Upgrage to LSD?
Discussion in 'Technical Chat' started by buck, Nov 8, 2009.
  1. Nov 8, 2009 at 2:58 PM
    buck
    buck [OP] Don't sweat the petty - pet the sweaty
    Ontario, Canada
    15 DC V6 4x4 TRD Magnetic Gray
    High-flow coconut smiley-face air freshener.
    Had the truck in at the dealer for a vibration and no engagement into 4WD. '05 4.0L 4x4 auto.
    They said the 4WD problem is a switch in the front diff, and the vibration is coming from the rear diff. They said there's metal filings in the rear diff and it would be more cost effective to replace the rear axle than rebuild.
    Question: if I'm putting in a new rear axle, is there a benefit to going LSD from a newer Tacoma? Only do lite occasional wheeling but lots of driving in snow.
    Side note: I was surprised at their diagnosis of the rear diff, because when I turned right the vibration went away, so I assumed it was a bad wheel bearing.
  2. Nov 9, 2009 at 7:15 AM
    buck
    Ontario, Canada
    Just spoke to the dealer about an LSD rear diff replacement/upgrade.
    They said that with all the additional electronics, it's probably not feasible.
    .... are the LSD's in the tacoma's electronically actuated? I thought LSD's were mechanical only?
  3. Nov 9, 2009 at 7:17 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    LSD's are mechanical. I think your dealer is stupid. Im very happy with the performance of the LS Diff in mine.
  4. Nov 9, 2009 at 7:24 AM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    That's bull $hit, I got my LSD installed a few months ago by Toyota for $300; its just a direct bolt on part. My price was a hook up price BTW, I'm not sure what it would normally price would be.
    BTW didn't the LSD system change for 2010?
  5. Nov 9, 2009 at 7:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its an R&R, not "bolt on". :) Normal price for install is probably around $500 to $ 600 buxs.
  6. Nov 9, 2009 at 7:43 AM
    raskal311
    S. Cal
    haha.. yeah I knew that what I was trying to say was no electronics involve; it just bolts on. Does $500 include part or just install?
  7. Nov 9, 2009 at 7:45 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That would be instal only. I think the TRD LS Diff is about $299.000 or so....
  8. Nov 9, 2009 at 7:51 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Is your truck still under warrantee? I thought all the driveline components were warranteed for like 6 years?
    If your truck is still under warrantee...have the dealership fix it under warrantee.
    Then - as an after thought....do some research on aftermarket LSD's (mechanical). You could probably find an aftermarket LSD unit (carrier replacement) and have it professionally installed in your current 3rd member (diff housing).
    The 05-08 trucks that have LSD's - are all mechanical clutch pak operated.
    The 09+ trucks have an open differential with AUTO LSD which is operated by the braking system.
  9. Nov 9, 2009 at 7:59 AM
    CJH9980
    CJH9980 Well-Known Member
    Clint
    Shreveport, LA/Tucson AZ
    2018 TRD PRO
    Wescott lift Wescott rock sliders Prinsu Cabrack SpartanXcustoms skewp light Demon Hook front recovery point Diamondback SD (just shipped) N2 Designs Remote Start A few meso goodies
    I recommend the Detroit TruTrac. I've had mine about a year now and have been very happy with it
  10. Nov 9, 2009 at 8:02 AM
    buck
    Ontario, Canada
    That's what I thought. I'm going to get back on the phone with the dealer. I love dealing with 'service advisers' whom have probably never turned a wrench before.
    Truck is 25,000 km's over warranty. That's another battle that I have to fight.
    If I'm getting the rear axle replaced, I may as well upgrade.
  11. Nov 9, 2009 at 8:07 AM
    Agent475
    Agent475 "Mark It Zero"
    Waldorf, MD
    2006 Red TRD Sport
    Hood Struts, 3" Tuff Country Lift, Shortie Antenna, WeatherTechs, Tinted front windows, custom TRD seat covers, custom pedals, debadged, custom USMC badging, quasi-functional hoodscoop (i.e. I cut it open), black front Yota emblem, Tailgate Theft-Prevention mod, Horn Relocation mod, Old Man Emu Carrier Bearing Drop, Brighter Backup Lights Mod, Smittybilt Reciever Hitch Tow Point, currently working on Satoshi Grill Mod
    :popcorn: I have some driveline vibration as well (prob due to the angle of my driveshaft after 3" lift and I haven't changed the diff. fluid yet after 93k miles ( I know... no flaming me)...But I sure hope mine doesn't need replaced...
  12. Nov 9, 2009 at 8:12 AM
    raskal311
    S. Cal
    IC, it looks like I paid for the part and they installed it for free with the drive line vib TSD. BTW I also got them to install my 5100 for free during the suspension TSD.
  13. Nov 9, 2009 at 10:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well Done! :)
