Upgrading '09 SOUND... HELP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dustin81, Apr 27, 2009.
  1. Apr 27, 2009 at 7:17 PM
    dustin81
    dustin81 [OP] DUSTOFF
    Rio Rancho, NM
    09 TaCo Lifted TRD
    PRO COMP 6" Lift Stage II PRO COMP 2.75" Coilovers PRO COMP MX-6 shocks PRO COMP skid plate Bushwacker Fender Flares Smittybuilt Chrome Steps KC Chrome 6" SLIMLITES Billet Custom Grill JDM window vent visors Window Tint Flowmaster TRD CAI
    I am looking to upgrade my stereo in my truck, a little at a time. Does anyone know what brands of head units will work with the steering wheel controls? Or is it just a mod? i guess i am basically interested in just getting better sound quality and more bass. the stock speakers such ass, and all i us is my ipod. Is it possible to just upgrade the speakers? will it sound any different, if i'm still using the stock HU? any suggestions?
  2. Apr 27, 2009 at 7:19 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    If you get good speakers and install them correctly it will make a HUGE difference. Especially if you amplify them. The head unit can help to by providing more power (if you dont amplify the speakers)
  3. Apr 27, 2009 at 7:48 PM
    dustin81
    Rio Rancho, NM
    09 TaCo Lifted TRD
    does it make a big difference not upgrading the HU or installing an amp? just speakers?
  4. Apr 27, 2009 at 8:14 PM
    GoBlueFan
    GoBlueFan Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
    wander over into the AUDIO forum and check it out. There are already threads addressing this very topic, and recently. :thumbsup:
  5. Apr 28, 2009 at 4:40 AM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    I put a image dynamics speakers all around in my 09 and they make a world of difference. I have them hooked up to an amp, and it really sounds like I have a pair of subs. These things are really heavy duty.
  6. Apr 28, 2009 at 6:08 AM
    rod11
    rod11 Well-Known Member
    Baton Rouge, LA
    09 Pyrite Mica DC Prerunner TRD Sport
    I replaced my stock speakers with Kenwood Excelons...6x9 up front and 6.5 in the back, all running off the stock HU. It's definitely an improvement, but still not what I would consider a quality sound. The sound is cleaner at moderate volumes, but there's still the issue of not enough power from the stock HU. Once you get up to 50+ volume even the aftermarket speakers gets some distortion. I'm also struggling with getting all of my bass from my front doors. Just doesn't have the same feel as a nice sub from the rear of the vehicle.
    My ultimate plan is to keep the stock HU, but get a 5 channel amp to push the doors and a single sub.
  7. Apr 28, 2009 at 7:15 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    I like the idea of still using the stock head unit...how would you go about hooking up the 5 channel to it? Would you use a clean sweep or just use line out converters to the amp. I have heard not so good things about the line out converters.
  8. Apr 28, 2009 at 8:14 AM
    rod11
    Baton Rouge, LA
    I'm not enough of an audio junkie to justify the additional cost of a clean sweep type product. I ran a 4 channel amp off of my factory HU in an F150 (pushing 4 speakers and a sub). I started with the line out converters and was pleased enough. At the urging of my sound guy, I later gave in and had a Rockford Fosgate 360 installed (mostly for the ipod connection). While the sound quality was improved, for my needs it wasn't improved $300 worth.
  9. Apr 28, 2009 at 8:29 AM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    just to add to my post, I still have the factory head unit. I'm just running a 1000 watt 4 channel amp. I'm no audio guru, had to have it done for me, but it was well worth it!
  10. Apr 28, 2009 at 8:48 AM
    xpander76
    xpander76 Well-Known Member
    Central, VA
    2009 TRD Sport Magnetic Gray Metallic
    2.5 leveling kit w/ 1" block in rear, about to swap out for the aal, Big Country black tube steps Weather tech vent shades Weather tech floor mats yota bug shield yota bed mat TRD Catback Exhaust Alpine CDA 117 MP3 player Ipod classic - 80 gig Alpine Sirius tuner kit Alpine spx 6.75" componets (front) JL Audio 6.5" two-way (rear) Alpine V12 4-channel 70x4 JL Audio W3 10" 2-ohm in custom sealed box. Sony XM-1S 500x1 mono amp full-time 12v power Cobra 75 WX ST cb w/ 4' Firestik antenna Philips x-treme power headlights & fogs.
    I have an 09 and installed a new head unit (Alpine), front 6.5" components, rear 6.5" two-ways, two amps & sub. I wanted to utilize the steering wheel controls also. Unfortunatley the stock radio in the 09's is slightly different than the 05-08 tacomas (mp3 playback, ipod jack, etc.) and the steering wheel adapter (seen here http://www.crutchfield.com/p_127SWIJACK/PAC-SWI-JACK.html?search=pac+steering+wheel&tp=3405) is not compatible for the 2009 model.
    PAC will either have to release a new adapter specifically for 2009+, or publish a diagram showing how to make the current adapter work. The technical support at PAC says to keep calling back every few months b/c eventually they'll work on an 09 and figure out how to make it work. It just hasn't happened yet.
  11. Apr 28, 2009 at 8:51 AM
    hendooman
    Jeff
    KC
    Yeah I was looking at Alpine and the steering wheel controls for the 09 won't work, Kenwood and Pioneer work I think...
  12. Apr 28, 2009 at 8:53 AM
    Joe B
    Joe B Well-Known Member
    Kenwood and Pioneer Pac steering wheel adapter units work but are different Pac part#s.
  13. Apr 28, 2009 at 8:55 AM
    hendooman
    Jeff
    KC
    that is what I thought, it steered me away from the Alpine...there are some comprable models from Kenwood for sure. Sonix Electronis has the new 712 or something, it is bad to the bone...$648 I think.
  14. Apr 28, 2009 at 9:58 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    I have the JBL system and upgrading to my Premier HU has made a huge difference. ( I have a DEH-P660 from years ago in my old ride, still works great!) as for steering wheel controls, you'll need an aftermarket interface. I think all pioneer decks have the input, its identical to a headphone jack on the back. The interface is a SWI-ps from PAC. I'm looking at buying one maybe on this paycheck, we'll see.
    EDIT: shit nvm on the SWI-PS, the earlier poster is right, it doesn't work on 09.
