Upgrading TRD Trans cooler
Discussion in 'Towing' started by EDJY, Jul 1, 2014.
  1. Jul 1, 2014 at 1:30 PM
    EDJY
    EDJY [OP] Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    Hey guys,
    I tow alot with my 05 TRD prerunner and have noticed the transmission get pretty damn hot. I never tow over capacity but I do tow long distances (across the country back and forth)
    On long trips I notice my Transmission really starts radiating alot of heat in the cab. My scanguage wont pick up and trans temp codes but I know it has to be cooking.
    Its actually fairly annoying, I literally have to blast AC to keep the cab cool, even when its snowing outside. Nothing will stay cold more than a couple min in the cup holders.
    Had the tranny fluid changed and apparently the fluid that came out was extremely dirty and black. Its pretty lame we cannot check the fluid ourselves.
    And Yes, the transmission seems just fine, shifts like the day it was brought home.
    My question is does this seem a little excessive or should I just deal with it?Thinking about replacing the TRD cooler with something substantially bigger. Thoughts?
  2. Jul 1, 2014 at 2:41 PM
    gearcruncher
    Canadain bumper technician
    TRANSMISSION COOLERS
    If you do not have a transmission cooler on your truck and you plan to tow or haul heavy loads or you are in heavy stop and go traffic and use 4X4 low a lot , consider purchasing a cooler . The cooler thats built into your rad is designed to cool the transmission with the weight of just the truck by itself .When you are in 4x4 low , your torque converter is usually in the stall stage and creates a tonne of additional heat .
    160 - 200 are considered normal temps providing your engine radiator is functioning properly . If your engine overheats , your transmission will also overheat
    Normal fluid temperature in transmission to be 175 deg. F.
    Rate of oxidation to double for each temperature increase of 20 deg F above normal (175 deg F). As oxidation rate doubles, useful life of fluid is cut in half.
    At 175 deg F life is 100,000 miles
    At 195 deg F (20 deg above 175) life is 50k miles
    At 215 life is 25k miles
    At 235 life is 12k
    At 255 life is 6,250
    At 275 life is 3,000
    At 295 life is 1500
    At 315 life is 750
    At temperatures much above 300 deg F the metals in the transmission will tend to warp, twist etc. high temperatures causes the formation of varnish deposits which impair or pre vent transmission operation.
    At a fluid temperature of 415 deg F fluid life is 30 minutes!
    Source: Empire Lubricants Inc.
    Consider a scan guage [​IMG][​IMG]http://www.amazon.com/ScanGauge-Comp.../dp/B000AAMY86
    Here is the best information for the scan guage http://www.tacomaworld.com/forum/2nd...-pressure.html
    This is how Low Pressure Drop technology works::
    When Automatic Transmission Fluid (ATF) is cold it is viscous. The unique Tru-Cool design allows the colder, thicker ATF to flow more efficiently through two open bypass channels positioned at the top of the cooler. As operating temperatures increase, the ATF becomes hotter and thinner, It's then directed through the core where it is cooled. Tru-Cool's highly efficient cooling technology combines improved protection against lube failure with optimal heat transfer.
    [​IMG][​IMG]http://www.amazon.com/Long-Tru-Cool-.../dp/B005XZXB1M
    Long Tru-Cool Oil Coolers offer advanced cooling protection for many towing applications. The advanced technology out performs TUBE & FIN Designs, Delivers up to 15 times less flow restrictions, 30% more cooling delivers maximum heat transfer, Self-Regulating for maximum lube flow protection through start-up, varied temperatures and driving conditions, heavy loads and towing.
  3. Jul 1, 2014 at 11:44 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
  4. Jul 2, 2014 at 12:11 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    your scangauge should be able to use an xgauge to get the trans temp no?
    Mine does
  5. Jul 3, 2014 at 8:21 AM
    EDJY
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    What codes do you run? I have tried a ton of codes and never could get it to display the temp. What kind of temperatures do you typically see?
  6. Jul 3, 2014 at 8:26 AM
    EDJY
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    Thanks for all the information.... Trans oil life is super helpful. Also, as stated previously my truck is a prerunner so I spend exactly zero time in 4wd. I know that isn't the cause of the heat. I cant tell if the transmission is creating more heat in full OD lock or just all the time. I don't have an issue of the tranny searching for gears usually, and if I do I just run it in 4.
