Upper ball joint question. Help. (FIXED)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MrTeller, Nov 2, 2017.
  1. Nov 2, 2017 at 8:54 AM
    MrTeller
    MrTeller [OP] Member
    2011 White tacoma trd sport
    I recently bought a set of camburg upper control arms from a member on here and when I tried to fit the castle nut and the cotter pin there just isnt enough thread left. Did anyone else have this issue? The castle nut they supplied was even longer than OEM ( I liked the oem castle nut better because of the flange and metric size). But this seemed to be a problem on both sides. Ive read that some people just use a nyloc nut but I dont think there is even enough thread for that. Help. please.
  2. Nov 2, 2017 at 9:08 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Make sure the ball joint is aligned right to the spindle, it's a snug fit. Doesn't look like you're all that far off but definitely not fully seated.
    I would verify the part number, though. My understanding is the the UCAs are the same between Tacoma, 4Runner and FJ Cruiser but the upper ball joint isn't. I don't know how close they are but it's possible you have the wrong ball joint and the difference is the taper.
    BTW, I wouldn't use a ny-loc, I'd stick with the castle nut and cotter pin personally.
  3. Nov 2, 2017 at 9:13 AM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
  4. Nov 2, 2017 at 9:13 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Is that nut all the way tight? Looks like you still need some ball joint to come through the knuckle
  5. Nov 2, 2017 at 9:45 AM
    MrTeller
    Thanks guys. The cap is a real pain in the ass to get off once sealed, I wont be able to get it off today to check the part number on the ball joint. But as soon as I do ill update this thread.
  6. Nov 2, 2017 at 9:54 AM
    motoxscott
    motoxscott Well-Known Member Vendor
    Scott
    Socal -> Hurricane, UT
    2017 Tundra - 2008 Tacoma
    @MrTeller Where did you get the arms? Those are 4-runner/FJ upper arms, not Tacoma. The ball-joint on the 4-Runner/FJ has a shorter stud length and is too short for the Tacoma. You can also tell by the boot on the MOOG ball-joint. What part number and label is on the box ?
    - Scott @ Camburg
    Hartford likes this.
  7. Nov 26, 2017 at 12:20 PM
    MrTeller
    Just thought id update this. The guys at camburg are awesome, great customer service! Even though it was pain for me to unistall them and reinstall them, Im glad I did.
    As you can see the left picture shows the ball joint seated correctly and the castle nut fits fine. (Just so there is no mix up, the first set I bought were from a member on here not directly from camburg like the second set I purchased.
