upper control arm with 3" lift?
Discussion in 'Suspension' started by justin14200, Jun 18, 2010.
  1. Jun 18, 2010 at 8:15 AM
    justin14200
    justin14200 [OP] frequent reader
    justin
    baton rouge
    2010 prerunner sr5 bsp
    stock
    do i need aftermarket upper control arms with the "procomp 3" iltimate lift kit"? anyone have links to where i can get some total chaos ucas or camburg or whatever they are. ive heard nothig bad about tc ucas...
    is it even neccisary with a 3" lift? i do want my alignment to be perfect and plan on doing it myself at work but will it be possible without new ucas?
    i have a 2010 prerunner sr5 with the v6.
    thanks in advance!
  2. Jun 18, 2010 at 8:18 AM
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    Chris4x4 said this in another thread..."If you want your alignment correct, Yes. Also they are stronger, and have more range of motion than the OEM ball joint." I'd listen to the man:cool:
  3. Jun 18, 2010 at 8:39 AM
    wilsonpj
    wilsonpj Well-Known Member
    Pete
    Charleston, South Carolina
    2006 DC, SB, OR
    OME 3in Lift, LR UCA's, 33in DuraTracs, All-Pro Full Skids, TRD CAI & Cat Back, 16x8 KMC Enduros
    Yea, get them. Check out the Light Racing UCAs if you are not a hard core off-roader. A tad cheaper and will allow for proper alignment.
    Running Board Man likes this.
  4. Jun 18, 2010 at 9:01 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    I'm on stock UCAs with a 3 inch and I'm right in spec. It wants to sorta wonder at 70+, but the truck did it stock too...fine withme and and I'll save the 400 bucks for later.
  5. Jun 18, 2010 at 10:03 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    If you going to pay the $400 for the Light Racing you might as well pony up the other $150 to $200 for the uniball. Thats if your going to be going off road so you can benefit from the upgrade.
    singletrack_ftw likes this.
  6. Jun 18, 2010 at 9:22 PM
    justin14200
    justin
    baton rouge
    stock
    are the absolutely neccisary for a perfect alignment? ill never even go offroad... ill probobly never even put te truck on grass...
    if i have to get new ucas what are the ebest option?
    what is the cheapest?
    and what websites can i order them from?
  7. Jun 18, 2010 at 9:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Odds are, you are not "Right in spec". You may be at the extremes though. Camber is probably at .5*, and your Caster is around 1* or so. Thats why you have the wandering. With a 3" lift, your caster should be closer to 3*+/-
    This depends on the UCA manufacture. My TC's havent made a peep, in the 3 years I have had them....
  8. Jun 19, 2010 at 12:13 AM
    SpaceGoat
    SpaceGoat Active Member
    Hawaii
    07DoubleCabSR5
    Bilstien5100s all around, 1 inch blocks rear, Total Chaos UCAs, Body Cab mounts, Pioneer Head unit, 8 inch sub, Wet Okoles
    I set my Billys at 2.5, had the TSB rears, stock UCAs and thought I would be fine. Had lifetime alignment from Firestone, the manager there is my cousin. Had it aligned as best it could. Alignment cross checked at another shop. Wandered at 50 mph. Running 265/75/17s. Had some bump steer at those speeds. Ride was not what I wanted, my co-worker who has a Tundra with 6 inches on 35s has a nicer ride. All this was on pavement, not even off road. I had the shop set the Caster as far as they could, got it to 1.7 with stock UCA's, that put camber slightly negative, that helped a little but not much.
    I pony'ed up for Total Chaos UCA's-local shop cut me a deal they had around that someone ordered and backed out on. WOW. Aligned at Caster at 2.4, everything else green. No wander at 70 even on 2 lane roads that need paving. Steering tighted up. I consider it money very well spent.
    This is just my experiance, your mileage may vary, but doing all over again, I'd of installed UCA's from the get go.
    grubburg and BassCatchinTacomama like this.
  9. Jun 19, 2010 at 12:16 PM
    justin14200
    justin
    baton rouge
    stock
    is there no set f upper control arms less than like $450?
    dang, thats expensive...
  10. Jun 19, 2010 at 12:47 PM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    Welcome to the world of performance parts.
    I am in a similar boat. Have billy' set at 1.75 right now, but am debating going to 2.5.