    I have heard from more than one person that flushing fluid, especially fluid that has been burned is terrible for automatic transmission because it causes the (assumed) damaged clutch plates to start slipping. Anyone find this to be true? Is this why Toyota chooses not to have a transmission dipstick? They discourage fluid changes?
  7. Jul 3, 2014 at 11:50 AM
    gearcruncher
  8. Jul 3, 2014 at 12:00 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
  9. Jul 3, 2014 at 12:15 PM
    gearcruncher
    Hey Justus . I am 2010 plus as shown on the link you posted and those codes worked for me , . I have an old scan guage version 3.16 . Up until recently, I wasnt able to get the codes working .
    Read through this post . I am not sure the guy from scanguage continues to offer free flashing to the latest firmware . I was lucky and they released a code that worked for my scan guage version .
    I have never seen the temps go above 200 . If it ever does go above 200 , time for a bigger cooler
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/102837-scangauge-ii-can-read-oil-pressure.html
  10. Jul 3, 2014 at 12:20 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    nice......... I have the newer sc2 so thats not the prob for me........... But now I entered BOTH temps thanks to the 1810 code for RXD............ hope it actually works out right... cant have too much info.
    anyone good at this code crap wanna work with the ultragauge MX I have, please PM me
  11. Jul 5, 2014 at 10:29 AM
    EDJY
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    I will try that code again but I'm pretty sure I have tried all those. What temps do you normally see? Are you TRD? with the cooler?
  12. Jul 5, 2014 at 11:52 AM
    S.B.
    Sean
    San Diego
    15 Taco
    if its below 90F and unloaded i never see above 150. a couple hundred pounds (excluding myself) going 90 through the desert that is 100+F up a hill in 5th unlocked, the fan will kick on (which it at 180) but won't go above 190F. Then as soon as the torque converter locks again it plummets to 150 again.
    Pulling my jeep on a flatbed (at least 5000 lbs) to cali from colorado the highest it got was 220F and that was 70F outside and going up a 7+% grade that was a couple miles long, as soon as it crested it went back down to 150F. When I tow it to the off-road park, which is all up hill at 6000 FT elev., it sits around 180-220. It is hardly ever locked, mostly just sits in 3rd gear.
    Keep in mind that I simply just swapped in the new cooler (posted in my first response) and did not bypass the "cooler" in the radiator.
    All these temps are the reading from an autometer gauge that I have plumed into the hard line that is coming out of the trans, so its the hottest fluid one can measure without a sensor in the trans itself.
  13. Jul 5, 2014 at 12:11 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    trd offroad with tow package.
    160 ish average in this 90+ heat but thats cruising.
    so ya know its gunna go up on takeoff, and any climbs
  14. Aug 9, 2014 at 6:45 AM
    toygoose
    toygoose Well-Known Member
    100 Miles from Nowhere
    2014 TRD Off Road
    Stock, for now
    I'm also looking at an upgrade to the trans cooler. I'm getting ready for after the first of the year, I will be pulling a 4500lb camper on a tour of the East Coast for about 10 months.
    Are you saying the "Long Tru-Cool LPD Transmission Oil Cooler 4454 18,000 GVW" on Amazon is a replacement cooler for the stock TRD cooler? Or would this be in addition to the stock cooler? I know nothing about trans coolers other than what they do. The specs mean nothing to me. I'm thinking you are saying this is a replacement, if so, is there anything else that would need to be done, lines, mounts, fluid?
    Thanks for any help you can provide!
  15. Aug 9, 2014 at 6:54 AM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    I found this Scanguage II code that works for my '07
    Transmission Fluid Temperature
    TXD: 07E021D9
    RXF: 032180000000
    RXD: 2810
    MTH: 00070065FE70
    NAM: TFT
    In degrees F
    I have an oversize cooler ready to replace the stock tow package cooler when I have time. I chose a Hayden 30k lb. GVW
  16. Aug 17, 2014 at 8:13 PM
    Tacouser
    Tacouser Tacoma User
    Chicago area
    12 tacoma Prerunner
    Cab LED's, Color matched front grill emblem,ARE color matched hard bed cover, Audio amp and new speakers
    If you have a newer Scan gauge it will read trans temp. You have to add a Xguage to it. You can get the codes free off the Scan gauge web site. I have it on mine, use it all the time. Plus I just added a secondary trans cooler in line with the factory tow package one. See my post from taco user.
