Upgrading OEM speakers?
Discussion in 'Audio & Video' started by JMC3800, Feb 20, 2016.
  1. Feb 20, 2016 at 1:46 PM
    JMC3800
    JMC3800 [OP] Well-Known Member
    Western MASS
    2021 Off Road DCab
    Has anyone replaced their OEM speakers without replacing the radio? I'm looking for better quality sound in my 2015 DCAB and if so what did you replace them with I have a Non JBL radio. Looking for options.
  2. Feb 20, 2016 at 1:53 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Yes. Do a search on this forum for options.
  3. Feb 20, 2016 at 2:01 PM
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Pittsburgh, PA
    2013 Black Baja Access Cab
    Lots to read, but most folks seem to swap out the head units too. I also wonder if better speakers would be worth if I kept the factory unit in my access cab. Is the crappy performance the fault of the factory speakers alone, or is the amp under-powered too?
  4. Feb 20, 2016 at 3:00 PM
    Cohutta
    Cohutta Well-Known Member
    Georgia
    2011 4x4 AC 2.7
    Dog hair
    So I'm in the midst of doing a full system in my truck but due to a broke tab on my dash kit, I had to hold off on the installation of my head unit / leads to amp and sub. So now I've got new speakers with the factory head unit - long story short, it sounds identical / slightly worse than the factory garbage speakers.
    It's not worth the money, do it right the first time.
  5. Feb 20, 2016 at 3:07 PM
    dertwin
    dertwin Active Member
    Erich
    North Carolina
    2015 DC 4x4 TRD Sport
    I hear you. If you don't have an unlimited budget, do some research on the Alpine Power Pack amp. I added one behind the factory head unit and upgraded all speakers to Rockford Fosgate Prime. It's definitely better but the factory EQ leaves much to be desired.
  6. Feb 20, 2016 at 5:45 PM
    SlowComa666
    SlowComa666 Well-Known Member
    San Antonio TX
    2014 SR5 Access Cab 2WD
  7. Feb 22, 2016 at 12:39 PM
    jas5985
    jas5985 Well-Known Member
    Jon
    Charlotte, NC
    2014 TRD Sport
    Toytec Ultimate Lift Kit, Wheelers 3 Leaf, Camburg UCAs, Stealth 6 Gunmetal Wheels, Falken Wildpeak 285s, Pioneer AVH 5700bhs, PPI Phantom 900.4, Hybrid Audio Unity Components, Image Dynamics IDQ 10, Mr. Marv Custom Box, 30% Tint, Truxedo Truxport Cover.
    I replaced the factory speakers, which were powered by an external amplifier, and added a subwoofer - all while keeping the factory head unit in my 2014.
    I have since replaced the factory head unit and went aftermarket, but it can be done and will still sound MUCH better than stock!
  8. Feb 22, 2016 at 1:25 PM
    JMC3800
    Western MASS
    2021 Off Road DCab
    Can you tell me what brands and perhaps model numbers for the components used for your OEM upgrade?
  9. Feb 22, 2016 at 2:04 PM
    jas5985
    Jon
    Charlotte, NC
    2014 TRD Sport
  10. Feb 22, 2016 at 2:12 PM
    JMC3800
    Western MASS
    2021 Off Road DCab
    Thanks I'll look in to this, was this upgrade a plug and play?
  11. Feb 22, 2016 at 2:17 PM
    jas5985
    Jon
    Charlotte, NC
    2014 TRD Sport
    Not exactly... You'll have to install the amp (which requires running power from the battery as well as remote turn on and tapping into speaker signal from the head unit) and run wires from the amp to your speakers and subwoofer.
  12. Feb 22, 2016 at 2:20 PM
    Goosed
    Goosed Well-Known Member
    07 DC TRDOR
    None
    Do an alpine power pack and some alpine components up front. I did the alpine sps650's in front. It has a built in crossover so no need to find the space under your door for it. Once they broke in they sounded great. Also just did some alpine 6.5 two ways in the rear doors. Sounds really good overall and only spent like $350 on all.
    dertwin likes this.
  13. Feb 23, 2016 at 2:58 PM
    UBYBC
    UBYBC Well-Known Member
    2014 Tacoma TRD OR
    i just installed and alpine power pack, and replaced all 6 speakers with MB Quarts 6.5" components up front and 2-ways in back. Highs and mid range sound really great now. You will lose most all of the low end doing this. At least I did. I will install and under seat sub woofer next to get the low end back.
    Goosed likes this.
  14. Feb 24, 2016 at 8:35 AM
    SlowComa666
    San Antonio TX
  15. Feb 25, 2016 at 7:31 AM
    PaulK
    Paul
    Pittsburgh, PA
    How about this?
    http://*********.com/car-audio-vide...to-your-stock-toyota-tacoma-stereo-head-unit/
  16. Feb 25, 2016 at 8:15 AM
    Cohutta
    Georgia
    2011 4x4 AC 2.7
    Dog hair
  17. Feb 25, 2016 at 9:06 AM
    hitech
    hitech Well-Known Member
    Blair
    Southern MD
    2014 MGM DCSB TRD Sport 4x4
    Just some dumb regular crap everyone else has
    I have a '14 Sport DCSB 4x4 Entune, non-JBL, non-nav. At first I replaced the factory speakers with Sony speakers up front and Kickers in the rear. The sound was actually worse than the factory junk speakers. I then added an Alpine 445U, the sound was much much louder, but I lost all of my bass. I played with the amps settings for both front and rear speakers but anytime I turned up the bass it was like it was a "puck" noise instead of it being bass. Sounded like crap even when the bass was turned up less than half. I left it like that for a year. So, I then decided to remove the new speakers and put the factory ones back in until I could figure out something better. Well, I'm shocked! I hate to say it, but just with the amp and everything else factory, the stereo is night and day from the factory sound, it actually sounds awesome - for just adding the amp. I will upgrade the speakers some day to something worthwhile, but honestly, for crap speakers going through my Alpine amp, I'm "somewhat" impressed. If I upgrade the speakers, I'll probably upgrade the HU as well. Good luck OP, there are many choices out there, and most of the good choices aren't too cheap.
  18. Feb 25, 2016 at 4:09 PM
    SlowComa666
    San Antonio TX
    i have no idea what you people are doing where sound gets worse after installing aftermarket speakers.
    i am running off the stock deck and it sound awesome. also i don't have people singing to my ankles anymore.
    timothom likes this.
  19. Feb 26, 2016 at 8:36 AM
    rnish
    Tacoma 2nd gen
    To use the stock head unit; the aftermarket speakers need to be very efficient, 91 db or better. It also depends on what you call better. The stock head unit will never be able to drive a SW.
  20. Feb 26, 2016 at 12:26 PM
    SlowComa666
    San Antonio TX
    if you have that level of limited knowledge you do not need to be doing anything yourself. find a reputable car stereo shop and have them do the work.
    no one with any stereo experience or reading would try to power a subwoofer with a factory radio. i am running a 3way front end off the stock deck and getting well over 100db over most of the frequency band with the stock deck. this is more then enough for windows up highway listening.
    i carefully chose my replacement speakers after tons of research. i paid little attention to efficiency, it can be adjusted with resistors.
