Upgrading to narrower tires on TRD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trib, Jan 5, 2010.
  1. Jan 5, 2010 at 12:43 PM
    trib
    trib [OP] Well-Known Member
    Has anyone tried running 245/75/16s on their TRD? The truck comes with 265/70/16, however, traction sucks really in wet/icey/snowy conditions if you only have two wheel drive because there is very little weight on the rear axle. IMO a 265 tire is way too wide for a 3500lb truck. My 5700lb tundra came with 255s. I calcualte that a 245 would be about .8" narrower than a 265.
    Has anyone tried running narrower profile tires? How do they look and did you notice any improvement in traction? FYI I am planning to keep my stock 16x7 wheels.
  2. Jan 5, 2010 at 12:44 PM
    98tacoma27
    Ben
    Not Beech Creek
  3. Jan 5, 2010 at 12:49 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    Skinnier tires are better for snow/ice and wide tires for dry conditions.
  4. Jan 5, 2010 at 12:50 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    ^^ What 98tacoma27 said. With less tire mass on the pavement, less friction. With skinnier tires comes less friction/traction.
  5. Jan 5, 2010 at 12:52 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x3
  6. Jan 5, 2010 at 12:52 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    With less contact patch the weight of the rear end is distributed over a smaller area...INCREASING pressure. Add weight over the axle with a smaller tire and you are more likely to hold the truck down in snow and crap....Ice is a whole different story.
    But with less width...there is less tire touching ground....so there is less friction.
    Interested to see what other folks have to say about this....
  7. Jan 5, 2010 at 12:53 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Essentially by narrowing the tire there is more PSI reaching the road.
    Wider thus makes less PSI.
    That being said, I run 265's and couldn't be happier with traction. Type tire has more to do with it when comparing .8" IMO.
  8. Jan 5, 2010 at 12:53 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
  9. Jan 5, 2010 at 12:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have no idea about this "Ice" and "Snow" of wich you Yettis speak of. However, Im just here...to..........well....Im not sure...
  10. Jan 5, 2010 at 12:55 PM
    Afwrestler1986
    Johnstown, NY
    Narrow tires CUT through Snow/slush
    Wider tires float/pack.
    With less surface area touching the road, the weight of the truck is multiplied and vice versa.
  11. Jan 5, 2010 at 12:55 PM
    pfatyol
    pfatyol Well-Known Member
    Patrick
    Southcoast MA & lakes region NH
    2010 DC Sport
    American Roll cover, fog light mod, weather tech, marathon seat covers, twin booster seats.
    Friction doesn't change with surface area.
    Force horizontal = Coefficient of friction * Force down (weight on tire)
  12. Jan 5, 2010 at 12:55 PM
    98tacoma27
    Ben
    Not Beech Creek
    That's wrong Matt. It doesn't work that way. The greater the surface area, the greater the PSI. Think of pancake cylinders.
  13. Jan 5, 2010 at 12:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Welcome to TW! :)
  14. Jan 5, 2010 at 12:58 PM
    JDMcQ
    If the weight stays the same and the surface area decreases, the PSI increases.
  15. Jan 5, 2010 at 12:58 PM
    Afwrestler1986
    Johnstown, NY
    Think of a bed of nails. If you lay down on a bed of them your weight is more evenly dispersed thereby causing a lower PSI.
    If you step on the nail it will go through your foot due to more weight being focused to a smaller surface area.
  16. Jan 5, 2010 at 12:58 PM
    Incognito
    VA
    Tell ya what... Go get a bike going 60mph and get your truck going 60mph and apply the same brake pressure to both and see which one stops the fastest. IMO, the truck would stop because there's more friction on the pavement from the truck tires is creating drag, reducing the speed.
  17. Jan 5, 2010 at 12:58 PM
    Taco-NB
    New Brunswick
    No .. Matt's right :D
  18. Jan 5, 2010 at 12:58 PM
    JDMcQ
    Exactly how a nail or a knife works, pressure concentrated in a small area.
  19. Jan 5, 2010 at 12:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct^^^^^
  20. Jan 5, 2010 at 12:59 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    No...You are wrong. ::Number are made up::
    The truck pushes 2500 pounds down on each tire
    If the tire has a 8in^2 contact patch...That is 312.5 PSI.
    If the contact patch is reduced to 7in^2 that is 357.1 PSI.
    Edit: Damn me and making math...Tooo sllloooowwwwwww
