Upper a arm hiem conversion Pros/cons
Discussion in 'Long Travel Suspension' started by nhurt, Jul 15, 2012.
  1. Jul 15, 2012 at 6:41 PM
    nhurt
    nhurt [OP] Well-Known Member
    N8
    San Diego, CA
    98 5 Lug
    total chaos, Fabtech spindles, F67 deaver leafs, dual spares, hella black magic's, 55w HID's, sound system, AEM intake, magnaflow, pacesetter headers, electric fan, optima battery, tach, oil water temp and voltmeter gauges, 4.56 gears, loc-rite locker,
    I have a 98 5 lug total chaos taquito kit up front with fabtech spindles. I'm thinking about doing a upper a arm hiem conversion vice the poly bushing ends it has on now. Reason being is to adjust my camber. Any pros or cons to doing this???
  2. Jul 15, 2012 at 11:12 PM
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    Pros-everything
    cons-non
    Seriously though, it is a great improvement. make sure you solid mount the lowers and you should be set on you're alignment for a while
  3. Jul 15, 2012 at 11:13 PM
    nfs257
    nfs257 Well-Known Member
    Menifee, Ca -> Tucson, Az -- April
    09 DCLB PreRunner MGM SR5 Debadged
    Trac Performance built Prerunner
    What do you mean by solid mount?
  4. Jul 16, 2012 at 12:22 AM
    Motiracer38
    Motiracer38 Active Member
    Lowers are solid, forget what he said. Weld 4 tabs to the top of the frame, put heims on upper arm, and chase the weak link elsewhere in your truck. I bent 3 crosshafts and ripped out countless bolts before I gave up on the truck. I should have just heimed it.
  5. Jul 16, 2012 at 1:00 AM
    whitetoblack
    whitetoblack ******
    Tyler
    SoCal
    02 Prerunner & 08 Prerunner
    Johnny Branch Fabrication, King, Deaver, Glassworks, Toyo Tire, Alpine, work in progress...
    Solid mount means there is no camber adjustment by sliding the bolt back and forth i.e. the arm is mounted to one fixed position.
    And OP do it. Really no cons to it at all just make sure the arms can be converted and still line up straight. I have seen on the newer tacoma TC kits they require a new upper arm to be made to accept hiems. This is due to the lack of a kink in the arm before the standard bushing ends. I will try to find a pic...
    See the difference?
  6. Jul 16, 2012 at 6:09 AM
    nhurt
    N8
    San Diego, CA
    98 5 Lug
    You bent those beefy TC cross shafts?! Those things look pretty indestructible. Good call on the "kinked" ends I need to check my arms to see if I would be able to do it still. Even without the kink in wondering if the ability of articulation in the hiem is enough to be able to cycle through the suspension without binding. Has anyone done this to the 98 taquito kit???
  7. Jul 16, 2012 at 8:18 AM
    Happysmiley
    Happysmiley Well-Known Member
    Fabien
    Ventura, CA
    07 4Runner
    It's not so much the angle of the heim as far as binding...
    It's when you thread the heims in/out for alignment, the mounting width or spread between heims gets wider or more narrow if the arm tubes are angled and aren't going in perpendicular at the pivot.
    You can make it work without the kink but you won't have much adjustablility for alignment
  8. Jul 16, 2012 at 11:34 AM
    nhurt
    N8
    San Diego, CA
    98 5 Lug
    Good call!
  9. Jul 16, 2012 at 12:04 PM
    Happysmiley
    Fabien
    Ventura, CA
    07 4Runner
    The angle doesn't look too drastic on the 5 lug kit, you can always leave a gap on both sides between the heim spacers and the frame tabs and run some thicker/thinner washers to give yourself a little more room for adjustment, then just move the washers around as you need. Not perfect but you can make it work.
    Don't think there is enough room to sleeve on a bigger diameter tube with a bend and fit the threaded bung + heim in, but if there is thats another way to go.
  10. Jul 16, 2012 at 12:19 PM
    nhurt
    N8
    San Diego, CA
    98 5 Lug
    Bending the arm on one side a few inches back crossed my mind. When I get back home I need to try to map it out and make sure it'll work, I'm sure it will even without modding the arm. Has anyone done this to this kit and year?
