Upper control arms.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Owenhall, Oct 8, 2024.
  1. Oct 9, 2024 at 2:31 PM
    William H. Bonney
    William H. Bonney Well-Known Member
    2016 TRDOR
    Yes I believe they do, they are made to accommodate a 2-3” lift if I remember correctly. Don’t quote me though, what does it say on thier site?
  2. Oct 9, 2024 at 4:09 PM
    Owenhall
    Owenhall [OP] Well-Known Member
    Owen
    2009 Toyota Tacoma 4x4
    Lift 33s
    I have billsten 5100s with ilbach 2.5 springs but the springs sagged so I later set the 5100 clip setting to .85
    Superdave1.0 likes this.
  3. Oct 9, 2024 at 4:12 PM
    Owenhall
    Owen
    Lift 33s
    Think I’m going to get spc because I called them and they said I can get my wheel in the same position it is with the stock control arms and will have adjustment to move the wheel away from the cab mount. And have better ball joint clearance
  4. Oct 9, 2024 at 5:35 PM
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    I'd do some more research on UCAs before you actually buy. There's lots of good info...
    https://www.tacomaworld.com/threads/spc-upper-control-arms-yay-or-nay.825270/
  5. Oct 9, 2024 at 6:07 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    SPC are great. Been happy with mine for over a year. The adjustability is awesome. You will read mixed reviews. Most are from older spc that had a few bad batches. They have been making adjustable control arms for decades for classic cars.
  6. Oct 9, 2024 at 9:56 PM
    Owenhall
    Owen
    Lift 33s
    I heard they had ball joint issues have they revised the design and are they greaseable?
  7. Oct 10, 2024 at 3:30 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    The new design is not greaseable. I think they contributed the ball joint failure to their lower seal design because it had to let excess grease out.
  8. Oct 10, 2024 at 10:17 PM
    Owenhall
    Owen
    Lift 33s
    Is the 0 setting on the SPC UCAS, the same as the stock control arm caster if so that will work perfectly for my application and will be able to dial in my camber from there