    Will most likely need to get "recon" (reconstruction) here on Oahu, so need to decide on going to 2.5 before I set-up my appointment.
    If money wasn't an issue, I would have already ordered.. I did setup a poll on the main 2nd Gen page to get opinions about spending the close to 500 just to get 3/4 of an inch more than I have now..
    Thinking I will just forgo the UCAs and instead get the toytec 1/4 spacer to get the taco-lean straightened out.. (funny.. never really noticed it before, but again, need to do almost everything I want to before my recon appt.)
    Over $400 expensive..YES.. But you do get what you pay for.. Wouldn't you worry a bit if they were considerably cheaper???
  11. May 30, 2019 at 5:29 PM
    SoCali_Guy
    SoCali_Guy Well-Known Member
    California
    TRD OFF ROAD
    I like JBA off-road UCAs.. good performance & reasonably priced
  12. May 30, 2019 at 5:33 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Congrats on reviving a 9 yr old thread. :thumbsup::D
  13. Jun 18, 2019 at 6:12 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    JBA uca’s.
  14. Jun 19, 2019 at 9:19 AM
    Yota_Ivan
    Yota_Ivan Geaux Tigers!
    Ivan
    Arlington, TX
    2006 Tacoma DCLB 4x4 TRD Sport
    A little bit of this, a little bit of that...
    Dobinsons Ball-joint UCA are like $400, but I dont know the quality or performance.
  15. Jun 19, 2019 at 10:29 AM
    gotoman1969
    The JBA uca’s are $449 for the pair.
  16. Jun 19, 2019 at 11:26 AM
    JT@Bajakits
    JT@Bajakits Well-Known Member Vendor
    JT
    Race Trucks and Off Road Suspension
    I hope after 9 years, he got himself a set of UCA's! :)
    TVH475 and TacoCasa like this.
  17. Jun 19, 2019 at 12:28 PM
    Yota_Ivan
    Ivan
    Arlington, TX
    Holy shit. I fell for that one. Damned and I usually am the one giving someone grief for posting to an older than hell thread. Shame on me!!:rofl::rofl:
    JT@Bajakits[QUOTED] likes this.
  18. Jul 20, 2019 at 1:53 AM
    xtwillie
    xtwillie Well-Known Member
    Kevin
    03 Tacoma
    Its okay because over the years you get experience with certain parts so it is good to hear feedback after so many years from everyone. Currently just took over the wifes 03 Tacoma Prerunner and she got the Forester XT with the Kids. I am deciding if it is better to replace all the front end bushings and ball joints or go with and upper control arm as well. Being a mechanic at heart I want to just replace the bushings as everyone else stated the cost for the upper control arm is over 500 bucks in most cases and bushings and ball joints for upper and lower would be under 200 for everything. But knowing the issues with lifting I am leaning towards a new upper control arm and just replacing the rear ball joints and bushings. Now my decision is do I pull the trigger on some SPC control arms that I can get for wholesale at 438.02 or do I save up another week or two and pull the trigger on a set of total chaos uniball upper control arms for.. or Camburg upper control arms for 664.hmmmmm....
  19. Sep 24, 2021 at 10:45 AM
    99luftacoms
    99luftacoms Member
    Edward
    2004 DoubleCab PreRunner
    Modest 2in Bilstein 5100 front struts
    Hello guys, I installed a set of Rough Country struts with a modest 2.5 inch lift in the front, mostly for leveling purposes. I hardly go off roading. Should I upgrade my UCAs? My stock ones don't rub or anything but I've read that I should upgrade when its a 3" lift and I've also read I should upgrade at a 2" lift. Lots of opinions out there. Then you have the money hungry shops that recommend upgrading with any lift :rofl:
    My upper ball joints do need replacing but I'm indecisive. Should I upgrade my UCAs with aftermarkets that have extended travel that come with integrated UBJs or should I just get new UBJs alone? The price difference is pretty big.
    99 Tacoma 4x4 here..
  20. Jan 10, 2023 at 3:34 PM
    2020Tacolorado
    2020Tacolorado Well-Known Member
    Best Slope Colorado
    2020 Soft Taco
    softopper, badass tacovinyl sticker
    Then why even lift the truck?
    WhiskeyHole likes this.
