverter do.
  11. Mar 19, 2010 at 9:55 AM
    normbal
    Norm
    White SR5 long bed
    May have a partial "fix."
    Look up interpower.com
    Part numbers:
    88010360 Ad 88090050
    Parts cost around $16 plus S&H. I'm going to order them and put them in the left hand cubby, one or the other of them (box is listed as "splash resistant"), get an inverter and run some indoor/outdoor wiring to the plug from the battery.
    Should cost around $150 or less.
    I priced the parts out from Toyota for the box, the outlet, the nuts, it's over $300.
    Fuggedaboutit.
  12. Feb 16, 2016 at 5:53 PM
    Basicoffroad
    Basicoffroad Member
    16 Tacoma sr5
    Do you think that all Tacomas are pre wired for the inverter even tho they aren't installed?
  13. Feb 16, 2016 at 6:31 PM
    DEMikey
    DEMikey Mr. Badwrench
    mikey
    delaware
    2013 red taco
    100XR, OTW Surf Rod Rack, Toytec 3" lift, +1 on tires
    i just put one of these in my work truck, and once i get things caught up and a camper top, i think im getting a pair of deep cycle batteries and one for myself. 2500w continuous, 5000w peak. and pretty decent price.
    i havent looked too much into this, this inverter was issued to me for my work truck. i use it to charge a 12/24v jump box, and all kinds of dewalt batteries, radio batteries, and even run my 4 1/2 angle grinder on it.
    https://www.cobra.com/sites/default/files/manuals/CPI2575.pdf
