Upgrading Truck - Need Advice!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Seraph, Dec 20, 2010.
  1. Dec 20, 2010 at 3:28 PM
    Seraph
    Seraph [OP] New Member
    02 xtra cab SR5
    I own a 2002 Tacoma SR5. It's an extra cab, but NOT a Prerunner.
    I go out to the desert 2-3 times a year right now, but am very limited by my little truck. At the suggestion of a friend I've been thinking about this upgrade path:
    -Larger tires (265/75/16)
    -1" spacers in front
    Eventually:
    -Detroit locker
    -skid plate
    -suspension?
    But you guys have the experience. Am I better upgrading my little truck or selling it and purchasing a PreRunner, or a 4WD vehicle?
    Thanks for the advice!
  2. Dec 20, 2010 at 9:02 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    how do you plan on driving it? are you hauling ass like the desert racing guys? or are you just goin out driving around?
  3. Dec 20, 2010 at 9:04 PM
    tiresmokintacoma
    tiresmokintacoma Bean&Cheese Taco
    VIC
    Texas
    18 DCLB OR Prior: 99LX470/05DCOR97LX450/914R
    Basic
    you should sell it... I could use a 4wd :)
  4. Dec 20, 2010 at 9:10 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I say throw on a moderate lift ( 3" or less) and throw some nice All Terrains on it (265s or 285s). That locker will make a world of a difference in its off road capabilities
    Edit: I'd keep your truck because its paid off...the MODs you can do to it are damn near endless
  5. Dec 20, 2010 at 11:48 PM
    Seraph
    02 xtra cab SR5
    Just driving around out in the desert without needing to worry about getting stuck or low clearance.
  6. Dec 22, 2010 at 11:45 AM
    BoostingMS6
    BoostingMS6 Well-Known Member
    Alex
    El Paso, TX
    1995.5 Tacoma Xtra Cab V6
    What do you do in the desert 2-3 times a year that your truck can't handle? I go out every weekend and handle just fine.
    I really wouldn't consider selling and repurchasing. You've got an awesome 4x4 platform right here. With a little lift and some bigger tires, there won't be much you can't handle as an occasional off-roader.
  7. Dec 22, 2010 at 12:10 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    So confused about your truck. Is it a 4x4? Or are you saying it is a 5 lug truck, not the six lug PreRunner? If it is a 6 Lug truck. Then your best bet would be to get a set of ICON Coilovers up front, and a set of Bilstein 5100s out back, with a 3 Leaf AAL set.
  8. Dec 22, 2010 at 12:40 PM
    BoostingMS6
    Alex
    El Paso, TX
    I think he means he has a V6 4x4 without locker. At least that's what I'm getting :confused:
  9. Dec 22, 2010 at 4:18 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I'm guessing he's 5 lug... He didn't say anything about v6 and specifically said non prerunner. I have a5 lug mini and am about to lift it 3" with spindles. A 235 tire is as big as you can go with no lift I believe.
  10. Dec 22, 2010 at 8:51 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    ^^^^ I'm betting the OP has a 5 lug.
  11. Dec 23, 2010 at 9:23 AM
    Seraph
    02 xtra cab SR5
    Yes you are correct, I'm sorry for the confusion everyone.
    A 235/75/16 is the largest tire I can go without a lift? I've read other threads that say 265/75/16 is the largest you can safely run without a lift.
